Board Formed Concrete Wall
Old 11-27-2017, 06:11 AM   #1
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 10,611
There's a remodel job in the neighborhood where they're said to be going for a horizontal board look on a 2-3' high concrete retaining wall. The forms are made out of horizontally faced and braced 2x4's, without plywood backing. Does this sound like a real pro method? It's got a bit of the "we never did it this way before'" look to it so far, but this contractor already did 22 cubic yards worth of steps and landing there (higher up on the hill than this new retaining wall, by about 12'
The wall will run about 20', then turns 90 and runs up a driveway for another 15' or so.
I hope concrete doesn't show up this morning, because the side form can be wobbled easily.
MarkJames is online now
Old 11-27-2017, 06:57 AM   #2
builditguy's Avatar
Rewards Points: 118
Re: Board Formed Concrete Wall
I wouldn't say it is exactly the most professional way, but I've seen alot of concrete walls that were poured with wood forms.
For basements, forms used to be plywood with pencil ties.
For standard concrete forms they make plastic forms that slide down inside the forms. It leaves a wood impression in the concrete.
They probably make other styles.
The difference is the forms, to make it look like boards, leave the impression. What you described is going to make it look like it was formed with boards, not made of boards.
As far as the forms being wobbly, I see that a fair amount. Usually someone that hasn't poured very much. Even small pours that are about 12" out of the ground, I don't see enough kickers. You can go by after it's poured and see the bow.
builditguy is offline
The Following User Says Thank You to builditguy For This Useful Post:
MarkJames (11-27-2017)
Old 11-27-2017, 09:04 AM   #3
hdavis's Avatar
Rewards Points: 3,439
5/4 is plenty thick enough. I don't think this is going to be a good look.
Building wood forms in general takes some experience.
hdavis is online now
Old 11-27-2017, 10:33 AM   #4
Hack
asevereid's Avatar
Rewards Points: 126
Notice any ties holding the forms together?
I'm just trying to picture how this would look...
Sent from my SM-G530W using Tapatalk
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is online now
Old 11-27-2017, 10:40 AM   #5
hdavis's Avatar
Since they're trying for a decorative look, the forms can be tied together above and below the exposed face only. Bracing would be doing most of the work.
Old 11-27-2017, 10:47 AM   #6
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 7,230
pictures please.
before & after.
if you get busted for trespass we'll bail you out.
trust me on this.
Net Zero Energy Is Here Now
“The worst day working for yourself, is still better than the best day working for someone else!”
..Jim Rohn
SmallTownGuy is online now
The Following 3 Users Say Thank You to SmallTownGuy For This Useful Post:
B.Johnson (11-27-2017), mstrat (11-29-2017), tgeb (11-28-2017)
Old 11-27-2017, 10:49 AM   #7
Fishindude's Avatar
Trade: Industrial
Rewards Points: 188
Sounds rather jerry rigged.
I'd use standard wall forms and a form liner to get the desired look. Something like a sheet of T-111 on inside face of forms would do it, if you don't want to buy the plastic form liners.
Fishindude is offline
Old 11-27-2017, 11:18 AM   #8
John the Builder
like a bunch of striped pillows strung together?
just guessing...
..Jim Rohn
Old 11-27-2017, 11:55 AM   #9
Hack
asevereid's Avatar
Rewards Points: 126
just guessing...
If its only 2 to 3 feet tall (depending on thickness) they should be able to make that look just fine... But I agree that more kickers are necessary. That form should be plenty strong with 2x4 facing.
If it were me, I'd have a kicker every 5 or 6 feet.
****, it ain't rocket appliance.
http://goo.gl/Il8c2
The Following User Says Thank You to asevereid For This Useful Post:
SmallTownGuy (11-27-2017)
Old 11-27-2017, 02:00 PM   #10
MarkJames's Avatar
I'll try to get pics, but there are guys all over the site today.
The Following 2 Users Say Thank You to MarkJames For This Useful Post:
asevereid (11-27-2017), SmallTownGuy (11-27-2017)
Old 11-27-2017, 04:22 PM   #11
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 228
Send a message via Skype™ to jlhaslip
Imagine, if you will, how basements were poured before Plywood became common.
Set up the wood form and add a layer of plywood forms behind it and use snap ties or tie wire to bind the panels together.
It ain't rocket surgery here.
It actually looks fine as an Architectural feature. Used it on this Bridge for the Abutments. Sorry, can only find this drawing as an image.
jlhaslip is offline
Old 11-27-2017, 04:29 PM   #12
Safety Third
shanewreckd's Avatar
Trade: Concrete Carpenter. Concreepenter? Carpencrete?
Rewards Points: 190
It would look nicer if it was rough sawn 5/4 or old ship lap. It's easy enough to make something like that look good, and brace it stable. I'm interested to see how 2x4 turns out...
shanewreckd is offline
The Following 3 Users Say Thank You to shanewreckd For This Useful Post:
asevereid (11-27-2017), Rio (12-01-2017), SmallTownGuy (11-27-2017)
Old 11-27-2017, 05:04 PM   #13
hdavis's Avatar
The problem with individual boards is some will bulge more than others. T&G gets rid of that issue. Plywood backing gets rid of it too. I
Old 11-27-2017, 08:41 PM   #14
B.Johnson's Avatar
Trade: Builder
Rewards Points: 460
I think that ship lap would be a bad idea. Remember that it is a form and you are doing to end up with a reverse image.
I've never used rough sawn or reverse board and batten as a form, but wouldn't it be tough to strip?
Home Designer Series Software
B.Johnson is online now
Old 11-27-2017, 08:47 PM   #15
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 196
Here you go. This is where I learned about it.
https://www.lifeofanarchitect.com/bo...rmed-concrete/
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is online now
Old 11-27-2017, 08:49 PM   #16
Safety Third
Rewards Points: 190
Nailing in a few rows of wailers will also solve that problem, as long as it's braced at every level. With the rounded corners on all KD dimensional I just think this whole thing is going to look goofy regardless, some weird ridge patterns. Although I have been wrong before... I'm only here to see how it turns out
The Following 2 Users Say Thank You to shanewreckd For This Useful Post:
Old 11-27-2017, 08:59 PM   #17
Safety Third
Rewards Points: 190
I'm aware it's a mirror image, I just think the ship lap would eliminate the worst of the ridge patterns between boards, while adding strength to the joint. Enough form release/diesel and you can do it. I've also been using a furniture polish, can't remember the brand, that works better than anything else with the plasticized epoxy grouts I use in the mill. Expensive though, wouldn't want to use it on a retaining wall.
Old 11-28-2017, 11:21 AM   #18
fjn's Avatar
Trade: mason
Rewards Points: 8,392
For board formed concrete,it makes sense to use fiberglass wall ties. Unlike steel snap ties that need patching and potential rust marring the look,fiberglass ties are made to be cut flush,they blend in and are unobtrusive.
http://www.sigmadg.com/?gclid=CjwKCA...xoCJAAQAvD_BwE
fjn is online now
hdavis (11-28-2017)
Old 11-28-2017, 07:54 PM   #19
MarkJames's Avatar
New development. For lack of a better term, they're bridging the two sides of the form to each other.
Old 11-28-2017, 08:00 PM   #20
hdavis's Avatar
Top to top, yes? This is a standard way to do it, but it should really be done earlier in the form build.
Tall Residential Concrete Foundation Wall Question John 1979 Masonry 8 12-11-2016 03:19 PM
need help on bidding for concrete jobs! Bconcretegirl Marketing & Sales 15 12-04-2013 12:25 PM
Bathroom Design Help - dark floor and wall tile the same? sbcontracting Architecture & Design 23 10-02-2013 01:14 PM
Concrete Slab breaking up in Barn Dustincoc General Discussion 7 02-14-2013 07:44 PM
Lightweight concrete alternative in a condo DanFreysinger Flooring 17 11-14-2012 10:10 AM
