Can I Replace A W8x35 X 20 Foot Steel I Beam With...
Old 03-14-2006, 06:24 PM   #1
Ray's Avatar
An LVL microllam, 7 inches wide by 8.5 inches tall by20 feet long?
The beam will span a 20 foot opening when I remove the existing 2x4 wall.
That wall is on the first floor of a 25 x 50 foot 2 story home, and its load bearing for floor joists that meet above that wall forming the floor for the two bedrooms above where I want to take the wall out.
Thanks
Ray
Ray is offline
Old 03-14-2006, 06:41 PM   #2
jmic's Avatar
Re: Can I Replace A W8x35 X 20 Foot Steel I Beam With...
I'd say no way, to much span!
Joe
jmic is offline
Old 03-14-2006, 06:51 PM   #3
RobertCDF's Avatar
Trade: Custom deck builder
It might be possible but you would have to talk to some engineers about it. Is it just holding the floor system or is it supporting a roof load as well?
RobertCDF is online now
Old 03-14-2006, 07:32 PM   #4
handyman923's Avatar
Trade: Structural Engineer/Contractor Wanabee
A W8x35 has a stiffness (E*I) of 3,683,000 kip-in2
A 7x8.5 (1.9E) LVL has a stiffness (E*I) of 681,000 kip-in2
The W8x35 is about 5.5 times stiffer than the LVL beam. So unless the W8x35 was significantly over-designed, there is no way this LVL would work.
handyman923 is offline
Old 03-14-2006, 07:37 PM   #5
bergenbldr's Avatar
Trade: builder remodelor
From past experience i would say a 7 inch lvl would need to be around 18 to 24 inchs deep to carry the same load as the i beam.
bergenbldr is offline
Old 03-14-2006, 08:00 PM   #6
K2's Avatar
What don't you like about the steel beam other than 700 lbs. ??
K2 is offline
Old 03-19-2006, 09:00 PM   #7
Kevin H's Avatar
Trade: home improvement
(3) 1 3/4" x 16 lvl's we did this over a garage carrying roof & floor load. I'd check with your lumber yard to be sure they'd be glad to figure it for you - Kevin
Kevin H is offline
Old 03-19-2006, 11:13 PM   #8
General Contractor
nadonailer's Avatar
No Way........................ A 5 1/2 x 14" lami beam will carry that load for that span with lots of straps and hangers - barely......
"History does not long entrust the care of freedom to the weak or the timid”.
Dwight D. Eisenhower
nadonailer is offline
Old 03-20-2006, 03:38 AM   #9
Blackhawk's Avatar
Trade: i am a small remodeling contractor been at this most my life
We took out a wait bearing wall on a two story like your on put three eightenn inch lams spanning about twenty feet or abouts and we got 3/4 deflection the minute we pulled the jacks out was suppose to be 1/4 at most so id stick with the I beam or talk to an engineer so be careful good luck ...
Blackhawk is offline
replace my barn w a steel buliding ctkiteboarding Excavation & Site Work 10 02-16-2007 08:04 AM
9 foot ceilings or 8 foot ceilings with treys? williefb General Discussion 1 02-11-2007 01:29 PM
Steel I beam capacity IHdonnie Construction 13 10-21-2006 09:42 PM
deck beam sizing and post spacing? diyerforever Decks & Fencing 5 05-10-2006 10:58 PM
ideas for wood stud wall attachment to steel "I" beam? durham Construction 9 05-10-2006 06:45 PM
