Best Window For The Money?
I was looking for some feed back as to the best window for the money. Building a 5,700 sqft log home. Looking at using Anderson 200, Pella, Jeld-wen, or Semco. Thanks
Thom
Re: Best Window For The Money?
Without the location of the project, we can't give an appropriate answer.
Here in Albuquerque, the climate is mild, UV is very high (we're a mile above sea level), and it's very dry (as low as 5%) with swings to high when it rains. Wood doesn't fare well if it's exposed to the elements, vinyl degrades in the UV. Aluminum is a good material. It lasts and is unaffected by our conditions. The downside, thermal transmission, is mitigated by our mild climate. |
I like Green things
I will rule out Semco without even knowing more info.
wood is good
Trade: trim carpenter
Dont even consider the Andersen 200 series--rather use the 400 series.
Roger
"SKILLED Carpenters aren't CHEAP , CHEAP Carpenters aren't SKILLED " --- saw this on a t-shirt a while back --- |
KemoSabe
I've been installing Andersen windows along the coast for 24 years. They have always stood by their product, in some cases beyond the warranty. I installed Andersen casements in my new home when I built it and have done 200 series double hung windows to replace the original Andersen casements in the home I'm in now, which were 25 years old. When properly installed, they are trouble free.
| The Following User Says Thank You to loneframer For This Useful Post: | Sooner Pesek (03-10-2009) |
#6 | ||
wood is good
Re: Best Window For The Money?Quote:
I probably should have been more clear in my statement--For the money, I would prefer the 400 series over the 200. Sorry, Roger
KemoSabe
The 400 series is hands down a better window than the 200 series, agreed. In my own personal situation I couldn't justify the additional cost. The 200 series also fit my existing openings better at the time.
I like Green things
I have had very good luck with the 200 series as well.
Most windows hold up if installed corectly. I have seen some semco's that were no more than 4 years old that were completey rotten, even installed right, for the most part. |
Thanks for the info. Should have noted, I build in East TN. 80-90's in Summer and 30-50's in Winter.
Tool Junkie
I agree with Warner the semco's are garbage
'06 F-350 Crew Cab Short Box V10 '04 Caterpillar 236B , Solideal rubber tracks & lots of attachments |
TRC
Trade: Windows and Doors
Never heard of Semco. Andersen's are great because you find them at most lumber yards or building supplier's so they are very competitively priced. I find discounts on the pella's harder to come by but they are equally good imo.
| estimating guide for windows? | Grumpy | Windows, Siding and Doors | 20 | 11-26-2010 08:18 PM |
| Replacement Window Question? | Max10 | Windows, Siding and Doors | 34 | 02-27-2010 06:15 PM |
| Estimating Exterior window and door painting | nolanco | Painting & Finish Work | 1 | 08-23-2008 11:53 AM |
| Pre Cast Window | Don H | Drywall | 7 | 09-20-2006 11:01 PM |
| Window Seat and Bookshelves in Fonr of Baseboard Heating | Richie-C | Finish Carpentry | 10 | 04-04-2006 09:05 PM |
