Bathroom Exhaust Venting
Old 11-18-2009, 05:27 PM   #1
Service & Repairs
Magnettica's Avatar
Trade: Electrician
I have 2 exhaust fans to wire and install.
Can I couple the (2) 4" aluminum vents into 1 common 4" vent?
Or am I better off doing 2 separate runs?
Magnettica is offline
Old 11-18-2009, 05:46 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Re: Bathroom Exhaust Venting
In theory that would work as long as both fans aren't running at the same time. Each fan will have a flapper to prevent reverse air flow. But if they're both running, neither one will be able to push the air at full efficiency.
Related question: Where are you running the vents to? Roof vent, ridge vent, gable wall? The last is best when practical. And remember not to have any low spots in the run that could collect condensation.
Tinstaafl is online now
Old 11-18-2009, 05:49 PM   #3
rselectric1's Avatar
I've always done separate runs. My thoughts on this are because that little plastic flapper on the fan units aren't very substantial and you dont want a deuce from one bathroom to be evident in adjacent bathrooms.
I would imagine that if there is any air pressure on them at all (from the wrong direction), they would open.
Just my $0,000.02
rselectric1 is online now
Old 11-18-2009, 05:56 PM   #4
Grand Rapids Remodeling
Paulie's Avatar
[quote=rselectric1;810694]I've always done separate runs.
I second that. It can be quite a pain though if your in a tight space and sometimes the HO doesn't like the looks of two vents side by side in the soffit or whatever but I've always run 'em separate.
Paulie is offline
Old 11-18-2009, 05:56 PM   #5
Pompass Ass
bwalley's Avatar
This is why the mechanical contractor should install the fart fans.
bwalley is offline
Old 11-18-2009, 05:57 PM   #6
Remodeling GC
kevjob's Avatar
if your going to run 2 fans on one duct look into http://www.americanaldes.com/products.html they can vent multiple fans on one exhaust point.
kevjob is offline
Old 11-18-2009, 06:00 PM   #7
And I do electrical, too!
480sparky's Avatar
I'm a wierdo. Since I'm an electrician, I let the HVAC people do the venting.
Site : the area or exact plot of ground on which anything is, has been, or is to be located.
Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision.
Cite : To mention in support, proof, or confirmation; refer to as an example.
480sparky is online now
Old 11-18-2009, 06:03 PM   #8
Capra aegagrus
Tinstaafl's Avatar
Some of us don't have to choose between walking and chewing bubble gum.
Old 11-18-2009, 06:04 PM   #9
I agree for new construction or remodeling, but I must admit that for swap outs on service calls, I have run these myself. I usually duplicate the existing setup, unless they just vent into an attic.
Old 11-18-2009, 06:15 PM   #10
Service & Repairs
Magnettica's Avatar
Trade: Electrician
A) Gable ends (split level home).
B) Because I'd rather not sub out any venting on a small job such as this.
C) Thanks for the link.
D) Chewing gum and walking at the same time is something I learned very early on in life.
I'm going to install 2 separate runs. Seems to make the most sense. There is a very good chance of both fans being on at the same time.
Old 11-18-2009, 06:17 PM   #11
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Hopefully I get this job I went looked at today. Complete gut job remodel. I will be more than happy to have an HVAC professional do the venting.
Old 11-18-2009, 06:18 PM   #12
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Thanks for the tips regarding condensation build up.
Old 11-18-2009, 06:19 PM   #13
Electrosexual
Zinsco's Avatar
Trade: Electrical Contractor
I would just connect the fans to each other and call it a day.
Zinsco is offline
Old 11-18-2009, 06:21 PM   #14
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Why even do that?
The HO will never go up in the attic and actually check your work.
Old 11-18-2009, 06:22 PM   #15
Illusion of Perfection
CookeCarpentry's Avatar
Mag - I've put a "y" connector right close to the exterior vent and then connected two runs into that. Kind of a last resort thing if they don't want two vents, etc.
Also, it's usually far enough down the run that backdrafting would not be a problem.
x2 with that Tin said about low spots. Also, think about insulated ducting if it is in an attic area.
CookeCarpentry is offline
Old 11-18-2009, 06:25 PM   #16
Service & Repairs
Magnettica's Avatar
Trade: Electrician
I was planning on doing it like I've always done it.... flexible aluminum.
Is that bad (really bad!) because the moisture meets the cold in air in the winter?
Old 11-18-2009, 06:26 PM   #17
Service & Repairs
Magnettica's Avatar
Trade: Electrician
I want to do it like a pro.
Old 11-18-2009, 06:26 PM   #18
I'll let an HVAC guy answer - just my opinion, but I do not like flexible aluminum - either ridgid or insulated.
Old 11-18-2009, 06:27 PM   #19
Then do what Zinsco suggested and connect them together...like you pointed out, slim chance the h/o is gonna check.
Old 11-18-2009, 06:28 PM   #20
Elite1's Avatar
Trade: Roofing, Siding, and Windows
I would defenatly install two 4" vents. I wouldn't short cut it. It would probably even take you longer to connect the two tubes together than it would be just to do it right.http://www.eliteroofingwi.com/
Elite1 is offline
Bathroom exhaust fan and minimum distance from shower Dustball Electrical 9 05-05-2010 10:12 AM
"LifeBreath" HRV as exhaust fan for bathroom? jarvis design HVAC 2 09-22-2009 06:02 AM
Bathroom Walls weeping... HELP hbl164 Painting & Finish Work 13 05-18-2009 12:37 PM
Codes for exhaust fan installations jarvis design Kitchens & Baths 0 01-18-2009 11:48 AM
