Bad Foundation
Old 11-11-2017, 09:32 AM   #1
John33's Avatar
Trade: Contractor
Bad Foundation
Have a cracked foundation. The wall is bowed about 4 inches in, and cracked in several places, with some reaching top to bottom and all the way through. What are my options for this, is there an acceptable repair or should the foundation come down and be re-poured?
John33 is offline
Old 11-11-2017, 09:37 AM   #2
rustyjames's Avatar
Rewards Points: 1,426
Re: Bad Foundation
Man, what a shame. They not only back filled, they REALLY back filled. If it was my foundation I'd want that side of the foundation replaced.
rustyjames is offline
The Following 8 Users Say Thank You to rustyjames For This Useful Post:
Bull Trout (11-11-2017), dayexco (11-11-2017), fjn (11-13-2017), Fouthgeneration (11-11-2017), FrankSmith (11-11-2017), Jaws (11-19-2017), SmallTownGuy (11-13-2017), Workingmanvan (11-24-2017)
Old 11-11-2017, 09:37 AM   #3
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 1,710
Re: Bad Foundation
Did you pour that?
Delta
I have an Edifice Complex.
Old 11-11-2017, 09:47 AM   #4
slowsol's Avatar
Rewards Points: 2,190
Re: Bad Foundation
Did they shore before they backfilled?
-John
slowsol is offline
Old 11-11-2017, 10:14 AM   #5
John33's Avatar
Trade: Contractor
Re: Bad Foundation
The whole foundation was poured as one piece, is it possible to replace one wall?
John33 is offline
Old 11-11-2017, 10:16 AM   #6
John33's Avatar
Trade: Contractor
Re: Bad Foundation
No, this is my house and a well-known builder is building the house.
John33 is offline
Old 11-11-2017, 10:17 AM   #7
John33's Avatar
Trade: Contractor
Re: Bad Foundation
No, it was not shored.
John33 is offline
Old 11-11-2017, 10:43 AM   #8
improving homes
platinumLLC's Avatar
Trade: Roofing/Remodeling
Rewards Points: 256
Re: Bad Foundation
What did this well known builder say about this? Sounds like somebody screwed up.
platinumLLC is offline
Old 11-11-2017, 10:47 AM   #9
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 1,123
Re: Bad Foundation
I’m pretty sure they can fix that. You’ll have to reexcavate then get your foundation guy back out. Fire your original excavator. You can’t backfill a long straight wall like that more than 4’ deep without bracing. If it had to be backfilled he should have done the corners then only 4’ up on the long run.
How long did it cure before he backfilled?
Big Johnson is offline
SmallTownGuy (11-14-2017)
Old 11-11-2017, 11:16 AM   #10
John33's Avatar
Trade: Contractor
Re: Bad Foundation
No, I notified them yesterday, they will get the message on Monday.
John33 is offline
Old 11-11-2017, 11:18 AM   #11
tgeb's Avatar
Rewards Points: 246
Re: Bad Foundation
I agree, that wall can be repaired.
It needs to be excavated, pushed back out and the cracks should be pressure injected with epoxy.
Though it is poor practice to backfill prior to the slab and first floor deck being installed, in tract housing the foundations are typically backfilled within days of the concrete placement.
www.gebcon.com
tgeb is offline
The Following 2 Users Say Thank You to tgeb For This Useful Post:
Old 11-11-2017, 11:18 AM   #12
John33's Avatar
Trade: Contractor
Re: Bad Foundation
It cured for 7 days before backfilling
John33 is offline
Old 11-11-2017, 11:32 AM   #13
John33's Avatar
Trade: Contractor
Re: Bad Foundation
Will the foundation be as structurally sound as an fully intact foundation, with the epoxy injection? I attached a picture of one of the crack
John33 is offline
Old 11-11-2017, 12:06 PM   #14
MeanWeen's Avatar
Trade: City worker
Rewards Points: 24
Re: Bad Foundation
Is should be fine, but I agree if you didnít do the work get them to fix it. You guys donít do any water proofing on wall like that?
MeanWeen is offline
Old 11-11-2017, 12:54 PM   #15
Krok's Avatar
Trade: Mold Generator
Rewards Points: 844
Re: Bad Foundation
Some people have to wait decades to get that sort of "distressed" look at the corners of their foundation.
Any crack fill will fill it, but won't address the bow. I'd line it to see if it's something you can work with framing wise and they may have to add a little to the outside where it's in too far, providing there's enough bite for the bottom plate.
Excavation/landscaper may have to put a little extra attention there to make sure there won't ever be any back pressure there.
Can't see if there's a beam pocket there or not, but if so, and depending where the bow is relative to it, might want to put a counterfort under that then hide it in a small wall under the beam for cosmetics.
Then discount all of this off of your bill.
But I'm not a concrete guy, just a mold generating unlicensed remodler without insurance that can do whatever you need done!
"Nobody is more inferior than those who insist on being equal" -Friedrich Nietzsche
Krok is offline
Old 11-11-2017, 06:20 PM   #16
B.Johnson's Avatar
Trade: Builder
Rewards Points: 416
Re: Bad Foundation
Tough situation. Talk to the builder and if you don't get any satisfaction, then ask for a meeting with the builder and the inspector. As mentioned before, they shouldn't have back filled it that high without bracing. I'm not going to suggest a fix except to say that while "Any crack fill will fill it", you want a structural solution, not a cosmetic one.
Home Designer Series Software
B.Johnson is online now
Old 11-11-2017, 06:25 PM   #17
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 1,828
Re: Bad Foundation
Oh man, its exposed too...
jackhammer and redo?
Definitely only need to do the one wall.
cedarboarder is offline
Old 11-11-2017, 06:25 PM   #18
FrankSmith's Avatar
Rewards Points: 4,132
Re: Bad Foundation
They can probably get it pushed back and repair the cracks. That still leaves you with a new yet repaired foundation and a bad taste in your mouth.
FrankSmith is offline
Old 11-11-2017, 06:32 PM   #19
Trade: Workaholic
Re: Bad Foundation
sure it can be pushed back and crack patched. Needs a structural engineer at this point if this was in my City.
More prone to foundation leaks.
And will never look right patched.
The Following User Says Thank You to cedarboarder For This Useful Post:
hdavis (11-12-2017)
Old 11-11-2017, 07:53 PM   #20
rustyjames's Avatar
Re: Bad Foundation
Sure, it can be "fixed" but it's not like you're ever going to unsee what happened. If it was my house the builder would have to give me something back, if that part of the wall is repaired.
The Following User Says Thank You to rustyjames For This Useful Post:
fjn (11-13-2017)
Newly Poured Foundation Looks Like THIS? HouseBurnedDown Masonry 1 09-23-2017 08:58 PM
any foundation pros here? mikemane General Discussion 4 12-13-2012 10:58 PM
foundation repair question ctcarpenter Masonry 26 06-25-2012 06:25 PM
Foundation Question kuponoconstr Construction 1 02-17-2010 08:04 AM
