Concrete Stilt Home Construction - Online Resources
Old 04-13-2011, 10:32 PM   #1
Bomb Dog's Avatar
Trade: Developer - General Contractor
I am trying to find an online resource for concrete stilt home construction - specifically the type of construction employed in coastal areas.
This is a long shot, but I was wondering if anyone on here has had any experience working on or building one of these types of structures.
Bomb Dog is offline
Old 04-13-2011, 11:49 PM   #2
Bweikel's Avatar
Trade: Carpenter/gc
Rewards Points: 250
Re: Concrete Stilt Home Construction - Online Resources
Built a couple wood stilt (pilon)homes in south and north Florida not sure if I can help but I can try. What are wondering about?
Reality is only an illusion that occurs due to lack of alcohol.
Bweikel is offline
Old 04-13-2011, 11:51 PM   #3
Bomb Dog's Avatar
Has to be concrete - Monroe County as well - very strict.
Bomb Dog is offline
Old 04-14-2011, 12:01 AM   #4
Bweikel's Avatar
Trade: Carpenter/gc
Rewards Points: 250
Sorry never built that far south love it down there though.
Bweikel is offline
Old 04-14-2011, 03:06 AM   #5
maninthesea's Avatar
Trade: High Pressure Air
Rewards Points: 30
Over here your house and roof must be concrete or no insurance(no loan). There are a few built on stilts here becuase they are in a flood plane. Whats the questions maybe I could ask around for you.
Cheers Jim
maninthesea is offline
Old 04-14-2011, 11:10 AM   #6
ziemer's Avatar
Trade: General & Design
Rewards Points: 27
What info are you looking for? Are you bidding a project? How far along are the plans? Are the walls CMU or poured in place? What is the roof? Concrete also?
The few I've seen, are damn near 100% concrete. Even the roof system can be poured in place concrete now.
ziemer is offline
Old 04-14-2011, 12:42 PM   #7
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,890
After Katrina, with the 28' storm surge, only concrete structures along the coast that really survived or were capable of being made usable economically were concrete or masonry. The stilt homes on wood piles were gone and for some reason the piles snapped at about 6-7' above ground level. The steel structures were also gone and the twisted/bent piles were left. The concrete piles were tilted a couple of feet and the houses were usually gone.
The surviving homes were concrete or reinforced masonry with very strong rectangular piers (only in the direction perpendicular to the coast or anticipated surge) since the surge is both in AND out. They were on spread footings about 6' deep. Between the piers were masonry "blow-out" walls (6" or 8" unreinforced block non-bearing) perpendicular to the coast that housed the garages, workshops, dens and T.V. rooms. The blow-out walls were important since they were gone when the surge came in and the basic first floor level did not pick up all of the surge load because of the blow-out walls. The upper floors survived and were partially/lightly reinforced concrete masonry and just needed washing and spraying after the carpet was ripped up.
I saw a few new homes being built just after Katrina in a similar manner.
Dick
concretemasonry is online now
Old 04-14-2011, 03:50 PM   #8
Bomb Dog's Avatar
I am trying to see what info exists on this type of construction outside of the few contractors in South Florida licensed to build these types of homes. From what I can tell, there is not much out there that relates specifically to concrete stilt homes of the Keys variety (CBS - Concrete Block Stucco).
In the Florida Keys most stilt homes are poured concrete piling with a poured concrete second floor, block exterior walls, and a beefed up truss roof (per the new hurricane codes enacted after 2004). You rarely see poured concrete roofs anymore, as they always fall victim to the climate.
That is exactly how it works in the Keys. In most cases breakaway walls are the only way you can have first floor living quarters. Some homes that were built 6" to a foot lower than others have different flood codes and are ineligible for any type of first floor.
Bomb Dog is offline
Old 04-14-2011, 04:05 PM   #9
General Contractor
Willie T's Avatar
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Rewards Points: 12
Originally Posted by Bomb Dog View Post
..... specifically to concrete stilt homes of the Keys variety (CBS - Concrete Block Stucco).....
Pssst!..... You might want to check on that definition.
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is offline
Old 04-14-2011, 04:10 PM   #10
If you build in the areas that are subject to storms, you can get 40-60% insurance discounts just by doing son simple things like providing anchors for the stronger garage doors and making the gable ends of the roofing system stronger for lateral loads, since openings and wind getting unber the roof leads to the roof damage and also to the personal property damage. The codes do not address this effect because they are prescriptive and easy to administer.
Blow-out walls are great along costs where the general direction of a surge is known and they are great additional bonus shear walls if the surge direction is close to being straight from the planned direction. Otherwise, they just blow out and the rest of the structure acts as it designed to.
Dick
Old 04-15-2011, 05:32 AM   #11
Florida GC
olligator's Avatar
Rewards Points: 250
LOL! Yeah we used to get insurance discounts for these storm-prep things down here in South Florida but all the insurance cos. re-negged on the deal and have continued to jack up the rates every year. Ooops! Your roof is older than 10yo so replace it and pay our higher rate or we drop you. Have a nice day! Sincerely, your insurance company.
I guess the one redeeming feature in the keys is that you don't have to go down too far to get to solid limestone for those poured piles.
______________
If you're not a Gator, you're Gatorbait!
olligator is offline
If you're not on Facebook, you should be. Sir Mixalot Marketing & Sales 1851 09-27-2016 11:09 PM
Concrete Company delivered junk concrete. How best to pursue? marcomjl Concrete & Paving 47 06-03-2014 10:17 PM
Home construction rises in January AmeliaP General Discussion 3 02-19-2011 09:33 AM
Home Construction Using Wood on Lot wilyum Construction 24 07-02-2009 01:41 AM
What is everyone running for Fiber in new home Construction? voiceguy Low Voltage 9 04-09-2008 05:20 PM
