Building Ada Wooden Ramps
Old 05-28-2012, 06:27 PM   #1
raydlr's Avatar
Trade: remodeler
Time and time again I hassel with figuring materials on building a ramp. The ramps im building have a 5x5 landing then go out x amout of feet. I cant seem to grasp the concept of figuring the planks. Ive searched for calcjlators or apps even programs to speed up the process , but no luck. Any sugestions.
raydlr is offline
Old 05-28-2012, 06:35 PM   #2
GRB's Avatar
Trade: Carpentry Contractor
Re: Building Ada Wooden Ramps
You mean decking planks?
You need to figure your rise & run, which will give you the diagonal length of your "rafters" (joists). Once you have that, just divide by whatever your decking width is & you'll have your number of pieces.
GRB is offline
The Following 2 Users Say Thank You to GRB For This Useful Post:
raydlr (05-28-2012), Seven-Delta-FortyOne (05-28-2012)
Old 05-28-2012, 06:40 PM   #3
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 1,972
well you could go and buy a 16 footer chop it up into small blks and lay it out that way
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
The Following User Says Thank You to parkers5150 For This Useful Post:
raydlr (05-28-2012)
Old 05-28-2012, 06:44 PM   #4
GRB's Avatar
If you don't have one, get yourself a construction calculator for figuring out projects like this.
GRB is offline
The Following User Says Thank You to GRB For This Useful Post:
raydlr (05-28-2012)
Old 05-28-2012, 07:08 PM   #5
Tom M's Avatar
Rewards Points: 5,558
Maybe we have a HO
Tom M is online now
raydlr (05-28-2012)
Old 05-28-2012, 07:12 PM   #6
GRB's Avatar
Originally Posted by Tom M View Post
Maybe we have a HO
I thought they were supposed to be kept in the van from the other thread?
GRB is offline
The Following 3 Users Say Thank You to GRB For This Useful Post:
MAULEMALL (06-01-2012), raydlr (05-28-2012), Tom M (05-28-2012)
Old 05-28-2012, 08:19 PM   #7
WICKED WOODCHUCKER
mnjconstruction's Avatar
Trade: Finish carpentry, drywall, Tile
Ho. Ho. Ho i think we got an ho!
mnjconstruction is offline
The Following User Says Thank You to mnjconstruction For This Useful Post:
raydlr (05-28-2012)
Old 05-28-2012, 09:21 PM   #8
raydlr's Avatar
Trade: remodeler
Lol.. Ho ho ho....
raydlr is offline
Old 05-29-2012, 12:26 AM   #9
PRO
BrandConst's Avatar
Rewards Points: 1,000
If your a real contractor I would only assume you keep receipts, payroll records, etc and somewhat keep it organized. If this were the case you would take your historical data and come up with some sort of ballpark price or cost per linear foot or sq foot.
BrandConst is offline
The Following User Says Thank You to BrandConst For This Useful Post:
raydlr (06-09-2012)
Old 05-29-2012, 07:47 AM   #10
PA woodbutcher's Avatar
You mean something like this only different?
How far apart do you want to put your posts (meaning how much do you like digging holes), and what do you want to use for joists?, how high off the ground id your landing going to be.. Lots of questions, before anyone can give you any answers.
When you rob Peter to pay Paul, chances are pretty good you will receive Paul's vote. Apparently the object of the game is to create more Pauls than Peters....What happens when the Peters can no longer support the Pauls? .
PA woodbutcher is offline
The Following User Says Thank You to PA woodbutcher For This Useful Post:
raydlr (06-09-2012)
Old 05-29-2012, 10:09 AM   #11
Tom M's Avatar
Thats a handsome ramp.
My experience though says @ 1:12 an elevation over 18" starts becoming the less expensive option to a stair lift. When you lay it all out on paper and add up the footings and landings it becomes very labor intensive.
Tom M is online now
Old 05-29-2012, 12:00 PM   #12
General Contractor
greg24k's Avatar
Rewards Points: 7,236
You can do a basic layout, just follow the requirements and keep maximum ramp slope 1:12 and maximum rise for any run 30 in.
greg24k is offline
raydlr (06-09-2012)
Old 05-29-2012, 08:12 PM   #13
deckman22's Avatar
Trade: Deck Builder
Rewards Points: 5,416
I think to be ADA compliant you need the ramps to be 5' wide also, not 4' as Greg24K shows.
Deckman
www.alscustomdecks.com
deckman22 is offline
Old 05-29-2012, 08:43 PM   #14
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Ramps only need to be 40" here. Landings minimum 4' by 5' so someone can manipulate a wheelchair effectively. Most all wheelchairs are designed to fit through 35" or the typical 36" doorway.
ohiohomedoctor is offline
The Following User Says Thank You to ohiohomedoctor For This Useful Post:
SC sawdaddy (06-07-2012)
Old 05-29-2012, 09:12 PM   #15
deckman22's Avatar
Trade: Deck Builder
Funny, the ADA ramps I start tomorrow the architect drew up everything 5' wide, thought that ADA rules were nationwide. All the ramps I put on school buildings here have always been 5' wide, but then everything in Texas is bigger.
Deckman
Old 05-29-2012, 09:16 PM   #16
Especially the egos.. :
Id bet 6' would be better. All heck lets just spec 124' just to make it easy.
Good luck finding an inspector who knows what it's supposed to be.
Old 05-29-2012, 09:34 PM   #17
Fire up the BBQ
griz's Avatar
Rewards Points: 316
Read this:
sec. 4.7 & 4.8
36" in the clear on the ramp, 60" on a landing...
http://www.access-board.gov/adaag/html/adaag.htm#4.7
griz is offline
The Following 3 Users Say Thank You to griz For This Useful Post:
deckman22 (05-29-2012), greg24k (05-29-2012), SC sawdaddy (06-07-2012)
Old 05-29-2012, 09:44 PM   #18
General Contractor
greg24k's Avatar
If the accessible route makes a 180 degree turn around an element which is less than 48 inches wide, clear travel width shall be 42"
minimum when approaching the turn, 48 inches minimum at the turn and 42 inches minimum leaving the turn.
If you have a clear width at the turn which is 60 inches then this minimum compliance is not required and the minimum clear width of a ramp can be 36" min, 32" min after railing or kick plate... we always made it 42 if there is no room restriction and landing 60", again if there is no room restrictions.
greg24k is offline
PA woodbutcher (05-30-2012)
Old 05-29-2012, 10:45 PM   #19
deckman22's Avatar
Trade: Deck Builder
Originally Posted by griz View Post
Read this:
sec. 4.7 & 4.8
Thanks for that link.
Deckman
Old 05-29-2012, 11:16 PM   #20
General Contractor
greg24k's Avatar
Read this:
sec. 4.7 & 4.8
Griz, update your file, this is the latest ADA compliance code which is adopted nation wide.
greg24k is offline
The Following 2 Users Say Thank You to greg24k For This Useful Post:
griz (05-29-2012), SC sawdaddy (06-07-2012)
High Value green building program points? Matt G Green Building 11 03-02-2010 02:39 PM
Salvage value of an old commercial building CharlesD General Discussion 14 01-24-2010 09:26 PM
Pipe-dreaming inquiry - building multi-units. bob_cntrctr General Discussion 2 04-27-2009 10:41 AM
Underground in building low voltage OhioTelecom NEC Discussion 4 03-22-2009 02:22 PM
