Casement Windows
Old 09-12-2009, 12:17 PM   #1
hurtlocker
nailkiller1's Avatar
Trade: homebuilder remodeler carpenter
Casement Windows
In my area if there is a set of casement windows. It is assumed they will open inside out.
Is this the same in your areas and what is the theory.
Probably a dumb question?
nailkiller1 is online now
Old 09-12-2009, 12:37 PM   #2
Framer53's Avatar
Trade: Framing
Re: Casement Windows
You want the casements to open in and take up square footage??
Framer53 is offline
Old 09-12-2009, 12:47 PM   #3
Tom Struble's Avatar
Trade: siding
hmm yea thats what i would assume
i think the ones that open in are called french casements around here
Tom Struble is offline
Old 09-12-2009, 12:51 PM   #4
The old ones that open in are
a real problem to weather proof.
neolitic is offline
Old 09-12-2009, 01:33 PM   #5
hurtlocker
no a set of windows with the sides nearest to each other opening out(most common) vs a set opening sides furthest from each other opening out?
maybe someone could translate this for me
sorry for the confusion
Old 09-12-2009, 01:49 PM   #6
paul100's Avatar
Are you talking about the hinge location? If that is what you mean then with a set of twin casements we will put the hinges on the outside edges so that the windows closes to the meeting point between the two windows. I dont think we ever had a customer ask for the hinges to be at the middle.
paul100 is offline
Old 09-12-2009, 06:05 PM   #7
hurtlocker
yes hinge location why always that way
Old 09-13-2009, 09:33 AM   #8
HSConstruction's Avatar
I guess I you asked for a center hinge they could do it, but why?
Is there any reason you would want it like this
HSConstruction is offline
Old 09-13-2009, 09:50 AM   #9
hurtlocker
Why not is my question why is that the norm
Old 09-13-2009, 10:38 AM   #10
oldfrt's Avatar
I don't know if I'm reading this right, but hinge location is probably determined by the strongest point of the unit,which would be next to the nailing flange.
Does that answer your ?,nailkiller?
oldfrt is offline
Old 09-13-2009, 11:44 AM   #11
hurtlocker
forget it
Old 09-13-2009, 12:20 PM   #12
Meetre's Avatar
Casement windows are designed to "scoop" moving air into the building for ventilation. You should only have one side open at a time. They put the hinges on the outsides to give the hinge side of the unit more strength. Hope that helps.
Meetre is offline
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Windows XP Mode in Windows 7! gideond Technology 9 05-15-2009 12:34 AM
Finishing windows before installation??? nwksremodeler Windows, Siding and Doors 9 03-11-2009 08:32 PM
Labor Est. for swapping vinyl rep. windows to wood clad rep. windows? Tallguy1 Windows, Siding and Doors 6 02-10-2009 12:58 AM
need help with pella casement windows wayne3434 Construction 9 02-12-2007 06:28 PM
