Different Dust Mask
Old 02-25-2018, 02:53 PM   #1
improving homes
platinumLLC's Avatar
Trade: Roofing/Remodeling
Rewards Points: 304
Different Dust Mask
I have 3 or 4 different 3m dust masks that I try to use when I should. But to be honest there are a ton of times where I should go grab one but don't take the time. When I'm doing something quick I just do it and don't go get the proper mask. If I'm sanding drywall or spraying paint or something like that I do try to use a mask.
So, is there some sort of quick and dirty dust mask? I'm thinking some type of cloth I can just pull over my mouth and nose. I realize it's not going to be the right filtering but it's also going to be better then nothing. And I would only use it for certain things. Even things like drilling holes in wood or sweeping or whatever. Be nice if there was something that l could just leave around my neck so it's always with me and then just pull up when needed. Think I would use it a lot more if it was right there ready to go.
Does anyone use some kind of dust mask like this?
platinumLLC is offline
Old 02-25-2018, 03:01 PM   #2
Stunt Carpenter's Avatar
Rewards Points: 1,060
Re: Different Dust Mask
No idea if there is anything out there but it would be a great idea.
On a related safety note I just picked up a pair of bone conduction headphones that let me wear earplugs and still listen to music. No I find myself always wearing ear plug.
Stunt Carpenter is offline
Old 02-25-2018, 03:02 PM   #3
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 794
We all use the half face respirators from 3M. You can keep it looped around your neck if you want, but I certainly can't see walking around all day with it or any mask for that matter always on.
I wear it for anything that irritates me. I'm fairly sensitive to dust, even just a few cuts on the miter saw in the shop without dust collection gets my nose running and I'll start coughing. I hate the little white masks with the yellow strings compared to my respirator. I keep one respirator in the shop and one in the truck so I've always got one where I am.
I don't know if the dental/doctor style mask might be more what you're going for regarding easy, quick deployment.
Xtrememtnbiker is online now
Old 02-25-2018, 03:18 PM   #4
Radical Basement Dweller
Robie's Avatar
Rewards Points: 11,532
I keep a box of these in the truck.
https://www.amazon.com/Superior-Disp...9QB0H9PAS&th=1
Democrats are doing more to undermine our country than Russians could ever hope to.
Robie is online now
Old 02-25-2018, 03:38 PM   #5
rblakes1's Avatar
Rewards Points: 1,472
I have one of these shirts, I use it occasionally. It's a little bulky around the neck when you don't have the mask on, and it's not really rated for anything, but it's better than nothing!
http://www.dus-tshirt.com
Sent from my SM-N910V using Tapatalk
rblakes1 is offline
Old 02-25-2018, 03:45 PM   #6
Lettusbee's Avatar
Rewards Points: 2,618
what was that dust mask company that was advertising here a few months ago?
Lettusbee is online now
Old 02-25-2018, 04:23 PM   #7
tgeb's Avatar
Rewards Points: 962
The most comfortable mask I have found is an N100 that is easily deployed when you need it and it can hang around your neck when not needed.
I absolutely hate wearing a mask. Typical mask is hard to breath through, leaks anyway and fogs up my eyeglasses. These do none of that, the exhale valve is better than any of the N95 masks I have worn. They ain't cheap but when the difference is an uncomfortable mask that won't be used and one of these that is quite tolerable, I'll take one of these.
https://www.pksafety.com/moldex2730n100.html
www.gebcon.com
tgeb is online now
Old 02-25-2018, 05:21 PM   #8
dibs16's Avatar
Rewards Points: 490
Check out the RZ Mask. I love it so far.
https://www.amazon.com/dp/B071F7ZGR6..._pt0KAbF4NG1TJ
Sent from my SAMSUNG-SM-G935A using Tapatalk
Anthony
dibs16 is offline
Old 02-25-2018, 07:28 PM   #9
This really got me thinking. I think I am going to pickup a motorcycle dust mask.
Like this
Probably not with a skull but same idea
Old 02-25-2018, 08:59 PM   #10
Rewards Points: 794
I think it was the RZ mask mentioned above if I recall correctly.
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
Lettusbee (02-25-2018)
Old 02-26-2018, 06:42 AM   #11
This space for lease
RangoWA's Avatar
Trade: General
Rewards Points: 4,628
I keep a 3M respirator in the truck but don't like working in it, plus it fogs up my glasses at some angles. I have a ATV/dirt bike one I got at Cabelas that is more comfortable but only if I am looking downward. It's almost a good design.
RangoWA is offline
Old 02-26-2018, 06:26 PM   #12
Fugetaboutit
Lunicy's Avatar
Trade: Professional fixer upper
Rewards Points: 404
A bandana
Lunicy is offline
Old 02-26-2018, 08:17 PM   #13
improving homes
Rewards Points: 304
Thank you for the link. I'm going to pick one of these up and try it out. Sounds like it's exactly what I was picturing in my head of what I wanted.
Old 02-26-2018, 08:18 PM   #14
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 1,678
I keep a bunch of the 3M N95 dust masks spread around in zip lock bags. That way I never have an excuse. Safety glasses are kept on my person in a case so they are clean and ready to go.
https://www.amazon.com/3M-8511PB1-Pa.../dp/B0002YKBV2
Often though I just use a breath hold and walk away. Nice to be able to easily go a minute without breathing. Known to do that spray painting from a can...
Peter_C is offline
Old 02-27-2018, 07:59 AM   #15
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,796
Yep, bandana... simple and comfortable. It can also be used in hot weather by wetting it down and slinging it over your head or neck. Good for bad cuts and such ...and bandanas are just plain cool.
I'm not sure they'd be much help in a fracking caused earthquake though.
Originally Posted by Lunicy View Post
A bandana
kirkdc is offline
Old 02-27-2018, 02:21 PM   #16
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 12,510
3M 6000 series...don't use it as often as I should.
Inner10 is offline
Old 02-27-2018, 04:57 PM   #17
RichVT's Avatar
Rewards Points: 625
I've heard that the 3M quick latch masks are convenient for frequent on/off.
https://www.amazon.com/3M-Comfort-Fa...p?ie=UTF8&th=1
RichVT is offline
Old 02-27-2018, 05:11 PM   #18
Peter_C's Avatar
What colors you representin'?
Bandanas
The most recognizable form of gang affiliation is based on color. Bandanas come in a wide range of colors and can be paired with other pieces of clothing to represent all colors of the gang.[8] Not only are bandanas an easy way to show gang affiliation they are also easy to remove if the situation calls for it (i.e. if confronted by law enforcement). Gang members are known for wearing bandanas around their face as a mask, or in their pocket, with it sticking out.
https://en.wikipedia.org/wiki/Gang_colors
Peter_C is offline
Old 02-28-2018, 07:10 AM   #19
RangoWA's Avatar
Trade: General
I have a couple very similar. They are comfortable, I've worn them all day on many occasions for chemicals.
RangoWA is offline
Old 02-28-2018, 07:11 AM   #20
RangoWA's Avatar
Trade: General
I was thinking the same thing. I don't want to look like a bank robber either, there are better ways.
RangoWA is offline
Dust collection platinumLLC Tools & Equipment 5 04-12-2015 11:09 AM
7" angle grinder dust control platinumLLC Flooring 8 12-09-2014 07:47 PM
8X8 PT with sand dust foundation steps Red Dog Solar Landscaping 1 01-20-2013 02:52 PM
Simple multi dust extraction set ups Roofcheck Carpentry 2 01-19-2013 10:56 PM
