Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Contractors Talk Forums > General Discussion
Old 01-19-2008, 09:12 AM   #1
AbriamBarkerCarpentry
Damp cedar closet
I built this cedar closet six months ago and learned yesterday that the all the garments inside the closet are damp. The closet is in a basement in the Boston area. I've seen many cedar closets in basements before so I didn't think dampness would be an isue.
Any suggestions? I don't want to install a fan in this closet.
AbeBarker is offline   Reply With Quote
Old 01-19-2008, 09:42 PM   #2
Trade: remodeling contractor, SE Mass.
I don't think a fan would work. If there is a high humidity level in the basement it will be very hard to keep it out of the closet. Humidity is very pervasive it wants to seek its own level like water. My sugestion is to 6 mil poly seal the closet( sealing joints in poly),rubber gasket the door, and install dehumidifier in closet. I know this sounds extreme, but I can't think of another solution off hand, unless you lower the humidity level in the whole basement. Phil
philner is offline   Reply With Quote
Old 01-19-2008, 11:34 PM   #3
Trade: Repair & Restoration Contractor and Specialty Graphics/Sign Installer
need more info, photos would be nice
are any closet walls perimeter basement walls?
block/poured walls ?
insulated ?
vapor barrier placement ?
floor?
ceiling?
is there a crawl space next to basement ?
humidifyer on HVAC ? what is it set at ?
return and supply HVAC vents near ?
Tin Cup
Tin Cup is offline   Reply With Quote
Old 01-20-2008, 02:19 PM   #4
Knowledge Factory
Floordude's Avatar
Basement = below grade
Ground moisture is going to make it have more moisture then above grade
http://www.AustinFloorguy.com
Floordude is offline   Reply With Quote
Old 01-20-2008, 02:26 PM   #5
If it's an older house my first guess would be
no vapor barrier in the floor.
Put down something impervious on the slab
for a week and check.
If it's on an outside wall,
or if there is dampness in other areas...
Different problems.
neolitic is offline   Reply With Quote
cedar shingles wink Roofing 22 10-08-2008 06:36 AM
Paint on cedar siding peeling. gideond Painting & Finish Work 19 05-03-2008 07:53 AM
Eastern Red Cedar TexasTimbers Contractor Swap 2 10-25-2006 06:08 PM
Cedar Railing Stain for the Pros gregt848 Painting & Finish Work 6 09-28-2006 08:59 PM
roofing over cedar jkdon Roofing 24 03-16-2006 09:26 AM
