Concrete Repair
Old 02-09-2018, 07:32 PM   #1
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 410
Concrete Repair
This is at a local gym that I’ve been to a few times and some friends will be helping the owner repair it tomorrow hopefully.
Dropping barbells and other things on the floor is causing the previous work to crack up.
What you’re looking at is about 12” wide and 1/4”-3/8” deep that will need to be repaired. Once they bust up the rest of the loose stuff, what product should be used to fill back in?
Xtrememtnbiker is online now
Old 02-09-2018, 07:38 PM   #2
builditguy's Avatar
Rewards Points: 226
Re: Concrete Repair
Feather patch. Not sure if the brand name, but different areas will call it something different.
Find it in the flooring section. Should be anywhere that sells flooring. Can be troweled to a “feather edge.”
Up to 1/2” thick. Dries in about 2 hours.
builditguy is online now
Old 02-09-2018, 08:50 PM   #3
rustyjames's Avatar
Rewards Points: 1,468
Re: Concrete Repair
Ardex makes some of the best patching/topping products, but not if they're going to keep dropping the barbells on it .
rustyjames is online now
Old 02-09-2018, 09:00 PM   #4
Rewards Points: 410
Re: Concrete Repair
I'm aware of those sorts of products. But it's in a gym and they will continue to drop barbells and things on it. I assume just a basic feather patch wouldn't hold up right?
Yeah, that's why I'm here. Hope somebody has a good suggestion.
Old 02-09-2018, 09:31 PM   #5
tjbnwi's Avatar
Rewards Points: 1,824
Re: Concrete Repair
Insert a piece of QSWO.
tjbnwi is online now
Old 02-09-2018, 09:36 PM   #6
rustyjames's Avatar
Re: Concrete Repair
Top the floor with sheet steel plates. I don't think any patch is going to hold up to repeated dropping of the weights.
Old 02-09-2018, 10:08 PM   #7
Rewards Points: 410
Re: Concrete Repair
Glued down? How would you account for an uneven substrate?
Old 02-09-2018, 10:27 PM   #8
Railman's Avatar
Trade: Railing
Rewards Points: 267
Re: Concrete Repair
http://www.lyonsmanufacturing.com/products.html
I did over 3,700 sq ft skim over very badly spaulded concrete floor using their patching compound. We ran forklifts, steel wheeled carts, fully loaded #5,000 pallet jacks, moved moved #6,000 machinery over it for a period of 10 years. We did a good prep for it, & never had a single failure anywhere on the floor. It's a little tricky getting a slick finish on it on large areas, but not for small patches.
Basically, you clean area, prime concrete with bonder, & apply topping.
We used the Patchcrete product, but it appears they have added some others that may work better for your application.
Railman is offline
The Following User Says Thank You to Railman For This Useful Post:
Xtrememtnbiker (02-09-2018)
Old 02-09-2018, 11:28 PM   #9
Rewards Points: 410
Re: Concrete Repair
Probably not available on the shelf at the local hardware store though...
Old 02-10-2018, 05:57 PM   #10
sparehair's Avatar
Trade: Painting, flooring
Rewards Points: 1,010
Re: Concrete Repair
A wheel is not a hammer.
sparehair is online now
The Following User Says Thank You to sparehair For This Useful Post:
rustyjames (02-10-2018)
Old 02-10-2018, 07:38 PM   #11
Rewards Points: 410
Re: Concrete Repair
They did the repair today with SLC. They pretty much know it won't hold up, but it at least buys some time. Next time around they would in advance plan farther ahead and maybe have a more ideal solution ready. Thanks for the help guys.
Old 02-10-2018, 08:23 PM   #12
Quality5280's Avatar
Trade: Hardscape ,Landscape and Roll off Containers
Rewards Points: 176
Re: Concrete Repair
I would get with a decorative concrete supplier
They should have some 6-7000psi patch
Me personally I would grind it down and add a piece of 1/4 plate
The reason I brought up the patch is we went to a class one of our suppliers had going and they were talking about the strengths of some of there products (you’d be surprised)
But you’d have to figure out the force a dumbbell has probably similar to hitting it with a sledge hammer
Steel plate
Sent from my iPhone using Tapatalk Pro
Quality5280 is offline
Old 02-12-2018, 09:44 AM   #13
This space for lease
RangoWA's Avatar
Trade: Tool jocky
Rewards Points: 3,378
Re: Concrete Repair
They need to put dense mats down where barbells are used. If they can't afford the fancy ones the cow mats work great. I layed some down for a crossfit guy, about an inch thick but made of recycled tires, very tough to cut!
RangoWA is offline
foundation repair question ctcarpenter Masonry 26 06-25-2012 06:25 PM
I need some input on a small concrete repair please..... Richiebro73 Masonry 21 05-23-2012 10:33 PM
Concrete Repair Contractors needed ASAP In Raleigh, NC. 4thGeneration Help Wanted or Looking For Work 0 10-11-2009 07:02 PM
