Suck it up, or shut up
Cutting A Cultured Marble Counter Top
I need to trim a cultured marble counter top, does anyone have any suggestions
thanks |
#2 | |
Capra aegagrus
Re: Cutting A Cultured Marble Counter TopQuote:
By coincidence, just today for grins and giggles I tried trimming a 1x3 piece of marble with a diamond blade on my grinder. No matter how slow and careful I was, it chipped and flaked six ways from Sunday. Fortunately, it was a waste piece that was being discarded anyway. |
Chief Toilet Mover
Trade: Bathroom Remodeling
Wood working tools work on it. (It's plastic & resin with some marble dust)
Big piece to cut off use a skill saw. Just a smidge you can work it with a belt sander. Wear a mask! |
Capra aegagrus
Re: Cutting A Cultured Marble Counter Top |
#5 | |
KemoSabe
Like Mike said, turn it over,
cut it from the back, and support it so the cut piece doesn't fall away. I've used a carbide or diamond blade.
Trade: Painting & Remodeling
I've always used a router. Gives a nice clean cut and no "dust" to worry about. I do wear a resp and safety goggles. The guy who showed me how to cut with a router was a manufacturer of cultured marble tops and panels.
General Contractor
Good new carbide blade will do the job. Cut the top being upside down. If there is a wall on one or both sides, backsplash will cover any imperfections, if not straighten it out with a wet sander, sanding sponges work best.
Good luck
bathroom guru
I stopped using cultured marble a few years ago (got sick of it!!) but I have done lots in the past. I always used a masonry blade either in a skill saw or grinder (smaller one). No chipping - pretty clean cut.
I builds'em
Trade: Renovations & Decks
Abrasive?
Ryan |
bathroom guru
Yes
I also used to use carbide grit jig saw blades for cut-outs |
does anyone have advise on 'polishing' surface abrasions? I set a paint can on the counter and it caused some scuffing.
Trade: trim carpentry
I had a builder call me today to see if I was interested in setting some vanity tops. So I checked it out and all of the tops will have to be trimmed to fit. the backsplashes are already built into the tops but the side splashes will also have to be trimmed to fit the profile of the backsplash.
Since only about 1/8" needs to come off the tops due to walls not square I'm thinking about trying to shave them with a belt sander. is this a viable option to fit them to the wall. or would I be pissing in the wind trying to get 1/8th off with a beltsander? forgot to mention that these are also cultured marble to the best of my knowledge |
#14 | |
Trade: GC Residential / Light Commercial
You can fine tune it with a grinder using a disc pad and 150 grit. |
| Polishing Cultured Marble Cuts | neolitic | Ceramic & Stone Tile | 14 | 06-25-2009 01:34 AM |
| Cutting cultured marble counter top | im4snow | Kitchens & Baths | 5 | 12-01-2008 06:35 PM |
| Cultured Marble Removal | jv4511 | Remodeling | 9 | 04-07-2008 09:02 PM |
| cultured marble counter top | ponch37300 | Carpentry | 6 | 11-08-2007 10:28 PM |
| Cutting cultured marble | kenvest | Plumbing | 16 | 11-23-2005 09:54 PM |
