Cement Damage
Old 09-17-2007, 06:34 AM   #1
cementman42's Avatar
Trade: lets make it work
Cement Damage
I have been doing small cement repair work for a few years, and I have started a small cement business. My brother lives in the city and someone is putting (he thinks it is his neighbor) something on his sidewalk and causing deep pockmarks in the cement. Over period of about six months there has been a lot of damage done on two or three sidewalk blocks. No, this is not normal wear and tear. I am thinking it is some kind of acid. He checks the sidewalk on dry days to see it there are any wet spots on the cement (from acid or something else being poured on it), but so far he has not seen any liquids on the sidewalk cement.
what would cause this? Any help would be greaty appreciated.
Thank You for any help in this matter.
cementman42 is offline
Old 09-17-2007, 08:10 AM   #2
concretemasonry's Avatar
Trade: Masonry consultant
Re: Cement Damage
Where is the sidewalk? - City, climate
How old is the concrete?
Pictures could help.
Do they look like "popouts"?
Dick
concretemasonry is offline
Old 09-17-2007, 12:18 PM   #3
Re: Cement Damage
Yes, it looks like popouts, but there are too many at one time. I'll try to upload a picture. The city is Philadelphia Pennsylvania. the popouts are near the curb, but no on the curb. None of my brother neighbors have this problem and the cement is the same for all of the other row homes. The reason he suspects the neighbor is because the neighbor has done damge to his brick wall by causing big chips in the bricks in too many places to be a natural chip and some chips too big to be natural break off
I tried to send a photo. But it did not come up on this Message board.
Old 09-17-2007, 12:27 PM   #4
Re: Cement Damage
Acid will not cause deep damage or damage to a well defined area.
Acid does not damage brick or cause chips.
Dick
Old 09-17-2007, 12:32 PM   #5
Luke Lukens
Luke's Avatar
Trade: General Remodeling Contractor
Re: Cement Damage
This might be a stretch but here in Reading, many of the older concrete sidewalks were installed over a crushed iron ore material instead of stone and over time, the chemical effect of the metals and the concrete eventually bleed through to the top of the walks. I don't know if the walks you are talking about are that old or newer installations but I thought I'd throw it out there. I'm talking about walks that are at least probably fifty years old now. This isn't Gary Heidnick's old home is it........?
Luke is offline
Old 09-17-2007, 07:25 PM   #6
finlander's Avatar
Trade: General Contractor Residential/Commercial
Re: Cement Damage
It is possible that the cement in question was never air-entrained.
All exterior slabs should have 6% air installed at the batch plant. It is possible that the air was missed on the batch in front of his house.
finlander is offline
Old 09-17-2007, 07:48 PM   #7
Re: Cement Damage
Most of the suggestions will give a general area of failure and not lo,ited to a very small area like a pop-out.
It could be the aggregates used that has shale, chert or other expansive particles.
many jurisdictions require different concrete mixes and aggregates for critical with with more severed exposures like gutters than they do for cosmetic surfaces like sidewalks.
A photo would probably tell the story.
Dick
Old 09-17-2007, 08:05 PM   #8
Re: Cement Damage
I tried to send a photo. I must have done something wrong.
Can someone walk me through sending a photo to this sight?
Old 09-17-2007, 08:17 PM   #9
Mod / ArchiBuilder
Cole's Avatar
Re: Cement Damage
How to post a photo:
http://www.contractortalk.com/f45/how-attach-photo-post-6001/
Cole is offline
Old 09-17-2007, 10:49 PM   #10
house bldr's Avatar
Trade: general contractor
Re: Cement Damage
Did this happen during winter months? Salt on concrete can cause pock marks especially on newer concrete.
house bldr is offline
Old 09-17-2007, 11:07 PM   #11
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & welding
Send a message via AIM to Michaeljp86
Re: Cement Damage
I dont think this is the problem but a torch will make pieces pop out. Hold a torch on it and a chunk will come flying in your face.
I would say it could be from salt to.
Michaeljp86 is offline
Old 09-17-2007, 11:24 PM   #12
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Re: Cement Damage
Philidelphia - Definately winter rock salt, the brick wall, does he use a snow blower/thrower on that same walk and aim it at the wall?
Chris
Chris Johnson is offline
Old 09-18-2007, 01:29 AM   #13
Re: Cement Damage
I uploaded the picture and saw it in the message box that I pasted it into, but the picture did not show up in my thread
Old 09-18-2007, 05:50 AM   #14
Home Builders/Contractors
Metrojoebarbs's Avatar
Trade: Residential Home Builder/Contractor
Re: Cement Damage
I would bet salt from the roads. Thats why it's near the curbs.
Metrojoebarbs is offline
Old 09-18-2007, 08:48 AM   #15
Re: Cement Damage
Metrojoebarbs -
No damage to the curbs that can see more salt (especially in Philadelphia). - That should be a clue, unless the posted information is not accurate.
It really can't be a big problem since the poster does not even know if it is happening to 2 or 3 slabs (50% difference).
Dick
Old 09-18-2007, 11:10 PM   #16
EVIL GENIUS
Re: Cement Damage
Concrete is a animal all its own, anything can change it from being mixed right to the temperature when it was poured, how it was worked etc. Im sure we've all seen concrete look like it was poured yesterday and its 20 years old. Im sure weve all seen concrete 3 years old already comming apart.
That section could be softer then the sidewalk 2 feet away because it was poured on a different day or even if the sun was beating down on that piece it could make it more susceptible to damage.
Old 09-18-2007, 11:22 PM   #17
Re: Cement Damage
Originally Posted by concretemasonry View Post
Metrojoebarbs -
Dick,
What I'm picturing is pop marks as when a HO runs out of calcium and decides to use rock salt for that winter because it's cheaper. We all know what happens then. The curbs will never be effected because they are usually vertical as upposed to the sidewalks were the moisture and salt can go to town on the flats. I was thinking rock salt mixing with the snow and then being pushed up by the plows. I think he said close to the curbs.
Either way... 90lb jack and a short load charge and you out.
Fiber Cement almost same cost as Vinyl? MKECONTRACTOR Windows, Siding and Doors 17 12-20-2008 06:34 PM
Transitioning drywall with cement board Lone Wrencher Drywall 19 03-02-2008 07:05 AM
Morter Mixer Vs Cement Mixer personalt Masonry 6 07-29-2007 09:16 PM
drywall mud over cement? mudgirl Construction 7 07-20-2007 08:27 PM
Wondering if I can mix a color into cement carlspackler Masonry 15 09-06-2006 11:52 AM
