Collar Beam Height Qusetion
Old 12-19-2007, 05:27 PM   #1
kbs2244's Avatar
Trade: general
Been a lurker, but now I need help.
The basic outline of the problem is a built on garage addition. What the R. E. guys call a 2 story Colonial with a Side Loader Garage. That means the gable end of the garage faces the street.
Existing garage is 24 feet top plate to top plate with 5 feet from the bottom of the joists to the top of the ridge board.
There is a 4 foot “Kick Out” on the street side that expands the inside dimension for the original owners boat.
This done with a support wall with a garage door type support across the span at the 24 foot point and with lean to rafters out to outside wall at the 28 foot point.
The end result is a “Cape Cod” look with the back eave lower then the front, “door side” of the garage, and a indoor, dry wall boxed, beam across the span.
The homeowner wants to add on 24 feet of width to the garage with the same depth.
But he wants more inside height.
Current construction is pretty common. 2x6 joists top plate to top plate and 2x6 rafters with 1x6 collar joists every third rafter.
So, can I raise the real joists from the top plates up the rafters to some point?
If so, how far with out hurting the structural requirements?
The homeowner wants as much finished inside height as he can get, but he understands the idea of the forces involved and doesn’t want to build a problem.
He is OK with the need for the support wall at the 24 foot point and the “real” wall farther out.
And then, of course, the next step is to move back into the existing garage and modify the existing joists and rafters so he has the same “dome” ceiling in the whole garage.
kbs2244 is offline
Beam Specs ophnurse Framing 19 10-02-2007 08:21 AM
flitch beam installation kweber General Discussion 4 02-04-2007 11:43 AM
Main beam sagging 1/2 inch? AllGoNoShow Construction 10 10-12-2006 08:20 PM
California Building Codes for Chimney Height vawn Construction 5 05-22-2006 08:49 AM
deck beam sizing and post spacing? diyerforever Decks & Fencing 5 05-10-2006 10:58 PM
