Concrete Filled Steel Lally Column
I am presently putting up a large stick frame building which requires the installation of some triple LVL beams. These beams are supported by concrete filled steel lally columns that need to be cut to length. I have no experience cutting a concrete filled column. What is the best way to assure a clean square end?
Trade: Carpenter/GC
Re: Concrete Filled Steel Lally Column
There are pipe type cutters you can get, or cut through metal with sawzall blade and whack it. Do it carefully so you don't bash out too much of concrete filler.
If you did take of too much cement fill it back in. |
I like Green things
The best way to cut them, is post an intro, tell us about your self, and then ask away.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana Warner Remodeling Facebook |
| The Following User Says Thank You to WarnerConstInc. For This Useful Post: | Meetre (11-03-2009) |
Trade: carpentry
giant pipe cutter like plumbers use to cut copper just bigger
Cut off saw w/diamond blade would do it.
| The Following User Says Thank You to tgeb For This Useful Post: | Tom R (11-04-2009) |
solar guy
Trade: solar contracting
Re: Concrete Filled Steel Lally Column |
Trade: Pretty much anything with wood
I always end up using a sawzall to cut through the steel and then a grinder to clean up the cement and or fine tune the steel square. I've used the large pipe cutter and that is definitely the best way to go. Don't forget to get the large heavy duty lally plates for the extra width of the 5 1/4" LVL's.
You'd be surprised how many people don't realize that a diamond blade will cut steel.
Trade: Outdoor D/B
Yeah, I have a Makita 12" electric cut-off saw that works like a charm for stuff like that. After all, they're designed to cut through concrete with re-bar.
Where's my coffee?
Trade: General Contracting - A/V Integration
My back aches just from reading this.
![]() The cutting method depends on your on-site tools and budget... all above will work, some better than others. Personally, I'd be headed to the rental store for a diamond in the rough! Dave
I never give up!
#13 | |
DavidC
Re: Concrete Filled Steel Lally ColumnQuote:
Good Luck Dave
www.CookContractingLLC.com |
Oh, - - I forgot to mention, - - if I need a really perfect cut on a lally column, - - I put that 12" diamond blade in my 14" (Makita) metal-cutting chop saw . . .
#15 | |
Trade: Mason
Construction Philosopher
Trade: Builder
What's with the newbies digging up old threads?!
A little Learning is a dang'rous Thing; Drink deep, or taste not the Pierian Spring: There shallow Draughts intoxicate the Brain, And drinking largely sobers us again. -Alexander Pope |
#18 |
Trade: Mason
#19 | |
David Festa
Trade: Framing Contractor
When I went out on my own I said to myself “self there’s got to be a better way”. So I bought a 5”? pipe cutter from a flea market, dumb idea. Total peace of crap, wouldn’t stay on track So I bought one used one from a pawn shop, almost perfect condition. Worked great till one of my guys tried cutting drive shaft with it, back to a circular saw I went and never looked back
Addition Contractor Bayville Home Addition Monmouth Beach NJ Contractor Jackson NJ “Photography is not art, It’s just a Xerox of what just happened” |
#20 |
| Installing a Lally Column | BCFBeacon | Construction | 22 | 03-13-2009 08:54 PM |
| ??? Whats the best way to spread the news about your company? | jmgrahamjr | Marketing & Sales | 21 | 06-24-2008 04:46 AM |
| Replacing lally column | tomk15 | Framing | 14 | 03-06-2008 07:30 PM |
| Remove Lally Column? | zslavin | Construction Picture Post | 7 | 12-05-2007 10:50 PM |
| Hollow steel lally or concrete filled? | kusa24 | Construction | 4 | 04-23-2006 08:49 AM |
