Board Formed Concrete Wall
Old 11-28-2017, 07:08 PM   #21
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 12,919
Re: Board Formed Concrete Wall
Originally Posted by hdavis View Post
Top to top, yes? This is a standard way to do it, but it should really be done earlier in the form build.
Top to top.
MarkJames is offline
hdavis (12-01-2017)
Old 12-01-2017, 08:27 PM   #22
Designer/Contractor
Rio's Avatar
Rewards Points: 1,796
The UCSD central library, designed by William Pereira, and built by Bechtel in the mid 1960s is board formed, looks really good and there is virtually no maintenance.
Rio is offline
The Following 4 Users Say Thank You to Rio For This Useful Post:
asevereid (12-01-2017), B.Johnson (12-02-2017), fjn (12-02-2017), hdavis (12-01-2017)
Old 12-02-2017, 10:16 AM   #23
fjn's Avatar
Trade: mason
Rewards Points: 9,112
I'm not much of an modernist when it comes to architecture,but I can really go for something like this !
Thank you for sharing !
fjn is online now
Old 12-02-2017, 11:17 AM   #24
calmod's Avatar
Trade: general contractor
Rewards Points: 172
I do modern architecture and board formed is a look that's been specified to me. It looks beautiful if it's done correctly. highly labor intensive if you want it to look good and not blow out. I've done it for low walls and benches for the entry to the house. I always avoid it for real retaining walls as the labor is too much on a higher wall that actually has a job to do and has engineering involved. I've built big walls with grain matched plywood and carefully laid out snap ties which held up well for ten to twenty foot tall pours. A board formed wall at that dimension would require a forest of bracing. I'm lucky in that when I started out building them I had a subcontractor that had crazy experience so I learned from his crew. It requires a lot of bracing and finish carpentry skills when you form as every mistake shows.
calmod is offline
The Following 2 Users Say Thank You to calmod For This Useful Post:
asevereid (12-02-2017), DaVinciRemodel (12-03-2017)
Old 12-02-2017, 01:43 PM   #25
MarkJames's Avatar
All seemed to be going well with the pour, but nearing the end they had a blowout in one portion (backside). Pics later.
Tall Residential Concrete Foundation Wall Question John 1979 Masonry 8 12-11-2016 02:19 PM
need help on bidding for concrete jobs! Bconcretegirl Marketing & Sales 15 12-04-2013 11:25 AM
Bathroom Design Help - dark floor and wall tile the same? sbcontracting Architecture & Design 23 10-02-2013 12:14 PM
Concrete Slab breaking up in Barn Dustincoc General Discussion 7 02-14-2013 06:44 PM
Lightweight concrete alternative in a condo DanFreysinger Flooring 17 11-14-2012 09:10 AM
