Trade: builder/carpenter
Azec Vs Kleer
Doing a biggie exterior all in plastic trim. first time for me in All Plastic... Crowns ,dentils, frieses, aprons, etc.
Any preferences between the two(Azec,Kleer) Any tips as far as glue-ups ,Long runs, milling, etc. would be much apreciated. Job is in New England Thanks IA.... G. |
KemoSabe
Re: Azec Vs Kleer
I've used Kleer on one occasion. It seems like a decent product. However, I have put up literally thousands of feet of Azek and can tell you it is a great product to work with. It machines with common woodworking tools and fastens no differently than wood. You will experience some thermal expansion/contraction of the product, especially where exposed to direct sunlight. I use an adhesive called "Christy's Red Hot" to join all connections. It softens the material and literally welds the joint together. Feel free to PM me with any specific questions. Also, there are a few threads going on the subject.
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
Re: Azec Vs Kleer
Like loneframer said, its a great product, kleer is just as good,but azek now you can get it with 4 sides finished!!
i also used certainteed restoration board on my last bay window job and ended up saving a few dollars but the prduct was really sweet to work with!! SHOP AROUND if you need alot of footage, you can negotiate alittle!! money in your pocket
The Bitterness of Poor Quality Remains longer Than The Sweetness Of A Low Price Is Forgotten
The Deck Guy
Re: Azec Vs Kleer
PVC trimboards have become a commodity item for lumberyard purchasers. Azek, Versatec, Kleer....whatever. Same stuff more or less. They just buy the least expensive stuff they can stock.
Re: Azec Vs Kleer
I have found Azec and Kleer to be comparable in quality, even though it was harder to find Azec was more cost effective.
I watched a demonstration of Azek being bent nearly into a pretzel and with the slightest strike of a hammer you then have 2 pieces of trim. |
Re: Azec Vs Kleer
I like kleer cause the boards are individually wrapped. Does your Kleer rep happen to be Joe Macaroni?
Trade: siding
Re: Azec Vs Kleer
the kleer supplier tried to tell me the core of thier product was more consistant or some such b.s.i cut them both they look identical to me
Tom |
Trade: Architectural/Historic Restoration and Preservatio
Re: Azec Vs Kleer
I went through this same process several years ago. I looked at just about every cellular pvc product out there and evaluated them on numerous criteria. Koma was ruled out early, as I needed a material that could be milled, not just dimensional trim boards. Ultimately, the contest for me was between Kleer and Azek. Both companies are reasonably local. I always try to support local/regional/domestic... Azek is based in PA, where I was born and raised and Kleer is based in MA, where I ultimately settled. Honestly, my first call and tests were with Azek; at the time they were 'hands down' the market leader while Kleer was basically a brand new company. The particular project that I was gearing up for was a big one and demanded the absolute highest standards in craftsmanship, durability, and longevity. Additionally it was probably the highest profile project that we had taken on to date. If I was going to use cellular pvc, it was going to have to last. Like most of us, my teeth were cut over the last several decades mastering the use of wood in myriad contexts. I know wood. I understand wood. Every board is more or less predictable by species, moisture content, grain, grade, etc. This PVC stuff really felt like a gamble, but one which seemlying offered huge upsides. Between my company and several other contractors in my area, there was a wealth of local knowlegde, born out of our collective experience installing cellular pvc trim as typical replacement/substitute for primed pine or painted western red cedar in the most standard and straight forward of applications. Going to the next level required, for me, refining my understanding of cellular pvc. Just like wood, Cellular PVC's durability, longevity and appearance is just as dependent on the raw material as it is on the craftsperson(s) doing the installation. Switching from, in this case western red cedar to Cellular PVC was going to require support from the supplier. This is where Kleer dominates hands-down. I was invited to tour their plant, meet with their head engineer, had and have frequent visits to my sites by the regional sales rep. The access to Kleer's people, expertise and support is second to none. Beyond that, Kleer recycles all my scraps and the PVC saw dust produced in the milling and installation processes. This is a big sell for my clients, most of whom want a green product. Since switching from Azek, we have installed literally 1000's of square feet of Kleer. I made the right choice and I do not regret it. If I figure out how, I will try to post a few pictures.
Spires & Co. Architectural and Historic Restoration, Preservation, Design, and Consulting http://www.spiresco.com/ |
Carpenter
Re: Azec Vs Kleer
There's only one thing I would buy from a guy named Joe Macaroni
"An idea is salvation by imagination" Frank LLoyd Wright |
| Azec (plastic) Trim Boards | Bukemdano | Windows, Siding and Doors | 26 | 11-15-2009 10:36 AM |
| Hardi Board | Bigbobdallas | Carpentry | 7 | 11-12-2009 06:42 PM |
