Brick Ledge Height
Old 11-22-2017, 12:10 PM   #1
prov774's Avatar
Rewards Points: 2
Brick Ledge Height
Hello,
I am trying to calculate the most common brick ledge height for a house in Houston TX area.
Are there are any codes or standards that apply?
What is the typical vertical height?
Thanks!
prov774 is offline
Old 11-22-2017, 04:40 PM   #2
MeanWeen's Avatar
Trade: City worker
Rewards Points: 24
Re: Brick Ledge Height
Not sure if there is a common height. Usually depends on what you are trying to accomplish, and the dimensions of the material you are working with. Typically for a wainscotting somewhere around 3í. Usually you would probably be coming up to the bottom of some windows or another feature. Iím sure you will get lots of varied answer. Would help a bit more if you told us what you were trying to do.
MeanWeen is offline
Old 11-23-2017, 02:56 AM   #3
3bar's Avatar
Trade: carpenter
Rewards Points: 380
you talking about the brick ledge on the foundation?
usually its a flat 2x4 or double flat 2x4 stepdown. so 1.5 to 3 inches perhaps.
3bar is offline
Old 11-23-2017, 03:12 AM   #4
MeanWeen's Avatar
Trade: City worker
Rewards Points: 24
Ahh, that makes more sense what 3bar said, I was thinking he was asking about a sill or cap.
MeanWeen is offline
Old 11-23-2017, 09:08 AM   #5
B.Johnson's Avatar
Trade: Builder
Rewards Points: 170
My answer would be whatever it takes to get below grade.
Home Designer Series Software
B.Johnson is offline
Cracked Brick Kneewall Planter Moishe3rd Masonry 4 04-28-2014 08:38 PM
removing brick Yersmay Masonry 27 12-24-2011 11:46 PM
Adding a Brick Ledge to a Michigan Home bajafx4 Masonry 3 01-23-2009 07:19 PM
Brick ledge coupe33 Masonry 14 01-12-2009 06:55 PM
ICF brick ledge coupe33 General Discussion 7 11-29-2008 01:45 AM
