Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Contractors Talk Forums > General Discussion
Old 11-02-2009, 03:39 PM   #1
freemason21's Avatar
Trade: carpentry and painting
crown molding, could use a little help...
just put some in a room still got a lot to do but whatever. stuff is a pain in the a$$ on the corners im not that good at it yet. any tips?
Originally Posted by Mike Finley View Post
You're probably the next coming of Jesus in regards to construction.
freemason21 is offline   Reply With Quote
Old 11-02-2009, 03:42 PM   #2
genecarp's Avatar
UPSIDEDOWN_______AND BACKWARDS______GMOD
genecarp is online now   Reply With Quote
Old 11-02-2009, 03:45 PM   #3
What Gene said, and COPE you corners.
Originally Posted by Zinsco View Post
First off, I have nothing but contempt for my employees, they will never be as good as me and I hate them for that.
www.meetre.com
Meetre is offline   Reply With Quote
Old 11-02-2009, 03:45 PM   #4
Trade: finish carpenter
1. set up a jig before you start cutting.
2. make practice cuts on scrap. I have been doing this for years and I still use scrap pieces to fit a cut just right.
3. Just like with anything else practice and experience are the best teachers.
maverick17 is offline   Reply With Quote
Old 11-02-2009, 04:16 PM   #5
Maker of fine kindleing
Gus Dering's Avatar
Trade: cabinet maker
The key to making crown molding installation easy and consistent is a chop saw that cuts well and very square and a good jig to hold the crown at the spring angle.
Notice that the crown is upside down. That is because you will be marking the cut on the bottom. Transfer your mark to the very bottom little shoulder and simply line that up with the kerf in the jig. That takes the eye balling part out of the equation.
If you are coping the inside corners do a search in the trim carp area and that will turn up all kinds of fun reading. Basswood has a video showing how he uses an angle grinder to do most of the back cutting. Good stuff in there.
Like others are telling you, you need practice. Crown molding is tricky for a lot of seasoned guys. Hang in there.
Originally Posted by WarnerConstInc. View Post
Gus is right.
Gus Dering is offline   Reply With Quote
Old 11-02-2009, 04:23 PM   #6
Thom
thom's Avatar
I learned upside down and backwards per the illustration by GUS. I tried using a compound saw. What a pain in the AS$ that was. Up-side-down and backwards is the way to go.
Great illustration Gus.
thom is offline   Reply With Quote
Old 11-02-2009, 04:26 PM   #7
Illusion of Perfection
CookeCarpentry's Avatar
Trade: Residential Remodeler/Custom Carpenter
Am I the only one who uses the pre-set stops on a miter saw and lays the crown flat?
Mark
Wayne, PA
"It is what it is."
CookeCarpentry is offline   Reply With Quote
The Following User Says Thank You to CookeCarpentry For This Useful Post:
JumboJack (11-02-2009)
Old 11-02-2009, 04:27 PM   #8
Yes, you are!
www.meetre.com
The Following 4 Users Say Thank You to Meetre For This Useful Post:
CookeCarpentry (11-02-2009), izzy (11-03-2009), Jeffrey Watson (11-04-2009), naptown CR (11-02-2009)
Old 11-02-2009, 04:31 PM   #9
Gus Dering's Avatar
You are clearly in the minority but that don't make it wrong if it works for you.
You are at the distinct advantage when it comes to those larger profiles that will not fit the throat of the saw standing up. You can hang your pride on that one.
Gus is right.
Old 11-02-2009, 04:35 PM   #10
Gus - this is exactly why I learned how to cut it that way.
I even had a chart at one time that I would cheat off of if the bottom or top was open, that would show me what degree to change the miter or bevel too. Now it's kind of ingrained.
Mark
Wayne, PA
"It is what it is."
Old 11-02-2009, 04:35 PM   #11
WarnerConstInc.'s Avatar
Trade: Sure, what you got?
Angle finder, Kapex, and crown stops. I am offically over coping for now.
I have done 3 small cut-up, wonky old kitchens, did not cope a single joint and it turned out better than when I coped and used my Bosch saw.
Thank you Kapex and your little angle thingy and your crown stops.
I hate, I mean refuse to cut crown flat. If it is bigger than 6 5/8" I suppose I have to.
It may be just a gateway tool to the hard stuff. Be careful
WarnerConstInc. is offline   Reply With Quote
Old 11-02-2009, 04:50 PM   #12
NormW's Avatar
Trade: Builder
When you cope your corners try putting the blade in your coping saw, backwards... Try coping by cutting on the pull stroke, I find it a lot easier. Also, if you have a dremel tool, try using it to fine tune the fit. Last thing to remember, if the joint won't go tight, and you can't see where its hitting, You have to back cut more.
Keep trying, and learn how to cope. You'll be better than most, eventually.
NormW is offline   Reply With Quote
Old 11-02-2009, 04:52 PM   #13
J F
where did everybody go?
J F's Avatar
wonder how confused the op is now
J F is offline   Reply With Quote
Old 11-02-2009, 04:53 PM   #14
J F
J F's Avatar
the kapex is just waaay too expensive....it's only for people with more money than brains.
Old 11-02-2009, 04:55 PM   #15
I guess you belong in that club with me too, huh?
Old 11-02-2009, 04:56 PM   #16
J F
J F's Avatar
I'm really screwed, I don't even have the money
Old 11-02-2009, 05:03 PM   #17
Gus Dering's Avatar
That Kapex may seem spendy until you take a look at that little Italian fox of a saw in that post up there ^^^
Although I wouldn't want to carry it from where it is to the truck with out help from two young studs while I watched and cheered them on.
Gus is right.
Old 11-02-2009, 05:09 PM   #18
J F
J F's Avatar
My next miter saw is going to have to be made of balsa wood at the rate I'm going.
Old 11-02-2009, 05:14 PM   #19
PHB CONSTRUCTION LLC
paulie's Avatar
Whatever happend to balsa wood, I haven't heard that for years.
paulie is offline   Reply With Quote
Old 11-02-2009, 05:17 PM   #20
Chief hand holder
bert0168's Avatar
Trade: Residential Remodeling
Nah, I'm with ya on that one.
I have done it both ways, U & B on small stuff but flat on larger crown.
bert0168 is offline   Reply With Quote
Pricing 5 1/2" Crown Molding, Baseboard (Colonial) and 3" Chair rail into metal studs baumbuilders Finish Carpentry 18 05-05-2009 10:28 PM
plaster crown molding install prices... CREATE NYC Finish Carpentry 19 01-23-2009 04:36 PM
plaster crown molding install prices... CREATE NYC Painting & Finish Work 2 01-19-2009 06:43 AM
Crown Molding SHAWNPAINTS Painting & Finish Work 16 01-05-2007 02:07 PM
Flexible Foam Crown Molding pshammond Finish Carpentry 11 08-06-2006 10:53 PM
