Cutting Off The Bottom Of Bi-fold Doors..?
Old 03-12-2008, 04:37 PM   #1
bujaly's Avatar
Trade: Commercial interior super
When you cut off 3/4" off the bottom of a Jeldwin hollow bi-fold door, the piece of "wood" that holds the pin in place is removed. What way do you all successfully re-attach that little booger?
"Relentless in Reliability and Satisfaction!"
Oh yeah, 1 other thing...
Assuming doesn't make an a55 out of me and you, it makes an a55 out of YOU and YOU!!!
bujaly is offline
Old 03-12-2008, 05:04 PM   #2
Teetorbilt's Avatar
Re: Cutting Off The Bottom Of Bi-fold Doors..?
Custom cut a replacement, gobs of Titebond II, clamp and proceed as usual. Done it plenty of times.
Albert Einstein
Teetorbilt is offline
Old 03-12-2008, 05:28 PM   #3
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & welding
Send a message via AIM to Michaeljp86
I did the same last year, just measure where you need your new hole for the pin on the new piece. Glue and clamp it
I am just a vessel from which genius flows -Homer Simpson
Global warming is a myth, like evolution and the metric system.
U.S. Coast Guard
Michaeljp86 is offline
Old 03-12-2008, 07:35 PM   #4
Remodeling GC
kevjob's Avatar
we cut new pieces and use good glue and clamp down to hold in place
kevjob is offline
Old 03-12-2008, 07:55 PM   #5
Tao_Rider's Avatar
Trade: Residential Remodeling Contractor
Personally, I'd use some duct tape and bailing wire, but, my customers aren't that picky either.
Tao_Rider is offline
Old 03-12-2008, 07:58 PM   #6
Thag
Thag's Avatar
Trade: Home improvements
Be there done that.
Thag is offline
Old 03-12-2008, 08:04 PM   #7
dkillianjr's Avatar
Glue and clamp, but if I need to hang the doors quicker I will shoot a couple brads in the peice to hold it til the glue dries. I wouldn't use the door til the glue dries but you can atleast put it back on.
dkillianjr is offline
Old 03-12-2008, 08:40 PM   #8
C.C.R.'s Avatar
Trade: Remodeling contractor
That's the way to go.
I just came across a new construction adhesive (probably been on the market a million years) I think its called Quick Grab or something like that. It comes in a tube and is usually with the PL400 and such but its much thinner than the others. So that might be a good option. I tried it out I put a glop on a 2x4 about 1'long and stuck it to my basement wall (painted block) and walked away. Next day it hadn't moved a spec.
Complete Custom Remodeling
"When Quality is Top Priority"
www.completecustomremodeling.com
C.C.R. is offline
Old 03-12-2008, 10:57 PM   #9
EVIL GENIUS
I see this all the time, you must work for landlords.
U.S. Coast Guard
Old 03-12-2008, 11:01 PM   #10
Deck Designer/Builder
DecksEtc's Avatar
I was taught to remove the piece, cut the bottom of the door and then replace the piece and glue and clamp it.
DecksEtc is offline
Old 03-12-2008, 11:37 PM   #11
EVIL GENIUS
How do you remove it when it glued in? I have cut it off them pealed the sides off the old piece and glued it back in.
U.S. Coast Guard
Old 03-13-2008, 12:59 AM   #12
bujaly's Avatar
Like I said, when u cut 3/4" off, it is already cut off. You just peel away the sides and proceed.
As for the rest of the answers, I figured as much, I just glued them and nailed them from the sides(aesthetics). Pretty much what you all are saying you do as well.
bujaly is offline
Old 03-13-2008, 06:59 AM   #13
Pearce Services's Avatar
Trade: Commercial Loading Dock and Door Contractor
I just remove the veneer from the bottom plug, glue it back in, and shoot a few brads to stabilize it until It's dry. Then I take white phenoseal, and skim the bottom of the slab to clean, and seal it.
Pearce Services is offline
Cutting panels into solid wood doors. BentheBuilder Windows, Siding and Doors 8 03-06-2008 11:28 PM
What to use on sandblasted security doors? Dorman Painting Painting & Finish Work 3 08-07-2007 06:24 AM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
Determining Manhours for rolling vs. cutting - your suggestions would be helpful Zeebo Painting & Finish Work 9 06-02-2006 06:12 PM
