Ceiling Tiles Smell
Old 07-04-2011, 09:16 PM   #1
General Contractor
Jaketoo's Avatar
Rewards Points: 81
Ceiling Tiles Smell
I installed Armstrong 1205 suspended ceiling tiles in a basement 2 weeks ago. The customer can't stand the smell. They have aired out the basement for several days and the smell is still strong. They said they may want me to return the panels. I am meeting with them tomorrow. Anyone run into this problem?
Thanks
Jaketoo is offline
Old 07-04-2011, 09:47 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 478
Re: Ceiling Tiles Smell
If I recall correctly, 50/50 odds, these panels are made to combat odor & mildew. You'll need to get air movement through there to alleviate the odor. Not much different than oil paint or some floor finishes.
griz is online now
Old 07-04-2011, 10:46 PM   #3
General Contractor
Jaketoo's Avatar
Rewards Points: 81
Thanks for the reply Griz. I am planning to bring some fans with me tomorrow. I will also remove some tiles, and open the 3 tiny windows and bulked door.
Jaketoo is offline
Old 07-05-2011, 06:39 AM   #4
PRO
BrandConst's Avatar
Rewards Points: 1,000
Either air it out or rent an ozone machine to clear out the odor. Just remember that nobody can be around a room that's being ozoned.
BrandConst is offline
Old 07-05-2011, 09:37 PM   #5
General Contractor
Jaketoo's Avatar
Rewards Points: 81
I basically took out 3 rows of tile . One on either end, and one towards the middle near the bulked door. I used 6 fans. 3 small ones up in the ceiling, and 3 large ones on the floor pointing up a little. The air is funneling out of the bulked nice. I also sponge mopped the floor to get any dust the vacuum missed.
It might have just been in my mind, but as I opened up the ceiling and got the air flowing, I smelled a strong odor, and after being in the basement for a few hours I left with a headache.
The homeowner will run the fans all day everyday, and I will check back with them at the end of the week to see if this solves the problem.
I'm not familiar with ozone machines. I will do an internet search, and take a look.
Thank you.
Jaketoo is offline
Old 07-21-2011, 06:04 PM   #6
oakshadows's Avatar
Trade: Homes
[B POSSIBLE PROBLEM[/B]
"How many people remember what puke smells like? Well, puke has a distinctive odor, and it’s actually called butyric acid, which comes from the fermentation of starch. Well, butyric acid is emitted from ceiling tiles that are made from cellulose and a starch binder. When the humidity goes above 80 or 85 percent, the butyric acid is emitted, and you have the odor of vomit."
source:
http://www.greenbuildingadvisor.com/...cience-podcast
See also the thread at:
How do you get rid of armstrong ceiling tile odors?
http://wiki.answers.com/Q/Discuss:Ho...#ixzz1SmYMJsxg
POSSIBLE SOLUTION
We had same problem with newly installed Armstrong ceiling tiles. Here is what followed.
All ceiling tiles were removed from basement, but the odor remained.
Large HEPA/activated charcoal air scrubbers did not work.
Homeowner then hired a professional remediation group to do the following:
1. Clean carpet. [Helped to remove ceiling tile dust, fragments and and residue from the carpet, which reduced the smell and presence butryic acid in the room.]
2. Ozone. [Now in process with all people and pets out of house.]
3. Dry vapor with VaporShark. [To be done after ozone.]
4. Crystal odor counteractants [To be placed on carpet for a period of time after the VaporShark treatment has been completed.]
There is no guarantee this will work, but we are optimistic.
ALTERNATIVE CEILING TILES
Once the odor is gone, we will install new tiles; ones made without starch binder. Any suggestions anyone?
oakshadows is offline
The Following User Says Thank You to oakshadows For This Useful Post:
Miss Brown (09-15-2011)
Old 07-22-2011, 02:43 PM   #7
3bar's Avatar
Trade: carpenter
Rewards Points: 460
how common is cellulose and starch used in ceiling tile?
3bar is offline
Old 07-23-2011, 04:41 PM   #8
The Ultimate Wire Hider
tedanderson's Avatar
Trade: A/V & Home Theater Installation
Rewards Points: 2,116
I've had this problem also.
The only way I was able to solve it was to remove the tiles and sit them outside for a few days on wire rack shelves. I stood them on the end so that I could stack more of them on the shelves while allowing fresh air to flow between them without them touching each other.
As a preventative measure, I also painted the back side of the tiles to seal off the unfinished surface. When everything was reinstalled, the only offensive odor was the smell of new latex paint.
tedanderson is offline
Old 07-24-2011, 12:49 AM   #9
3bar's Avatar
Trade: carpenter
Rewards Points: 460
tell us the brand so the rest of us can avoid the same scenario.
3bar is offline
Old 07-24-2011, 07:45 AM   #10
I don't remember the brand but I remember that we got these in lieu of the Armstrong tiles because they were much cheaper.
Old 09-13-2011, 11:26 AM   #11
oakshadows's Avatar
Trade: Homes
UPDATE
1. New Ceiling Tiles Installed
The offensive Armstrong ceiling tiles (with the pervasive butyric acid smell) were replaced with new ceiling tiles made from entirely different materials. http://newceilingtiles.com/ This was a good result.
2. Removal of Butyric Acid Smell from Living Area
Steam Cleaning of Carpet. The most effective step in the removal of the butyric acid smell from the living area was the steam cleaning of the carpet.
Ozone. On the other hand, the use of ozone to remove the butyric acid smell created a whole new set of problems in the treated living area: The creation of caronyls, which can be irritiating and even toxic.
Although ozone disappears quickly, what most people don't consider is that it is HIGHLY reactive with many materials in the home.
Ozone chemically reacts with furniture, fixture, and flooring surfaces to form a wide range of chemical by-products that are “oxidized products” known as carbonyls (mono and di-carbonyls), including formaldehyde, acetaldehyde, acrolein, and others.
This problem is magnified further if you use a fragrance in the home that emits terpenes or terpene alcohols (nice smelling chemicals found in plug-in and solid air fresheners), which are highly reactive with ozone and yield a lot of harmful oxidized products.
Hope this update is helpful to those interested.
Old 09-13-2011, 07:24 PM   #12
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
IMO, it's not the fiber, rather the binder. Fiber is fiber and fiber is filler. Binders are chems (glue here) and they outgass and that's what's usually the problem, especially when airflow is part of their job description. Walk into a new RV/camper and you'll get hit with the outgassing of the binder. Lighter materials mean more and more HD binder. Outgassing does decrease over time, so that can be a way to deal with it, sort of like drying/acclimating wood I'd imagine.
CO762 is offline
Ceiling Tiles and Baby Powder - Best Practice? ardalis Commercial Construction 9 03-24-2011 09:11 AM
Ceiling Tile Smell?????/ buildpinnacle Drywall 6 03-11-2011 08:45 AM
Painting acoustic ceiling tiles dereka1a Painting & Finish Work 8 05-24-2010 06:13 PM
Funny Craigslist ad for paint work... Splinter Painting & Finish Work 14 06-10-2009 05:43 AM
Storage Limits for Suspended Ceiling Tiles FlashJT General Discussion 5 01-29-2008 07:18 PM
