Bad Foundation
Old 11-11-2017, 07:02 PM   #21
John33's Avatar
Trade: Contractor
Re: Bad Foundation
If they do re-pour the wall, how will it be able to join the new wall with the existing walls? Is it possible to join concrete without leaks?
John33 is offline
Old 11-11-2017, 07:25 PM   #22
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 1,208
Re: Bad Foundation
It has to be tied in with rebar and epoxy then poured . If it's all prepared right I don't see it ever leaking, concrete sticks like **** to other dry concrete
cedarboarder is offline
Old 11-11-2017, 07:42 PM   #23
jomama's Avatar
Trade: Concrete & masonry
Rewards Points: 122
Re: Bad Foundation
DO NOT allow them to simply push that wall back to save them money, it needs to be replaced, and YES, you can replace part of the foundation w/o water issues. There's a number of products that can be applied to the existing wall before the new wall is poured, to assure it won't leak Sika "Swellstop"and "Voclay" are two products we've used in the past for exactly this. Obviously, it needs to be doweled together adequately as well.
I'll never understand why builders insist on pushing these things so fast when it's inevitable that eventually you're going to have an issue like this. We've been using bracing like this for years, it literally takes a minute to install each one, cheap insurance.
http://www.farrellequipment.com/foot...vice-footlock/
jomama is offline
The Following 2 Users Say Thank You to jomama For This Useful Post:
cedarboarder (11-11-2017), Fouthgeneration (11-11-2017)
Old 11-11-2017, 08:50 PM   #24
Frank Castle's Avatar
Rewards Points: 1,106
Re: Bad Foundation
Originally Posted by FrankSmith View Post
They can probably get it pushed back and repair the cracks. That still leaves you with a new yet repaired foundation and a bad taste in your mouth.
Originally Posted by rustyjames View Post
Sure, it can be "fixed" but it's not like you're ever going to unsee what happened. If it was my house the builder would have to give me something back, if that part of the wall is repaired.
Are you dead set on that lot? Looks like there's room around there.
Pick a different lot and start over. Let the "Well-Known Builder" have it for a spec.
Or as said, gotta get something back.
My late on-set of OCD would not let me live with that chit, again.
I lived with a fu^&ed shop floor that I had done. Got some $$ back.
Thought that would make me feel better. Every time I looked at that floor it pissed me off. Was kinda happy to move to a new shop. Not as big as the old one and missing some amenities.
But I don't have to look at that Fu^&ing floor anymore.
Adapt, Improvise, Overcome.
Frank Castle is online now
The Following User Says Thank You to Frank Castle For This Useful Post:
Old 11-11-2017, 09:35 PM   #25
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,341
Re: Bad Foundation
Get your money back NOW, and beat the rush when all the other silly things he did to "save" money become apparent to the masses in his "Quality" homes that will be know as the lemons they truly are.
Get another home builder, this one is a proven dud.
Where is the 2-3 inches of blue/pink board to keep the basement warm/Cool????
Where is the Damproofing coating on the basement???????
Why didn't the clown POUR the concrete floor PRIOR to backfilling and install the flooring to brace the walls at NO EXTRA COSTs?
This is a "totaled" home, you couldn't NEVER sell it with out revealing the defective foundation, Ask a banker that doesn't work with the house shacker if he'd loan money on home with a broken foundation, other then a repair loan.
Posting the picture of your broken foundation in front of neighbors houses revealed to the world this house is defective to all the World and where it is at....Act accordingly.
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
Frank Castle (11-12-2017)
Old 11-11-2017, 09:54 PM   #26
dayexco's Avatar
Rewards Points: 1,896
Re: Bad Foundation
i'm not an engineer, nor architect. but i've dug/backfilled hundreds, if not thousands of these. were that "my" house, i'd have that wall dug back out...sawed off at the corners, demo'd, repoured.
i'd never accept a repair on that bowed wall.
dayexco is offline
Old 11-11-2017, 10:26 PM   #27
JAH's Avatar
Trade: carpenter
Rewards Points: 1,824
Re: Bad Foundation
I would be calling my lawyer before the builder.
JAH is offline
Old 11-12-2017, 12:53 AM   #28
3bar's Avatar
Trade: carpenter
Rewards Points: 466
Re: Bad Foundation
i seen a wall get pushed in before. concrete guys used jacks to push it back out. then poured a square column in the middle next to wall to support it. that was 20 years ago and no issue since. of course it doesnt look the best, but it is what it is.
how many cracks are there?
3bar is offline
Old 11-12-2017, 04:21 AM   #29
brickhook's Avatar
Trade: masonry
Rewards Points: 7,566
Re: Bad Foundation
I will admit, when I looked at the picture, I thought maybe the concrete guys let their forms get away from them.
Thats a concrete wall with a rebar grid, and to be pushed in 4 inches after its already set, in my opinion, it certainly needs to come out and be repoured.
If you dont want to be the bad guy and have this conversation with the builder, the inspector will.
No inspector will let anyone build a house on on foundation like that.
Good Luck and keep us posted.
brickhook is offline
Old 11-12-2017, 06:00 AM   #30
builditguy's Avatar
Rewards Points: 406
Re: Bad Foundation
I've seen this before. The guy backfilling, ran the machine parallel to the foundation. Never good.
As far as insulation, there isn't enough in the picture to see that.
Waterproofing. Still not enough in the picture. If you could see the waterproofing, that would be another issue. I keep the waterproofing below the grade line. Nothing worse than seeing waterproofing sticking out above the grade.
If they used silicone waterproofing, you wouldn't see it anyway.
I've backfilled alot, at this point. Just never bowed a wall. Not uncommon to backfill before pouring the floor. They just did it wrong.
Just because some guy on a machine, screwed up your foundation, doesn't mean the builder is bad. At this point, you don't even know what his reaction is, or what he plans on doing.
Maybe he had already seen it and has been talking to the excavator. Maybe he hasn't seen it. The guy backfilled and the builder hasn't been out to see his work.
I think it could be pushed back out and the cracks sealed. Personally I would prefer to see that section removed and re-poured.
Somebody makes a water stop, to be used when two pours but up against each other. I've seen it specd in footings and I remember using it one time. I had to cut a notch in the existing concrete, stick one side in the cured concrete, seal it, then the new pour covered the rubber piece.
It's not uncommon to see pours in more than one section. Larger pours require this. Sometimes there just aren't enough forms.
builditguy is offline
The Following 3 Users Say Thank You to builditguy For This Useful Post:
Big Johnson (11-12-2017), overanalyze (11-12-2017), ProCarpenterRVA (11-16-2017)
Old 11-12-2017, 07:21 AM   #31
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 3,386
Re: Bad Foundation
Not to mention superior brand factory made walls are a bunch of small sections bolted together on site.
Big Johnson is offline
The Following 3 Users Say Thank You to Big Johnson For This Useful Post:
builditguy (11-14-2017), overanalyze (11-12-2017), SmallTownGuy (11-16-2017)
Old 11-12-2017, 07:46 AM   #32
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 890
Re: Bad Foundation
Just have a good, calm talk with your builder. Everyone makes mistakes and you don't really know who's mistake it is yet. I always tell my clients that the difference between a successful build and a stressful one isn't that one doesn't have any issues, it's that one handles the issues in a calm and professional manner.
overanalyze is offline
TxElectrician (11-12-2017)
Old 11-12-2017, 07:53 AM   #33
mstrat's Avatar
Trade: New Construction & Remodeling
Rewards Points: 1,424
Re: Bad Foundation
...a good lawyer's first question would be? "have you talked to the builder? what'd he say?"
...a bad one? "That's worth a couple million to you, yeah?"
Chat with the builder, chances are, if he's a decent reasonable 'reputable' builder like is stated he'll simply agree that's a problem and the GC, basement wall guy, and excavation company will all work together and deal with the problem. Crap happens, "call your lawyer first" is unfortunately what our world has come to...
mstrat is offline
The Following 2 Users Say Thank You to mstrat For This Useful Post:
overanalyze (11-12-2017), SmallTownGuy (11-15-2017)
Old 11-12-2017, 07:57 AM   #34
John33's Avatar
Trade: Contractor
Re: Bad Foundation
When walking along the wall, I see about 6 cracks (all from top-to-bottom), 2 of the cracks are on both corners. If the wall is saw cut at both ends and re-poured, will this be as structurally sound and leakproof as it was before the wall was damaged?
John33 is offline
Old 11-12-2017, 09:11 AM   #35
hdavis's Avatar
Rewards Points: 8,899
Re: Bad Foundation
My answer on this depends on whether It's in termite country.
hdavis is online now
Fouthgeneration (11-12-2017)
Old 11-12-2017, 09:44 AM   #36
Re: Bad Foundation
Your builder is going to have to get an engineer to draw up a repair. If he’s a good sized builder he’ll already have a suitable engineer in his Rolodex.
Did you hire the builder or just agree to buy one of his houses in his development? What State are you in?
Old 11-12-2017, 09:45 AM   #37
Re: Bad Foundation
Have a cracked foundation. The wall is bowed about 4 inches in, and cracked in several places, with some reaching top to bottom and all the way through. What are my options for this, is there an acceptable repair or should the foundation come down and be re-poured?
Is that an 8 tall wall? How long is it?
Old 11-12-2017, 10:08 AM   #38
JAH's Avatar
Trade: carpenter
Re: Bad Foundation
Crap does happen and in todays world & its all about legally protecting yourself. Thats just the way it goes.
Whats the harm in having your lawyer do a contract review & provide guidance for getting the issue resolved? I never said sue the builder!
A lawyer can also bring up concerns that the op may not have considered. For example how will a repaired foundation effect the value of a new structure.
JAH is offline
Old 11-12-2017, 10:15 AM   #39
General Contractor
greg24k's Avatar
Rewards Points: 7,334
Re: Bad Foundation
Footing settlement could also be the issue, is there a vertical crack in the footer also?
greg24k is offline
Old 11-12-2017, 10:58 AM   #40
Renaissance Man
superseal's Avatar
Rewards Points: 5,354
Re: Bad Foundation
What a crap job...doesn't anyone utilize pilasters anymore?
supersealconstruction.com
superseal is offline
The Following 3 Users Say Thank You to superseal For This Useful Post:
Fouthgeneration (11-12-2017), overanalyze (11-12-2017), shanewreckd (11-13-2017)
Newly Poured Foundation Looks Like THIS? HouseBurnedDown Masonry 1 09-23-2017 07:58 PM
any foundation pros here? mikemane General Discussion 4 12-13-2012 09:58 PM
foundation repair question ctcarpenter Masonry 26 06-25-2012 05:25 PM
Foundation Question kuponoconstr Construction 1 02-17-2010 07:04 AM
