Building First Cricket
Old 09-26-2009, 07:31 AM   #1
Box Builder
Morning Wood's Avatar
Rewards Points: 8,492
This is my first cricket attempt on a chimney. Wondering how wide you guys build your crickets. do you go full width of the chimney or less? Also, what do you cover the cricket with? It is an asphalt shingle roof. I am going to cover with water and ice and then rubber roofing. Thanks.
Morning Wood is offline
Old 09-26-2009, 07:41 AM   #2
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
Re: Building First Cricket
In most cases, I will use a 4' level to get my ridge height at the chimney, then make my rafters long enough to get the valley to finish just a bit beyond the finished surface of the chimney. They get I&W first, then typically asphalt shingles. In some cases, they will get a soldered seam copper pan.
You may be able to make out this one to get an idea.
loneframer is offline
Old 09-26-2009, 07:47 AM   #3
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Usually the crickets I deal with are covered with the same material as the rest of the roof. Around here that means it is asphalt shingles with few exceptions.
The cricket is always as wide as the chimney to prevent having a catch area behind the chimney, which is the purpose of a cricket in the first place.
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline
Old 09-26-2009, 08:14 AM   #4
Kent Whitten's Avatar
Rewards Points: 2,040
If you go too long, you see little triangle pieces past your chimney. If you go too short, you create a possible trap of ice/snow/rain. The surface of the plywood should plane a valley to the point of the finished siding or just a tad more.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 09-26-2009, 09:45 AM   #5
Box Builder
Ok. No problem going full width. It is only 24" wide anyway. Do you guys seal all your shingle nails on the cricket or just roof it normally? Also, I figured I would try to match the existing pitch of the roof depending on how my shingle courses ended up.
Old 09-26-2009, 09:50 AM   #6
smartazz contractor
mtp's Avatar
Trade: commercial interiors
Rewards Points: 75
I bet it leaks....
mtp is offline
Old 09-26-2009, 10:12 AM   #7
Box Builder
We'll see about that.
Old 09-26-2009, 10:18 AM   #8
Framer53's Avatar
Trade: Handyman
Rewards Points: 242
Don't forget the I&W before the shingles.
Framer53 is offline
Old 09-26-2009, 10:53 AM   #9
framer
steves's Avatar
Trade: framing
Rewards Points: 150
Crickets are the simplest thing that I see most guy's strugle with.
I just mark a level line from the roof to the center of the chminey, measure the legnth of the ridge, (level line) and from the center mark to the bottom corner of the chim.
Cut 2 triangles from 3/4 ply, hold them together flat and nail the ridge from both sides. Pull the bottom corners apart, drop it on the roof, beat to fit and nail it to the roof ply. Keep it small enough and you can jump all over it with no deflection.
Cover it with I+W then cover with whatever roofing you have on the rest of the roof. A good cricket shouldnt be seen from the ground.
steves is offline
Old 09-26-2009, 10:58 AM   #10
Trailer park boy
shanekw1's Avatar
Rewards Points: 9,251
Originally Posted by steves View Post
beat to fit
Is that a technical term?
"Industry without art is brutality"
shanekw1 is offline
Old 09-26-2009, 11:09 AM   #11
KemoSabe
loneframer's Avatar
That is actually the generic definition of "Persuasive fudging"
Old 09-26-2009, 11:12 AM   #12
Trailer park boy
shanekw1's Avatar
I have a hammer that I call "The Convincer", special for persuasive fudging.
shanekw1 is offline
Old 09-26-2009, 11:24 AM   #13
Handle It!
MALCO.New.York's Avatar
Rewards Points: 2,000
I have at least four different sized Hammers in MY box!
Ultimate Wisdom---------
MALCO.New.York is offline
Old 09-26-2009, 11:38 AM   #14
Trailer park boy
shanekw1's Avatar
Yea, but, are any of them called The Convincer?
shanekw1 is offline
Old 09-26-2009, 02:57 PM   #15
Home Builders/Contractors
Metrojoebarbs's Avatar
Trade: Residential Home Builder/Contractor
Rewards Points: 250
I bought a gift for my wife called the "Punisher" once.
Metrojoebarbs is offline
Old 09-26-2009, 03:02 PM   #16
Originally Posted by metrojoebarbs View Post
i bought a gift for my wife called the "punisher" once.
tmi
neolitic is offline
Old 09-26-2009, 03:11 PM   #17
HSConstruction's Avatar
Rewards Points: 250
My BFH is known as the persuader.
HSConstruction is offline
Old 09-26-2009, 04:28 PM   #18
wannabe
WNYcarpenter's Avatar
Trade: carpentry
Rewards Points: 1,000
Just did it yesterday...on a 12/12....36" chimney.
I cut two 2x4's 24" long with 45* seat cut. Held them 1/2" back from the side of the chimney, let them cross and then I scribed them to mark my plumb cuts.
Cut my pieces then nailed the triangle together. Marked center, n tapconned to brick. Leveled back to the roof for ridge length...18" so no rafters were needed.
then measured one side for the ply. cut ply and used that piece to scribe the next piece. assembled, I&W. Then shingled like I would normally, just on a smaller scale.
WNYcarpenter is offline
Old 09-26-2009, 06:29 PM   #19
KemoSabe
loneframer's Avatar
Mine is affectionately referred to as "The Equalizer"
The Following User Says Thank You to loneframer For This Useful Post:
MALCO.New.York (09-26-2009)
Old 09-26-2009, 10:40 PM   #20
Moderator
Double-A's Avatar
When I was using one, it was called The Reason.
As I would swing, I would chant, "Because I said so, Damnit!"
New York Times, July 20, 2006
Double-A is offline
Joasis (and others) how much would this building cost in your area? Mike Finley Construction 8 09-15-2008 03:51 PM
??? Whats the best way to spread the news about your company? jmgrahamjr Marketing & Sales 21 06-24-2008 04:46 AM
Certified Green Building Professional Training CatAlii Green Building 6 05-11-2008 04:20 PM
Nobody Wants to bid Deutsche Bank Building Now Wolf Demolition 2 08-26-2007 03:37 PM
