Trade: CARPENTER
CARPENTRY - Threading Sash Weights In Double Bay Window
I need to know the correct procedure regarding the threading of cord through a sash weight for double bay windows.
can anyone help? |
#2 | |
Re: CARPENTRY - Threading Sash Weights In Double Bay WindowQuote:
the sash out of the jamb? And have you found the weight pocket covers?
Put your location in your profile! (Sorry....it seems there really are dumb questions) Last edited by neolitic; 10-11-2008 at 04:30 PM. |
Everyone i've seen is just a single knot through the loop in the weight. Nothing fancy like the boy scouts and sailors do. The rope always breaks before the knot would come loose. .. I generally get to the weight pocket by taking off the inside or outside trim. Not that i ever try to fix those old things but after the windows are replaced that pocket needs to be insulated. It also makes a nice chase for running romex when rewiring an old house.
Of course that was cotton rope they used back then which would bind itself on a single knot. If I was using anything with nylon or other synthetics, i think I'd do a couple of half hitches or a square knot.
Oddly enough, sash cord is the best
thing to use to replace...sash cord.
#6 | |
I got to get a picture of how they did brick stove and coal furnace chimneys here a hundred years ago. They generally wood framed a little angle shelf about 6 ft off the floor and then started laying bricks up from there. Sometimes 2 and 3 stories. Very scarey when you see one of these today and it still has something hooked up to it. Ok back to sash weights. i want to hear more. |
#7 | |
More often I put in a tensioned replacement jamb track. Anyway, there is a wooden cover near the bottom of the jamb usually held with a brass screw. Take it off and there is the weight pocket. Raise the sash so the weight is near the bottom and cut the cord. Yes they still make cotton cord, it's just treated with some new age coating. ETA: If you pull the casing usually it's just plaster and lands. You would have to break through.
Put your location in your profile! (Sorry....it seems there really are dumb questions) Last edited by neolitic; 10-11-2008 at 06:22 PM. |
#8 | |
Some nice old houses in Denver.
I like those old neighborhoods with the shingled gable painted ladies and granite slab side walks.
Trade: general contractor b license
Remove the stops and the parting bead. Remove the weight covers and be careful not to lose them. I usually like to sand the window sash a bit to remove paint build up. Now, here's the thing that is a pain. Sash chord likes to get stuck in the weight chase. If the old rope is still there coming out of the pulley above, I like to tape the new sash chord to the end of this and use it like a fish line. If there is no sash chord in there now, I put tape on the tip of the rope so the fray does not catch as easily going down, I try to curve the rope tip downwards a little and roll it in over the top of the pulley to try to get the rope started aimed downwards as it enters the cavity. Usually it gets stuck somewhere along the way but keep feeding a bunch in there anyway even if it is bundling up inside you can usually hook it with a coat hanger with a little bit of a hook on the end and pull it down. You can remove the casing as well, but that is often times not practical if the wood work is old and has a million coats of paint. It can be difficult to take it off without breaking it.
Ok, I'll ask this. I can buy a perfectly sized retro fit window that fits perfectly into that jamb for 150 bucks and pull the casing off and stuff that weight pocket full of insulation, both of which will seriosly cut down on the giraffs comming through the window. Why would I mess with fixing the old sashes and weights? The new window has about the same profile as the old sash so light and ventilation is the same and the only disadvantage is that they are probably not paintable although I've never persued something that might be paintable.
Now I like old and i like to preserve as much as possible but the old wall hung kitchen sinks go, the old coal furnaces go, and the old sashes go. Of course the rest of the window and the trims stay. Sometimes I put the old wall hung kitchen sinks in the laundry room or the garage just to keep it with the house. My wife likes to do sweaters in to old sink because it's long, wide, and shallow. |
#12 | |
Builder/Remodeler
![]() Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50 www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here |
Re: CARPENTRY - Threading Sash Weights In Double Bay Window |
Builder/Remodeler
A real giraffty window:
Handle It!
I have a Pet Draft.
#17 | |
some it's the "look"...true divided lights, etc, retaining the style of fenestration. For some it's just the least expense short term. Some just like old things....
| estimating guide for windows? | Grumpy | Windows, Siding and Doors | 20 | 11-26-2010 08:18 PM |
| Replacement Window Question? | Max10 | Windows, Siding and Doors | 34 | 02-27-2010 06:15 PM |
| Replacing double window w slider 1st time | dvlscapes | Carpentry | 5 | 09-03-2008 02:26 PM |
| Condensation Help | Patrick | Windows, Siding and Doors | 10 | 03-16-2007 09:40 AM |
| Andersen Window (1983ish) sash cord issue... | old27 | Windows, Siding and Doors | 2 | 02-11-2006 12:06 AM |
