Conditioned Area
Old 09-22-2006, 03:21 PM   #1
stangit92's Avatar
Trade: roofing & siding
Conditioned Area
Got into and intreasting conversation with a home owner here in Houston, Tx and was curious about other contractors thoughts.
Basically the O/H got into a conversation with me about a uncle of his who lives out in florida some where, and how they are now installing this type of foam insulation on all the framing and under decking of the roof to create a conditioned zone.
well so I was some what intreasted in the applications and products, so I mentioned it to a good A/C buddy of mine who, in end replied with how it will "rought off your roof and sheathing. mentioned also how the radiant barrier paint, basically the does the same thing and they had problems with that as well as it trapped moisture and created mold or mildew"....
So im just intreasted what ya'lls idea would be on this ..
stangit92 is offline
Old 09-22-2006, 03:49 PM   #2
My custom title
Brushslingers's Avatar
Rewards Points: 1,000
Re: Conditioned Area
House has to breathe, really.. i've sealed up footer boards to keep bugs out, etc... but sealing a house airtight is bad. You can kill a rat by leaving cola in a dish, they can't burp so they blow thier insides... same deal as a house... well sorta, in a weird way.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 09-22-2006, 04:09 PM   #3
mdshunk's Avatar
Rewards Points: 2,002
If you feel like you must create a vivarium or terrarium out of your house (that is literally what those urethane foamed houses turn into), an air to air heat exchanger is an ABSOLUTE MUST to maintin the indoor air quality. If the underside of the sheathing is foamed up against, you need to use that scrim type stuff under the shingles so that the sheathing can have and effluence path from above instead of it's more typical route below.
mdshunk is offline
Old 09-22-2006, 06:00 PM   #4
stangit92's Avatar
Yeah from what this guy mentioned to me about the foam it almost seemed to good to be true. (at least in the humid Texas areas)
oh well I guess he's just gunna have to be stuck with his $1800 a summer month electric bill
Old 09-22-2006, 06:09 PM   #5
Teetorbilt's Avatar
Rewards Points: 2,000
I'm beginning to see it more often now that energy costs are going up.
In conditioned space building you do not insulate the ceilings. Air transfer take place through the penetrations.
Albert Einstein
Teetorbilt is offline
Old 09-22-2006, 08:00 PM   #6
stangit92's Avatar
its a 5200 sqft 2 story house. with a gentleman in his 350 to 400 lb range that likes to sleep with the a/c down to 68 at night.
what penetrations are you talking about. I believe most reviews on the foam process say to block all attic vents. I also contacted Elk to see if there would be any warrenty issues reguarding the foam or elastomeric type of radiant barrier applications.
Old 09-22-2006, 08:43 PM   #7
Teetorbilt's Avatar
Let me preface this by saying that this is not my area of expertise BUT I was considering getting into the sprayfoam business a few years ago and did a lot of reading on the concept.
What THEY say is that there is enough transfer through ceiling penetrations (can lights, bath fans, ceiling light/fan boxes, et.al.) to prevent excessive accumulation of moisture in the attic space.
You can learn more here: http://www.buildingscience.com/
Albert Einstein
Old 09-22-2006, 08:46 PM   #8
Tscarborough's Avatar
Rewards Points: 1,406
Foaming your house turns it into a snake enclosure?!
Tscarborough is offline
Old 09-22-2006, 08:59 PM   #9
stangit92's Avatar
or a small return air ....
but then that still doesnt change the fact sheathing still wont be able to breath?? correct which would cause the rot...
Siding & Windows Sales needed - Chicago area - NO SALES EXPERIENCE Grumpy Help Wanted or Looking For Work 4 05-26-2009 02:51 PM
Proposals...... AAPaint Painting & Finish Work 3 08-25-2007 08:47 AM
Upstate NY area in need of contractors... Sellncars Remodeling 4 08-12-2006 09:45 AM
Anyone in the Tacoma WA Area skatchmo Marketing & Sales 2 11-23-2005 02:40 PM
