Drilling A 9 Inch Hole Through Masonry?
Old 04-20-2008, 05:28 AM   #1
Fahrenheit's Avatar
Trade: Solid Fuel Heating, Chimney Services
Hi guys,
It's my first post on here. Quite often i could do with something that drills a 9 inch hole through masonry. I install twin wall prefabricated chimneys and it would be very handy for going through the house wall as the outside diameter of the chimney i use is 8 1/4 inch. Sometimes i need to put a 9 inch hole straight through and other times i need to go through at 45 degrees. I have a 6 inch core drill......is there anything available as a 9 inch and can you use it free-hand or would you need some kind of rig to bolt it to the wall/floor?
Cheers
Fahrenheit is offline
Old 04-20-2008, 07:53 AM   #2
Repair/Remodeling Tech.
jproffer's Avatar
Trade: Repair and Remodeling Services
Re: Drilling A 9 Inch Hole Through Masonry?
I'm not sure they even make a 9" hole saw for masonry, but if they do I'm sure it's QUITE expensive. If you were doing this only once, I would drill several smaller holes in a close circular pattern and knock it out with a hammer...but I assume this isn't just a one time thing so I'm afraid I got nothin' friend...wish I did. Good luck.
Jim P.
jproffer is offline
Old 04-20-2008, 12:13 PM   #3
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & welding
Send a message via AIM to Michaeljp86
They make concrete core bits up to 14". A 9inch will be like $450.
I am just a vessel from which genius flows -Homer Simpson
Global warming is a myth, like evolution and the metric system.
U.S. Coast Guard
Michaeljp86 is offline
Old 04-20-2008, 12:17 PM   #4
chenley's Avatar
Trade: Electric
Just rent a core drill and bit, I think it's only about $35/day here.
chenley is offline
Masonry hole saws JamesNLA Tools & Equipment 13 02-27-2008 07:00 PM
Demo Masonry Fireplace LNG24 Masonry 26 11-12-2007 06:12 PM
Concrete backer over 1/2 inch subfloor jim20 Ceramic & Stone Tile 4 08-01-2007 11:22 PM
Back panel hole england030 Carpentry 2 05-18-2007 10:05 PM
2 inch hole saws LSI Boro General Discussion 1 10-07-2004 08:14 PM
