Concrete Pads For Wood Deck Stair Stringers
Old 12-11-2008, 01:51 AM   #1
Bodger's Avatar
I am building a deck with stairs on three sides, two treads, three risers. Stringers are pressure treated, I usually pour a pad about a foot deep and a foot wide and set in anchor bolts and bolt down pressure treated sills for the stringers to sit on. Always seems like a lot of concrete and re-bar and forming and all that for stringers that aren't supporting a huge amount of weight.
Does anyone know of a simpler way to do this? I have about 45 line feet of stairs on this one, and access sucks for pumper and truck.
Ever tried just forming a square box for each stringer end to sit on? Or would they all settle at different depths and such.
Probably just looking for a short cut that will lead to trouble.
Bodger is offline
Old 12-11-2008, 07:44 AM   #2
Deck Designer/Builder
DecksEtc's Avatar
Re: Concrete Pads For Wood Deck Stair Stringers
If you do a proper base prep there's nothing wrong with using patio stones.
DecksEtc is offline
Old 12-11-2008, 07:47 AM   #3
genecarp's Avatar
SECOND THAT
genecarp is offline
Old 12-11-2008, 08:02 AM   #4
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
Adjust the way you frame the steps-
Cut-in to the bottom riser for a 2x6 vertically- and a 2x4 at the bottom horizontally if you think you need it...
The idea is to make this a "unit" that is tied together, so you don't get the up-n-down that you might otherwise get with lots of small stringers.
Then, pavers, patio block, slate... whatever you fancy. Oh, and maybe list that as a separate option (xx for this *** for this, etc.).
HTH,
~Matt
BreyerConstruct is offline
Old 12-11-2008, 08:43 AM   #5
Bodger's Avatar
What would be the best base prep method? Level out an area and compact some good sand?
Avoiding my usual concrete pad on this one will be a huge blessing.
Bodger is offline
Old 12-11-2008, 08:48 AM   #6
DecksEtc's Avatar
I'll dig down 6-8 inches, fill with limestone screenings then level the patio stones. The screenings make it so much easier to level the patio stones.
Also, unless the steps are leading to a walkway, I set the patio stones so that they're hidden by the steps/skirting after I'm done.
DecksEtc is offline
Old 12-11-2008, 09:19 AM   #7
Bodger's Avatar
Thanks! Limestone screenings and patio stones it shall be. I have good undisturbed soil where the stringers will end so I'm not too worried about settling.
Thanks again to all for the good advice.
Bodger is offline
Old 12-11-2008, 09:59 AM   #8
DecksEtc's Avatar
No problem.
Glad I could help.
DecksEtc is offline
Old 12-12-2008, 03:26 PM   #9
rotarex's Avatar
cement pomp Truck what you pouring a house foundation haha, jks jks, i use my http://www.fiskars.com/webapp/wcs/st...tegoryId=12735
the best fastest digger i have $65 homedepot. and pre mix cement if not patio slab $2 8"x8" homedepot
Custom Decks
Custom aquarium all salt water
Renovation
next on my list............planting trees for all those material i used
rotarex is offline
Old 12-12-2008, 05:33 PM   #10
Bodger's Avatar
Naw, just enough concrete and bad site access to make it almost impossible to hump in bags of 'crete, or get a load of 50/50 dropped off and do the Portland mix thing in my own mixer.
Thanks for the info.
Bodger is offline
Old 12-12-2008, 05:59 PM   #11
DecksEtc's Avatar
Dude, those things are knuckle busters. You need to get yourself a Bobcat
DecksEtc is offline
Old 12-12-2008, 06:35 PM   #12
rotarex's Avatar
my bobcat has only seen 3 decks, the damage is sooo not worth it, its mostly used in interlocking
Custom Decks
Renovation
rotarex is offline
Old 12-12-2008, 08:55 PM   #13
Bodger's Avatar
....I wish I had a Bobcat. For fun if nothing else.
Bodger is offline
exposed deck w/EPDM on concrete (no pitch) kellry27 Decks & Fencing 0 09-22-2008 09:03 PM
Advice - concrete Pool Deck coping ejleonard Masonry 4 06-17-2008 05:18 PM
Deck Height Over Concrete Joeyyungrocks Decks & Fencing 11 04-19-2008 07:00 AM
Patching penetrations in concrete roof deck geecee Concrete & Paving 1 03-04-2008 03:34 PM
Deck stair stringers?? bujaly Decks & Fencing 29 08-13-2007 12:05 AM
