Building Over New Drainfeild
Old 11-07-2017, 11:00 AM   #1
stovebolt's Avatar
Rewards Points: 4
Just a hypothetical... what if i were building a garage with a poured slab, and i were to install a drain feild about 4 ft deep under the slab... i know this is not code anywhere, but what are the real world risks, possibilities, and probabilities?
The soil in the area gas excelent drainage.
stovebolt is offline
Old 11-07-2017, 04:51 PM   #2
tgeb's Avatar
Rewards Points: 366
Re: Building Over New Drainfeild
Why would you even entertain such a silly notion when you've already admitted that it would violate building codes.
www.gebcon.com
tgeb is online now
The Following 2 Users Say Thank You to tgeb For This Useful Post:
AustinDB (11-08-2017), dayexco (11-07-2017)
Old 11-07-2017, 10:28 PM   #3
Deaknh's Avatar
Trade: Handyman
Think he was saying it's not required by code, not that it violated code.
Deaknh is offline
Old 11-07-2017, 10:52 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,104
No, there's no code that would allow that.
Most likely scenario is that he doesn't have the acreage to put in a legal setup.
Tinstaafl is offline
Old 11-07-2017, 10:54 PM   #5
Deaknh's Avatar
Trade: Handyman
Leach field? Ohhhh. Never heard it called drain field before. No, don't do that. Ever.
Deaknh is offline
Old 11-08-2017, 12:25 AM   #6
Jay hole's Avatar
Trade: General contractor
Rewards Points: 885
Are you asking for a friend?!?!🤣
Jay hole is online now
Old 11-08-2017, 12:47 AM   #7
stovebolt's Avatar
Rewards Points: 4
Tinstaafl is pretty much right on. I know it violates all codes everywhere, and in fact, if attempted, i would take great measures to conceal it during other inspections.
Let me ask the same question in a different way...
Imagine that there are no such things as building codes. You have a lot with a house, many trees, and an easement in your way. There is just enough space in one corner to add a garage or mother in law house.... your existing septic system for the house is over 60 years old, made of concrete pipe, and under-engineered from the begining... so pretty much impossible to add to IF it could handle the increased load.
Now, thinking outside the box for your new bldg addition you think... "i could lay the drain (or leach) feild under the slab, have a small tank to the side of the building, and cleanouts several feet outside the perimeter just in case".
The weight of the building would be evenly distributed over the slab eliminating pressure points, the pipes would be deep, also decreasing pressure, and finally your not going to last 60 years anyway (current age of poorly designed septic system for your house.)
So what would the consequences or less than desirable effects be for this sort of design? (Besides codes and inspectors)
Will Hell open up and suck the house into the abyss? Or will everything probably be ok?
Also important to note: this one is not for a customer.
Old 11-08-2017, 01:31 AM   #8
Designer/Contractor
Rio's Avatar
Rewards Points: 744
Who knows, could end up being a sh!tty situation. How about doing a vertical septic system?
Rio is online now
Old 11-08-2017, 05:21 AM   #9
builditguy's Avatar
Rewards Points: 198
I suspect he has already installed the septic system and now decided he wants a garage. Turns out the only area with enough room is over the new septic field.
Answer is no. As said above. A different type of septic system would have made it possible, but I believe the system is already in place.
builditguy is offline
Old 11-08-2017, 09:56 PM   #10
3bar's Avatar
Trade: carpenter
Rewards Points: 422
is redoing the septic an option? or is there no legal alternative?
3bar is offline
Old 11-08-2017, 11:32 PM   #11
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 1,860
Well, here's the reasons it's a code violation:
1, all septic systems fail at some point, and need periodic maintenance and upkeep, but you can't do that if you don't have access to it, because it's underneath your house.
2, in order to build a structure, it is necessary to fully compact the base. This is the opposite of what you want to do over a leach field.
3, intentionally placing water underneath a house is bad idea all around, particularly pathogen-laden effluent.
I seen some pretty hacked-up stuff in my day, and I know people do some dumb stuff on there own property, but there is no excuse for doing what you're thinking of doing.
Delta
I have an Edifice Complex.
TxElectrician (11-10-2017)
Old 11-08-2017, 11:54 PM   #12
Unger.const's Avatar
Rewards Points: 2,496
Every time you go into the garage.........it smells like a sewage treatment plant . Might reduce the amount of friends coming over to visit.....
Unger.const is offline
Old 11-09-2017, 08:12 AM   #13
hdavis's Avatar
Rewards Points: 4,559
It won't perc the way you expect. If you want something that will perc, pole barn with car decking or pole barn with crushed rock (no compaction).
Normally there is a lot of evaporation from a leach field.
I've never seen it, but I think a holding tank in that location could be legit.
hdavis is online now
Old 11-09-2017, 11:12 AM   #14
Frank Castle's Avatar
Rewards Points: 452
Delta
I'm with 7-Delta on this one.
Adapt, Improvise, Overcome.
Frank Castle is offline
Framing for end walls on steel truss hoop building JaWe General Discussion 2 09-27-2017 05:14 PM
Looking for steel building erectors and concrete specialists jcollins23 Help Wanted or Looking For Work 1 08-30-2017 10:08 PM
Moling in a new water main at a small office building Cuda Plumbing 0 10-15-2012 07:50 PM
Block building leaking inside? GSS Masonry 9 05-24-2010 10:20 AM
