Trade: consulting
Definition Mechanical Contractor
I'm sorry to infiltrate this forum, but I thought you guys could help me with a question I had. What's the difference between a mechanical contractor and a plumber? Aren't both the same?
Thanks. |
Re: Definition Mechanical Contractor
A mechanical contractor works on all of the mechanical systems of a building...Plumbing, Heating/Air, and I believe some electrical as well.
#3 | |
Three Rivers Services LLC
Re: Definition Mechanical ContractorQuote:
You really can't compare them to your average plumber. |
#4 | |
Old School Marine
Trade: Union Journeyman Electrician
Mechanical contractors handle piping, electric (low/line), controls, ductwork, associated with the installation of mechanical systems (chillers/boilers/pumps/drives/cogens) Check out www.emcorgroup.com |
EVIL GENIUS
A mechanical contractor does do electrical and plumbing but just on the system they are working on. They do heating, AC, and ventalation. Most plumbers are also mechanical contractors which is why most people think plumbers do HVAC. I worked with a mechanical contractor yesterday and today on a cold storage building used for apples on a farm. He was running 2 1/8" copper tubing for the freon. I did the electrical work on getting the power to the compressor and to the fans.
Trade: consulting
Thanks guys, appreciate it.
Trade: Plumbing
When I was a young apprentice working for a mechanical contractor, I assembled boilers, cut black pipe for heat lines, learned to read blueprints, worked in commercial-only environments. I installed sprinkler systems, was even jobbed out one time to a major fire sprinkler company. I fitted for a welder putting in 4" steel pipe for fluid transfer; I installed rooftop hvac units - geez, I did a lot of stuff.
Since I left there and over many years did plumbing, I've plumbed houses, small commercial, small apartments, and so on. |
#8 | |
Electro-Mech. Contr.
Trade: Mechanical Contractor
"Injustice anywhere is a threat to justice everywhere" mlk 100% Union and Proud of It Last edited by MechanicalDVR; 10-13-2007 at 06:54 PM. |
EVIL GENIUS
Correct me if Im wrong but dont those plumbers who say that have both a plumbers license and mechanical license???????
The Grand Wazoo
What the hell is a mechanical liscense?
#11 | |
The principles in mechanical contracting outfits normally have several licenses of their own, and their men have a great variety of licenses. I thnk of mechanical contractors as "plumbers with brains". They do plumbing, pipe welding, gaswork, fire sprinkler, ductwork, hvac, refrigeration, controls, automation, and electrical. They touch everything that makes a building "tick". They don't normally do all that work on the same job, but they have the ability to do so. Mechanical contractor = plumber plus one or several other related trades. On a job where a mechanical contractor is working, there might also be a plumbing contractor and an electrical contractor doing the major plumbing and electrical work. The mechanical contractor, in that case, takes care of whatever plumbing and electrical is necessary to facilitate his work (like the heating or air conditioning, for instance), with little or no involvement of the plumber or electrician on the job. Last edited by mdshunk; 10-13-2007 at 11:24 PM. |
EVIL GENIUS
Re: Definition Mechanical Contractor |
| Mechanical Contractor Qualifier Available | LOWELL1966 | Help Wanted or Looking For Work | 6 | 01-07-2009 08:26 PM |
| Proposals...... | AAPaint | Painting & Finish Work | 3 | 08-25-2007 09:47 AM |
| Subcontract | C.C.R. | Business | 6 | 04-27-2007 01:24 PM |
| Problem with Tile contractor in Florida | storesstores | Flooring | 3 | 03-13-2007 12:01 AM |
