Ceiling Tile
Old 01-19-2007, 07:16 PM   #1
abonear's Avatar
Trade: Handyman
Ceiling Tile
Hi Everyone.
I was'nt to sure where to post this..so If It's wrong I apologize.
I was wondering if anyone has installed ceramic tile on the ceiling.
We have a customer that he wants to tile up. He already has the tile around the bathtub..now he wants to keep going up to the ceiling. We have never done that. We have seen bathrooms that
do have it in magazines but we have never done it. Is it the same as tiling around the tub?
You input is greatly appreciated.
Thanks
Alex
abonear is offline
Old 01-19-2007, 07:33 PM   #2
Teetorbilt's Avatar
Re: Ceiling Tile
How old is the original? Will you be able to match it? Match grout? Will he go for a tearout? I'm guessing not. The easiest way is to place a feature band above the existing tile and go up from there. With that you can change everything, tile size, color, grout..........
Albert Einstein
Teetorbilt is offline
Old 01-19-2007, 07:50 PM   #3
abonear's Avatar
Trade: Handyman
Re: Ceiling Tile
No he has the tile and the grout. It maches because he had bought
all of it together. He never got around to it...or who knows..but now
he wants us to continue going up all the way to the ceiling.
What I'm wondering how does the tile hold up, during the drying time
of the cement.
abonear is offline
Old 01-19-2007, 08:56 PM   #4
Repair/Remodeling Tech.
jproffer's Avatar
Trade: Repair and Remodeling Services
Re: Ceiling Tile
on the ceiling
up to the ceiling
Not trying to be a jacka$$, but which is it? ON the ceiling, or TO the ceiling.
If he wants it ON the ceiling, it can be done but there are alot of extra steps involved. At least there would be if I was doing it (for the record I've done alot of tile on floors and walls but never ON a ceiling, so take or leave my advice with that in mind). I would want to "prop" each tile in place until it was dried, which obviously would involve building several props. They may even have special thinset for inverted installation. I'm interested to see more responses on this.
Some of the tile guys will be along shortly, well maybe...by your title it sounds like normal accoustic ceiling tile, so if you're still able to edit that you may try "ceramic tile on ceiling" or something of that sort. You may also wish to ask a mod to move this to the ceramic forum where it will likely get more replies from the real pros, but I leave that to your discretion.
Jim P.
jproffer is offline
Old 01-19-2007, 09:07 PM   #5
GC / Remodeler
dshcontracting's Avatar
Trade: General Contractor/Remodeler
Send a message via AIM to dshcontracting
Re: Ceiling Tile
If you use a normal thinset, it will stick right on. We usually use a speed set so we don't have to wait as long. Thinset works a little better on sloped cielings. The suction the mortar or thinset creates holds them really well until they set. Just make sure you use the right notched trowel and get good even coverage. Know how when you stick a floor tile down, it takes a crowbar to let it release from the wet mortar? same thing on the cieling. You're probably thinking it'll be hard because wall tile slide down when wet, but think about it like a suction cup. They are easier to pull off while sliding then straight off. Just like working on a floor, except its above your head, so if you do make a mistake and get poor adhesion, you'll have a booboo on your head.
Dan
dshcontracting is offline
Old 01-19-2007, 10:13 PM   #6
Pearce Services's Avatar
Trade: Commercial Loading Dock and Door Contractor
Re: Ceiling Tile
Also cover the tub with plywood, and or canvas drop cloths, one or two may fall out overnight, and you do not want to chip anything.
Also if you try to line up the grout lines, the walls will need to be perfectly 90 degrees to each other or it is impossible without "staircasing", that is why most ceiling installations are on a 45 degree angle to the back wall.
Pearce Services is offline
Old 01-19-2007, 11:38 PM   #7
abonear's Avatar
Trade: Handyman
Re: Ceiling Tile
Yes...sorry...I was not specific...It is Ceramic tile.
Yes we have installed on floors many times. I was
wondering because of gravity..I would think it would
dificult to keep the tiles up.
Do you recommend any paticular thinset over another.
Is there one that drys faster than another ...just in
this paticular case because it is the ceiling.
Thanks in advance for the advise
abonear is offline
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
Sloped ceiling in a steam shower Eric K Remodeling 6 08-08-2007 06:16 PM
Got some design ideas for tile wainscoting? Mike Finley Ceramic & Stone Tile 2 05-09-2006 10:05 AM
Cutting Existing Tile. kpikul Remodeling 16 02-05-2006 12:30 AM
