Can This Be Healthy Or Safe ? - General Discussion - Contractor Talk
Old 03-13-2018, 10:23 AM   #1
fjn's Avatar
Trade: mason
Rewards Points: 9,380
If so,it can be a game changer for energy performance.
http://www.jlconline.com/how-to/insu...6325841595919c
fjn is online now
The Following 2 Users Say Thank You to fjn For This Useful Post:
Lettusbee (03-13-2018), Rio (03-13-2018)
Old 03-13-2018, 11:10 AM   #2
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 962
Re: Can This Be Healthy Or Safe ?
Fred,
I didn't check to see if the same vid is on your link.
LINK:
https://www.mandalayhomes.com/
Mandalay Homes in Prescott Arizona is run by a fella that's from the upper peninsula here in Michigan, and I know somewhat.
Anyway, they are breaking ground on a 2900 home dev out there that will be using that process.
He's doing Net Zero homes on a large scale NOW. And he does his homework before putting new tech into production.
SmallTownGuy is offline
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
fjn (03-13-2018), Rio (03-13-2018)
Old 03-13-2018, 11:24 AM   #3
Lettusbee's Avatar
Rewards Points: 2,750
Ok, It's a liquid applied sealant, that is like caulking.
Does that mean 5 years down the road the performance will have suffered from cracked caulking syndrome?
I would like to see long term data on one of these homes.
Not bashing the people doing this, I really want to see something like this that works over the long term.
Lettusbee is online now
The Following 2 Users Say Thank You to Lettusbee For This Useful Post:
Californiadecks (04-20-2018), Rio (03-13-2018)
Old 03-13-2018, 11:27 AM   #4
John the Builder
Rewards Points: 962
No. Not how it works.
yup.
Old 03-13-2018, 12:04 PM   #5
hdavis's Avatar
Rewards Points: 1,921
This type of product has been used for duct sealing for 20 years. It has worked well, and You'd expect heat to degrade it faster than usual.
Indoor air quality us an issue no matter how you get a tight envelope.
IMO, as soon as existing housing stocks are required to meet current energy code, this is really going to take off, $1000 to retrofit an existing is way cheap.
hdavis is online now
The Following 4 Users Say Thank You to hdavis For This Useful Post:
fjn (03-14-2018), Lettusbee (03-13-2018), mrcat (03-13-2018), Rio (03-13-2018)
Old 03-13-2018, 12:09 PM   #6
Lettusbee's Avatar
So this is basically aerosolized pookie?
And how could this have a negative effect on IAQ, after it sets up?
"Pookie" is what we call duct mastic in this part of the world.
The Following 3 Users Say Thank You to Lettusbee For This Useful Post:
fjn (03-14-2018), hdavis (03-13-2018), SmallTownGuy (03-13-2018)
Old 03-13-2018, 12:17 PM   #7
hdavis's Avatar
Something like that. Whatever it is, apparently it's acrylic.
The product doesn't create the air quality concern, having a tight envelope automatically degrades air quality, so you can get into having ventilators.
Lettusbee (03-13-2018), SmallTownGuy (03-13-2018)
Old 03-13-2018, 12:31 PM   #8
Designer/Contractor
Rio's Avatar
Rewards Points: 2,388
That really is something, could really save some contractor's bacon who was supposed to have an airtight home but screwed up along the way.
Rio is online now
The Following 2 Users Say Thank You to Rio For This Useful Post:
fjn (03-15-2018), hdavis (03-13-2018)
Old 03-13-2018, 12:34 PM   #9
Lettusbee's Avatar
My 25 yo modular home is so leaky, I'd like to find the builder and take out back to the shed for some wall to wall counseling.
This might be the answer I seek. Wonder if I can get in on a franchise?
Old 03-13-2018, 12:45 PM   #10
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 528
The thing I like about it is, you can control how tight the house is by shutting the machine down once it reaches you desired air exchange rate.
Sent from my SM-G900V using Tapatalk
mrcat is online now
Old 03-13-2018, 12:58 PM   #11
John the Builder
Rewards Points: 962
vids...
https://www.youtube.com/channel/UCCU...NIQGF98U8VY2cw
fjn (03-14-2018), mrcat (03-13-2018)
Old 03-13-2018, 01:12 PM   #12
hdavis's Avatar
I'd think so, call them up.
Old 03-13-2018, 09:08 PM   #13
rblakes1's Avatar
Rewards Points: 1,682
I'm curious about the remodeling aspect, how would it not leave a layer on everything in the house? Unless I missed something
Sent from my SM-N910V using Tapatalk
rblakes1 is online now
The Following User Says Thank You to rblakes1 For This Useful Post:
Tinstaafl (03-13-2018)
Old 04-20-2018, 11:57 AM   #14
fjn's Avatar
Trade: mason
AeroBarrier Envelope Sealing Wins Best Overall Product of 2018
fjn is online now
hdavis (04-20-2018)
Old 04-20-2018, 12:03 PM   #15
John the Builder
Rewards Points: 962
Leave a layer of of what and on where? This is performed during the studs phase.
It's not like Grandma's Duncan Fife Dining room set is gong to be in the house.
smh
Old 04-20-2018, 12:13 PM   #16
rblakes1's Avatar
smh
I'd have to go back and reread the article, but it talked about doing remodel/retrofit applications. Since it can be done with sheetrock up, does it have an effect on spackle/ paint?
It would make sense that this could only be done in a new construction environment, but I don't recall it specifying that
Old 04-20-2018, 12:14 PM   #17
hdavis's Avatar
smh
I actually think this may be the best approach to airsealing an existing. Something like airseal and possibly repaint or touch up.
Old 04-20-2018, 01:07 PM   #18
RyMar Builders's Avatar
Rewards Points: 50
That’s a pretty interesting way to seal the house, I can definitely see a benefit for using it in older homes, but is having a super tight house healthy? I’m a builder in Prescott and we have a lot of radon gas, From what I understand you need air exchange to help mitigate radon build up in the house.
RyMar Builders is offline
Old 04-20-2018, 01:16 PM   #19
John the Builder
Rewards Points: 962
Originally Posted by RyMar Builders View Post
Thatís a pretty interesting way to seal the house, I can definitely see a benefit for using it in older homes, but is having a super tight house healthy? Iím a builder in Prescott and we have a lot of radon gas, From what I understand you need air exchange to help mitigate radon build up in the house.
There are specific methods for dealng with radon. And they do not include leaving pulling the windows out and letting the wildlife in.
Do your homework.
PS: Actual home builders know what is required of the homes they build n the state they are in.
Old 04-20-2018, 01:40 PM   #20
hdavis's Avatar
If a house fails a radon test, actual mitigation is the only answer.
fjn (04-20-2018), SmallTownGuy (04-21-2018)
How do you keep homeowners safe on the jobsite? Cricket General Discussion 7 05-20-2017 03:18 PM
Metal Roof Paint - animal safe artinall Painting & Finish Work Picture Post 5 04-25-2013 09:45 PM
Building a safe room / vault bdog1234 General Discussion 29 10-27-2012 10:16 AM
Secret safe. SuperiorHIP General Discussion 19 12-01-2010 08:34 AM
Hud announces $13 million in grants to protect kids from lead paint Brickie General Discussion 22 05-15-2010 02:09 PM
