Coring Through Rebars
Old 10-28-2013, 04:38 PM   #1
BROTTO's Avatar
Trade: General B
WHAT KIND OF DRILL BITS, OR TOOL OR MACHINE YOU WILL USE TO CORE 7/8 HOLE 8" DEEP IN CONCRETE, TROUGH TWO OR THREE #5 OR 6REBARS, HILTI WET DIAMOND BLADE IS OUT OF QUESTION, BURN OUT IN FIVES MINUTE DIDN'T DRILL NOTHING. ANY SUGESTION PLEASE, IT IS VERY IMPORTANT, YOU CAN EMAIL ME TO IF YOU WISH AT.
branko@brottocompanyusa.com
BROTTO is offline
Old 10-28-2013, 04:46 PM   #2
Have Trowel, Do travel
brunothedog's Avatar
Trade: Artisan
Rewards Points: 1,188
Re: Coring Through Rebars
I have had no problem drilling with Hilti's core bits.
I use the ones specifically for wet cutting thru rebar.
I have used others as well, Its important to use the right diamond cores for the job.
It's more important knowing what your doing. I have done over 500 holes thru reinforced concrete with various machines, take it easy and take it slow,
I hope your using the base for drilling .
by burning, or ruining the bit tells me your doing something wrong.
Oh, and welcome
brunothedog is offline
Old 10-28-2013, 04:54 PM   #3
Project Superintendent
mudpad's Avatar
Rewards Points: 2,000
YOU DON"T HAVE TO YELL, WE CAN HEAR YOU.
Call your local cutting and coring company. You obviously need some help.
Steve
mudpad is offline
The Following User Says Thank You to mudpad For This Useful Post:
griz (10-28-2013)
Old 10-28-2013, 04:58 PM   #4
Pearce Services's Avatar
Trade: Commercial Loading Dock and Door Contractor
Rewards Points: 36
I bet he is just using a SDSplus bit
Kevin
www.BadcoDoors.com
Pearce Services is offline
Old 10-28-2013, 05:06 PM   #5
mudpad's Avatar
Well, he said "core"
Are you using a core drill bit? That cuts a circle and leaves the center?
Steve
mudpad is offline
Old 10-28-2013, 05:11 PM   #6
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
7/8" core??..8" deep?? just drill that sucker
-Steve
TimelessQuality is offline
Old 10-28-2013, 05:26 PM   #7
mudpad's Avatar
You got it from 2 Steves now. What's the problem?
Steve
mudpad is offline
TimelessQuality (10-28-2013)
Old 10-28-2013, 05:26 PM   #8
rustyjames's Avatar
Rewards Points: 1,524
A Hilti core bit is about as good as you can get, unless you're using it wrong.
rustyjames is online now
Old 10-28-2013, 05:34 PM   #9
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 11,560
I'd bet a coffee that a 7/8" rebar cutter will go through rebar faster than a core bit.
Just drill until you hit bar, then toss in the cutter.
Inner10 is offline
Old 10-28-2013, 05:36 PM   #10
mudpad's Avatar
Probably will. But apparently the OP is not using either one.
Steve
mudpad is offline
Old 10-28-2013, 05:36 PM   #11
Kent Whitten's Avatar
Rewards Points: 2,040
Dude...turn your cap locks off.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 10-28-2013, 07:44 PM   #12
BROTTO's Avatar
Trade: General B
We use all right excluding rebar cutter we will try tomorrow, problem is, i have to core or drill 2000 same holes and if i reach only 50% steel will be very hard, well thank you for yours inputs, will let you know what happen tomorrow
branko tomas
BROTTO is offline
Old 10-28-2013, 07:58 PM   #13
mudpad's Avatar
branko tomas
2000 Holes? I repeat my advice with more emphasis: Call Your Local Coring and Cutting Contractor! Then the only thing you will need is a Sharpie to lay out the locations.
Steve
mudpad is offline
The Following 2 Users Say Thank You to mudpad For This Useful Post:
Californiadecks (10-28-2013), rustyjames (10-28-2013)
Old 10-28-2013, 08:19 PM   #14
BROTTO's Avatar
Trade: General B
Yeh sound good but i have lots of workers, and i have to do a best i can do, thank you for advise
bt
BROTTO is offline
Old 10-28-2013, 08:24 PM   #15
mudpad's Avatar
branko tomas
Well, we are talking about concrete and rebar right? These materials are used because they are durable, which by definition means they are not easy to put holes in.
Steve
mudpad is offline
Old 10-28-2013, 08:25 PM   #16
mudpad's Avatar
You are using water, right?
Steve
mudpad is offline
Old 10-28-2013, 08:39 PM   #17
GC/carpenter
Californiadecks's Avatar
Rewards Points: 5,828
Just make sure you don't apply water after you have drilled for awhile. You must apply the water at the start of the drilling process, or you will ruin an expensive bit.
Californiadecks is online now
Old 10-28-2013, 08:59 PM   #18
rustyjames's Avatar
Sounds like we're drilling for dowels and if it's that many holes gang drilling is the way to go. I agree with mudpad, a company that specializes in that will save you money, time and heartburn.
The Following User Says Thank You to rustyjames For This Useful Post:
Old 10-28-2013, 10:44 PM   #19
Trade: Artisan
I'm pretty sure the Engineer will be happy cutting thru all that rebar
Old 10-28-2013, 10:49 PM   #20
Fire up the BBQ
griz's Avatar
Rewards Points: 342
Is this by chance a tensioned slab?
That is a lot of rebar to cut....
Sub it out....after you check w/an Engineer....
griz is online now
Seven-Delta-FortyOne (10-28-2013)
Concrete Coring & Cutting Equipment, Texas takeoffs Contractor Swap 0 07-17-2012 10:50 AM
Scanning / Coring holes in 8" slab for 3-6" sleeves scwalther Low Voltage 4 05-28-2011 08:30 AM
advice needed for coring concrete overhead rshackleford Electrical 66 01-20-2011 06:51 PM
Cutting, Coring, grinding and polishing. CutCoreGrind Introductions 3 04-20-2009 08:46 PM
52 inch Lap Splice for 2 #5 Rebars in 8 inch Block?! TWOM JDuran Masonry 21 07-07-2008 12:20 PM
