Anyone Familiar With This Product
I am meeting with the rep for this product on mon morning, i am considering it for my own house, any thoughts?
http://www.sealoflex.com/files/pdf/2...o%20System.pdf
Re: Anyone Familiar With This Product
keep us updated
I'm a Mac
Trade: ICF Construction
When new products come out such as this I like to see an ICC report, it raises my comfort level.
Chris |
Trade: masonry
Something that might interest you is fossilcrete. I went to a demo and tried doing some and its pretty nice looking and easy.
Its also waterproof and very customizable as far as color goes.
Kamps Masonry & Concrete Countertop Design Green Bay, WI 920-680-3195 Visit our website @ http://www.concretecountertopsdesign.com/ |
Would it hurt your feelings if I called it junk?
It ain't Rocket Science unless you are building rockets. |
Fossilcrete looks to be better, but I don't like the use of expanded polystyrene keystones and accessories. They do at least specify lathing.
Re: Anyone Familiar With This Product no it does not hurt my feeling, i did not invent the stuff, i am just interested in it. what dont you like about the product that makes you call it junk?
If you are buildng a Best Western hotel to flip, or plan on building future slum housing, then this is a great product. It is cheap, as well it should be.
Basically, you have plywood coated with a primer and then 1/4" of acrylic finish. That is the whole "system".
#9 | |
Re: Anyone Familiar With This ProductQuote:
Aside from looks, the system provides no way to flash. It is a skin and relies on perfection of that skin to prevent water penetration (which is the ultimate goal of any exterior finish). Any water that does penetrate has no path to leave the wall. Expansion and contraction issues are not dealt with at all in their literature, that I could find. Etc., etc.
It's primary virtue is that it is cheap.
Trade: roofing contractor
Ok here is an educated answer to your question.Sealoflex is a great product except for one huge issue.It is extremly flamable and can and will ignight without a spark I know a lot of contractors who have had roof burst into flames using this product.Sealoflex is an solivant based product.You should use HydroStop instead.HydroStop is a green building product and is water based.Sealoflex and HydroStop used to be the same company untill they split apart.HydroStop and Sealoflex both have no wind resistance because it is fluid aplied and become intigraded together to form one complete system with no seams.If installed in white it high albedo will break down and reflect 60% of the heat from your roof.You can also get 50.00 per sq back from you electric company for using it on residential applications and 45.00 per sq on commercial applications.It is EnergyStar approved Factory Mutaul Approved and in my opinion is the roof of the future and will ultimatley take over the flat roofing industry.HydroStop also covers the entire building envolope from below grade foundation to stucco. Hydrostop also has a 10 and 20 year renewable warranty for certified contractors and the HydroStop rep will com out to every job no matter how big or small to do an in progress inspection and a final inspection required for the warranty.That say alot for a manufacture considering they are the only one that will warranty LABOR and MATERIAL.Also I want to add they are not a new company and are on there third life cycle (30 years.)
Um, wrong product, PRC.
They do the whole building envolope including Stucco
#14 | |
Talk to the rep, raise the issues I have and see how they are addressed. For building, I am not a fan of any system that only reduces cost. What are the specific advantages of this, excluding cost?
Both these systems are self flash and are ran directly up the wall with renforced fabric They are also the oly one that cover the entire flashing detail in there warranty no other system covers more than six inches up a wall you can also run the product up and over paraphat wall and install a coping cap.Also the expandind and contracting issues is the reason HydroStop will only let you use there fabric because it also is the only system that has fabric that will expand and contrct without cracking
thats why i want to meet with him, thanks for raising these issues, i will definately ask him everything we have discussed.
#18 |
so the reps came over yesterday, they of coarse had an answer for every concern i had, they think there product is superior to eifs in every way, it is a totally breathable , and 100% waterproof system, the rear drainage plane is not a concern with this system, which i like because who wants to deal with water and moisture after it beats the primary siding. top of windows are flashed as with any other siding. special tapes and coatings butt to the sides of windows for waterproofing, denshield is the recomended substrate. the color selection is extensive, the product is flexable, and has been around for many years, cost for mat, about $2 a sqft. i like what i see , so far. FIRE AWAY!!!!G
#19 |
Did you ask for the address of a five year old building? A ten year old one?
#20 |
Trade: Exterior Lighting
No idea, but watch out. I would wait to see a report on it first.
| Too much product | Tom M | General Discussion | 7 | 09-05-2007 03:13 PM |
