#61 | |
Re: Crown Molding, Could Use A Little Help...Quote:
#62 | |
Great advice from Gus! |
#63 | |
Maker of fine kindling
Every parent who has walked barefoot into their child's room late at night hates Legos |
#64 | |
One that I like is that if you are doing stain grade base moulding and the outside corner miters end up too shallow (you cut for a 90 degree corner but you should have cut for a 90.5 degree corner) you can roll the shaft of a round nailset along the point of the miter crushing the wood fibers and bringing the tips together. |
#65 |
I like Green things
Wavy, bumpy wonky ceilings are my specialty.
I have glued outside corners, pined them, thrown one or two nails in and waited untill the next day to move the section of crown up to the wavy, dipped ceiling without pulling that outside corner apart. With enough practice one will figure out all the little tricks to make an ugly crooked room look good crowned out.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana Warner Remodeling Facebook |
| The Following User Says Thank You to WarnerConstInc. For This Useful Post: | Tom Struble (11-03-2009) |
#66 | |
Trade: general carpenter
#67 | |
KemoSabe
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
#68 |
The August/September issue of Fine Homebuilding has a nice little article about making a jig to check your cope. Basically a jig you set your coped piece of crown in with a little cut out window to see the back of your cope as it's butting against a scrap piece of crown. That way you can see were you have to take a little more off to get a good fit.
Some other really helpful tools to have if you start doing trim a little more often is a Collins Coping foot for you jig saw and Collins miter clamps. www.collinstool.com Also a few rat tail files can be pretty helpful too. |
#69 |
I like Green things
I am going to have to say, after playing with the collins clamps a little, I do not like them.
I am going to have to get some of that FasctCap glue!!
#70 | |
Trade: Remodeling/building
Always work one direction is my nickels worth of advice. Don't nail it tight until you get all the joints lined up and matched. I think someone already mentioned doing that. If the crown is stained, stain your raw cuts. It makes them look better if you are off a small fraction that isn't enough to redo it. Last edited by CharlesD; 11-03-2009 at 10:09 PM. |
#71 |
KemoSabe
It gets easier with practice.
#72 |
Re: Crown Molding, Could Use A Little Help...Is it me, or is that a wicked spring angle? Last edited by Meetre; 11-03-2009 at 10:17 PM. Reason: can't brain today, I've got the dumb |
#73 |
Trade: carpenter/ handyman
I am not a fan of Ryobi tools but someone recommended me to this product & it actually works. I have never used the laser, but I use the airgrip base with the arm & it holds up one end of 16' crown molding perfectly. I let it run for hours & I haven't had to change the batteries yet.
Steve http://static.howstuffworks.com/gif/...001-large.jpeg http://products.howstuffworks.com/ry...001-review.htm http://www.woodmagazine.com/woodwork...s-laser-level/ |
#74 |
KemoSabe
It's not you. That was the biggest PITA crown I ever installed. The spring angle made me think I was installing it upside down, until I tried one upside down and it looked like dookey.
#75 |
If you use that activator you have to be quick, it sets in 3-4 seconds and is fully cured in 30 seconds or so. I have had to recut pieces because I bobbled the mitre as it set...
#76 | |
Super B
#77 |
For anyone that for whatever reason actually wants to cut crown laying flat, here's a handy link I've had stashed away. http://www.dewalt.com/us/articles/ar...odworking&ID=2
#78 |
Trade: siding
me either i was thinking a spreader bar would help hold things tighter
Tom |
#79 |
I like Green things
Where's the damn pictures all ready!!
#80 |
KemoSabe
Here's some
__________________________________ "Walking the fine line between production and perfection" __________________________________ Last edited by loneframer; 11-04-2009 at 08:53 PM. |
| plaster crown molding install prices... | CREATE NYC | Finish Carpentry | 21 | 01-27-2010 05:28 PM |
| Pricing 5 1/2" Crown Molding, Baseboard (Colonial) and 3" Chair rail into metal studs | baumbuilders | Finish Carpentry | 18 | 05-05-2009 11:28 PM |
| plaster crown molding install prices... | CREATE NYC | Painting & Finish Work | 2 | 01-19-2009 06:43 AM |
| Crown Molding | SHAWNPAINTS | Painting & Finish Work | 16 | 01-05-2007 02:07 PM |
| Flexible Foam Crown Molding | pshammond | Finish Carpentry | 11 | 08-06-2006 11:53 PM |
