Current Job "mold" - Page 2 - General Discussion - Contractor Talk
Current Job "mold"
Old 12-25-2017, 10:36 PM   #21
Renaissance Man
superseal's Avatar
Rewards Points: 5,630
Re: Current Job "mold"
Improperly vented bath fans more than likely...and most remediators would have it done in a day for less than 3K.
supersealconstruction.com
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
rrk (12-26-2017)
Old 12-26-2017, 10:29 AM   #22
Jrno1's Avatar
Rewards Points: 80
Yes I just don't want her paying for it.
Jrno1 is offline
Old 12-26-2017, 10:30 AM   #23
Jrno1's Avatar
Rewards Points: 80
The company is coming out Friday with a fogger.. Going to have a couple restoration friend look at this first.
Jrno1 is offline
Old 12-26-2017, 11:51 AM   #24
Insrepair's Avatar
Trade: Ins Repair
Rewards Points: 18
Done 100’s of these roof mold remediation. #1 factor was wet decking on roof install with improper venting. Without seeing it-it appears the decking has substantial rot and probably isn’t a durable nailable surface and will need replaced. Microban will only help in cross contamination concerns, which is justified and the fogging will help getting into those hard to reach areas.
Now, I never condone trying to place blame on another contractor but you need to see if an HVAC contractor installed the venting. I’ve watched way to many roofers lose lawsuits for improper venting leading to mold in attics. HVAC=heating, VENTING & AC.
Insrepair is offline
The Following User Says Thank You to Insrepair For This Useful Post:
Jrno1 (12-26-2017)
Old 12-26-2017, 11:59 AM   #25
Jrno1's Avatar
Rewards Points: 80
Originally Posted by Insrepair View Post
Done 100ís of these roof mold remediation. #1 factor was wet decking on roof install with improper venting. Without seeing it-it appears the decking has substantial rot and probably isnít a durable nailable surface and will need replaced. Microban will only help in cross contamination concerns, which is justified and the fogging will help getting into those hard to reach areas.
Now, I never condone trying to place blame on another contractor but you need to see if an HVAC contractor installed the venting. Iíve watched way to many roofers lose lawsuits for improper venting leading to mold in attics. HVAC=heating, VENTING & AC.
Absolutely love your input thank you!
Jrno1 is offline
The Following User Says Thank You to Jrno1 For This Useful Post:
Insrepair (12-26-2017)
Current job in Boardman, Oregon - Front end finished NWPB Specialty Trades Picture Post 2 05-26-2013 03:38 PM
Any current deals on Makita brushless kits? redwood Tools & Equipment 27 06-30-2012 07:44 PM
Why does code note require gfci breakers on electric water heaters? bob_cntrctr Electrical 187 09-30-2009 02:26 PM
Need help with a shocking outside waterspout Badoish Electrical 23 12-27-2008 04:18 PM
shocked when touching bath faucet earl964 Electrical 28 09-16-2008 04:50 PM
