Bad Day
Old 11-25-2008, 08:21 PM   #21
General Contractor
sivak's Avatar
Trade: Carpenter/Builder
Re: Bad Day
Originally Posted by nlgutters View Post
This was a kit. Made taken apart then reassembled. They chinked every joint and lookes like siliconed the ends of the logs where they are cross hatched. I couldnt believe how easy the water went in. I swear you could throw a glass of water at it and it would run in the house,
I don't see how you could be to blame,after all a structure should be designed water tight at the wall line no matter what.Unless you made the water run into the house at the gutter to eave connection they just have some bad building practices.On a project that or any size in todays world,it should not leak,no matter what the heck it's made out of...
www.taylorandignathomes.com
sivak is offline
Old 11-25-2008, 08:57 PM   #22
nlgutters's Avatar
Trade: seamless gutters
Re: Bad Day
Originally Posted by RayGoerdt View Post
are you sure that the water is not coming in from the roof? it is possible that it could be entering the roof system from a chimney or vent pipe flashing, running down the ceiling untill it hits the top of the wall and then down an electrical run in that wall, from there it could spread out.
unless there are cracks thru the logs that have not been sealed.
Can you get photos?
Not from the roof. You can stand inside its coming in about a ft below the roof line. By sealed do u mean chincked? If so they did that a week ago.
nlgutters is offline
Old 11-25-2008, 09:21 PM   #23
RayGoerdt's Avatar
Trade: Residential building/Remodeling
Send a message via AIM to RayGoerdt
Re: Bad Day
sometimes during drying the logs will split along a grain line, in rare instances, the split will go most or even all of the way thru the log.
I have seen one time where the ho claimed window flashing was bad and causing water leaks inside, but it turned out to be a severe check line in the log that allowed the water to run thru the log and into the cabin.
RayGoerdt is offline
Old 11-25-2008, 09:38 PM   #24
nlgutters's Avatar
Re: Bad Day
Could be. Either way its a big problem. I just cant believe that water just leaks in like that. On a regular sided house that would never happen
Old 11-25-2008, 09:50 PM   #25
dirt diggler's Avatar
Trade: contractor
Re: Bad Day
NL
are you truly worried??
Gutters or not - sounds like the house leaks. Kinda like blaming the ambulance for not putting out the fire.
Thanks in advance!!!
dirt diggler is offline
Old 11-25-2008, 10:05 PM   #26
RayGoerdt's Avatar
Re: Bad Day
If this was my job, I would be concerned, not to the point of losing sleep but I would certainly try to find out how and where the water entered. It is often times not enough just to say it is not my fault some times you have to be able to demonstrate it. although the gutters may not be the total problem, they may have been a contributing factor in this situation because they may have directed extreme amounts of water to the building that it would not normally have to deal with.
Old 11-25-2008, 10:32 PM   #27
nlgutters's Avatar
Re: Bad Day
100% agree. Yes they didnt help the situation at all bringing all the water too one area. They have a problem and this really just brought it out. This winter will prove that. A couple of ice dams built up next to all the walls and it will be pouring in.
But still they look at me like its all my fault. I think it will be fine after thety calm down. they had a bad day today. The ground was frozen and with 4" of rain the water was about 1' deep around the house. They had to just open the tops of the permiter drains to let the water out.
Just listening to the news we got 4" of rain today. They weather yesterday said we would get showers.
Old 11-26-2008, 07:44 AM   #28
RayGoerdt's Avatar
Re: Bad Day
love that weather forecast!
Old 11-26-2008, 09:46 AM   #29
Burby's Avatar
Trade: Remodel / repairs / Certified Mold inspector, Remediator
Send a message via AIM to Burby
Re: Bad Day
Originally Posted by Ed the Roofer View Post
Wouldn't a valid assumption be, that any reasonalble man would have considered the exterior product on a home to be adequately water-proof?
Don't just lie down and bite the bullet on this.
Were your guttering actions unreasonable?
Did you directly cause the water to seep into the structure, or was a lack of proper water=proofing the culprit?
This sounds like an, "Act Of God/Nature", which should fall under the home owners insurance policy, not the contractors liability policy.
But, that will probably be a matter best left to subrogate between the two different insurance companies.
Document what you have done with detailed photos and keep accurate records of all conversations.
Ed
I have to agree with the above. All the litagation work I have done, I would be amazed if you could be held liable for anything based on what you explained.. lol, if you are gutting the inside of a any home, log cabin or not, how can you or anyone be held liable for moisture intrusion if you have not worked on the outside of the home??? This is where I get my kitty look from.. lol
And the other thing is, log cabin or otherwise, unless before codes were enforced, how did this ever get a C/O is weather is able to gain entrance to the interior?? While gutting if not before, there had to be signs of previous moisture intrusion and was this ever mentioned to you while considering the job?
Something is not right here...
Proud to help make a house your Home
Never judge another by one's own intelligence
Burby is offline
Old 11-26-2008, 09:56 AM   #30
Burby's Avatar
Re: Bad Day
--=oop si daisy, I guess I should have looked to see if there was a page 2 before I posted a reply.. lol, but I guess because it amazed me as it did, I had to reply..
But you just stated the answer above.. "They" chinked a week ago. It is "they" that needs to be concerned as "they" where responsible for the dry in. And as long "they" did not work for you, you have no worry about responsibility. "They" may want to contact their insurance company or double check their agreement / contract.
If this has added any cost to you from delays to any losses, note them.
And hopefully regardless of everythig else the job can move forward.
Is there a Prime, or General Contractor on the job or are the H/Os handling everything?
Burby is offline
Old 11-26-2008, 11:26 AM   #31
RayGoerdt's Avatar
Re: Bad Day
He is Gutter ing, not gutting
Old 11-26-2008, 11:55 AM   #32
Burby's Avatar
Re: Bad Day
ohhhhh gutt er ing, as in installing rain gutters, seamless gutters, ect.. So sorry, my many apologies, seriously said & thanks for clearing that up for me.. I knew I needed to get new glasses and is a good reason for me to make a point to get some today, thank you..
Still, answer is the same in most respects, in my opinion, not his fault or problem, though shows he does care about his work to care about something beyond his control.
Gutter companies, like window & door companies seem to take the blame for so many things beyond their control.
For this reason I stopped having gutters installed on all new homes I built. I would offer the H/O names of reptuable installers "they" could hire after closing, but not as a part of the build.
In the Southeast, if it is wood and not treated, it can & will rot in turn attracting termites & lawyers. Even after switching to treated lumber for the facial, I still would not have gutters installed as part of the build, because someone would blame the gutters for paint peeling behind them. Have diverters installed on the roof above doors, that is it.
Windows & doors, I would work with my installer and inspect each opening for proper wraping & flashing installs.
Thanks again for clearing that up.
Burby is offline
Old 11-27-2008, 08:28 PM   #33
Ten Fingers's Avatar
Trade: carpenter, builder
Re: Bad Day
Log homes are fantastic if the builder knows what he's doing.
Ten Fingers is offline
Old 11-30-2008, 01:08 AM   #34
RayGoerdt's Avatar
Re: Bad Day
Very true
Any news on this situation?
Old 11-30-2008, 10:56 AM   #35
tinner666's Avatar
Re: Bad Day
I was under te impression log homes had 18" to 24" overhang at the eaves?? If so, the roof is leaking or the gutter end is dumping water on the ends that have the 'lincoln-log' look. Pics would be helpful.
Frank Slate Roof Repairs, Richmond, Va.
tinner666 is offline
Old 12-19-2008, 07:50 PM   #36
framer6262's Avatar
Trade: carpentry
Re: Bad Day
Just wondering what everyonelse is getting per ft of seamless gutter/ downspout?
framer6262 is offline
Old 12-19-2008, 07:56 PM   #37
Fentoozler
Celtic's Avatar
Re: Bad Day
Slightly less than blown in insulation.
Celtic is offline
Old 12-19-2008, 08:28 PM   #38
RayGoerdt's Avatar
Re: Bad Day
Depends, if its aluminum I get the going rate per pound at the recycle yard, if its vinyl, I have to pay to get rid of it.
Old 12-21-2008, 01:07 PM   #39
inthegutter's Avatar
Trade: Seamless gutters & leafguard systems
Location: Northwest NJ (Where the weak are killed & eaten)
Re: Bad Day
Nl- What size gutters did you use and why did they clog/overflow? I've seen similar situations caused from using 5" gutters where 6" were needed. If the water flowed to the drain, it should have flowed through it. Either way, the house should never have leaked like that.
inthegutter is offline
Old 12-22-2008, 01:32 PM   #40
Tom Struble's Avatar
Trade: siding
Re: Bad Day
silicone on wood? were the logs prefinished?
Tom Struble is offline
