Adjusting Pocket Doors
Old 07-28-2009, 04:39 PM   #1
Finishing Carpenter
Mrmac204's Avatar
Trade: finishing Carpenter
Got a client who has a 12 yr old home. 4 pocket doors, all dragging on the ground at one end or the other. I need that little wrench! or some such thing - gonna have to remove the trim on one side, and swing the door out so I can get access to the hanger bolts.
Is there anything else that will work here if I can't find that wrench?
thx
Laurie
lauriescustomfinishing.ca
Mrmac204 is offline
Old 07-28-2009, 04:46 PM   #2
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Re: Adjusting Pocket Doors
check at your hardware store.
They usually have replacement parts along with that wrench
Gus Dering is offline
Old 07-28-2009, 05:31 PM   #3
jtpro's Avatar
Trade: Construction Assistant Superintendant/Remodeler
I picked up a set of xtra long handled, xtra long headed needle nosed pliers at HF for a bout $7. Haven't tried them on a pocket door but wish I had them for when I had worked on them.(That's about ALL HF is good for but just the same)
As far as "the wrench" must of been sleeping in class when they talked about it. I've never seen or used said wrench and haven't seen anyone with one.
Maybe THAT'S why so much cussing was involved!
jtpro is offline
Old 07-28-2009, 05:40 PM   #4
D.Foster's Avatar
Trade: Carpentry & Remodeling
Thats why i always screw in one side of the head jam instead of nailing it. Then no trim needs to be removed.Even though the painters still want to fill the screw holes!!
But i would check the store as mentioned by gus
Do what you would do, as if i won't Do anything after you Did It!
D.Foster is offline
Old 07-28-2009, 05:42 PM   #5
D.Foster's Avatar
The wrench usually comes with the pocket door kit, at least with the johnson door kit
D.Foster is offline
Old 07-28-2009, 06:19 PM   #6
Money Changer
bert0168's Avatar
Trade: Residential Remodeling
Another tip. I always use a small washer and drywall screw to screw the wrench up inside the head at the end of the track. That way if I need to readjust later, the wrench is always there.
bert0168 is offline
The Following 6 Users Say Thank You to bert0168 For This Useful Post:
bonz (08-02-2009), D.Foster (07-28-2009), loneframer (07-28-2009), Mellison (07-28-2009), PGD (08-01-2009), WarriorWithWood (07-31-2009)
Old 07-28-2009, 09:53 PM   #7
Finishing Carpenter
Mrmac204's Avatar
thanks guys I do have some long handled "bent nose" needle nose pliers, so that might do the trick. My backup plan is to go to a dedicated kitchen hinge/hardware store in Richmond (bout 30 miles from me) I think they have the gadgets.
f all else fails, gotta small piece of metal, bend, file beat
Laurie.
Mrmac204 is offline
Old 07-28-2009, 09:59 PM   #8
mmike032's Avatar
Trade: trim carpentry
go to a door supplier or whereever sells pocket doors and ask them for the wrench.
I keep a few in my trailer for this reason
mmike032 is offline
Old 07-31-2009, 09:53 PM   #9
Finishing Carpenter
Mrmac204's Avatar
well it went great, 4 doors turned into 7 doors! LOL I just removed the "head" stop, which gave me access to the nuts/hangers. pinned it back on, little bit of filler and on to the next one. Two doors I had to completely remove (one was missing the bogey wheels, other the bracket was torn off) client went out and got the wheels (first at home depot, they sold him the wrong item, so to a local lumberyard where they had the right item) They fed me pizza for lunch too great day!
6 1/2 hrs, 350 man I need more clients like that
Laurie.
P.S. the long needle nose pliers with the bent nose worked like a charm, particularly for the "top" nut. Bottom nut I was able to use a skinny 7/16 wrench.
Mrmac204 is offline
Old 07-31-2009, 11:05 PM   #10
Tech Geek
WarriorWithWood's Avatar
Trade: Property Management/Facilities Manager
You were lucky, it seems every pocket door I've fixed had the head run over the legs.
-Dennis
www.bowmanch.com
WarriorWithWood is offline
Old 08-01-2009, 12:22 AM   #11
jtpro's Avatar
Laurie.
I BELEIVE the proper/polite thing to do is to have shared said pizza with those of us that were "here" for you!
YEAH PIZZA
jtpro is offline
Old 08-01-2009, 01:31 AM   #12
mics_54's Avatar
Trade: contractor
IF IT WAS EASY..anyone could do it.
mics_54 is offline
Old 08-01-2009, 09:21 AM   #13
Finishing Carpenter
Mrmac204's Avatar
well it did, the stop is about 5/16" thick x 3/4 wide- cut the paint on the outside with a sharp utility knife, then pryed it off from the inside- slowly! this stuff bends, so I was able to bend it enough to get one end out, then it was just a matter of wiggling it out of the opposite end. Original installer used about 3 18 ga nails per piece.
YEAH PIZZA
you want me to send pizza all the way to Florida???? oooookkkkk then, but it'll be cold LOL
Ya! its what keeps trades guys goin!
Mrmac204 is offline
Old 08-01-2009, 11:15 AM   #14
jtpro's Avatar
NOT the first time I ate cold pizza (EVEN a local delivery!)
and YET I keep my "girlish figure"
Glad it turned out 4 ya.
jtpro is offline
24" exterior doors - where to buy? Panzer5 Carpentry 11 05-07-2009 08:43 AM
Recessed Door Handle for Pocket Doors. My Chisel on compressed would looks hacked personalt Finish Carpentry 14 03-03-2009 07:15 PM
century old wooden doors joeslob Sandblasting 8 01-25-2009 03:08 PM
pocket doors MO-AMPS Carpentry 3 03-14-2008 05:11 PM
How many Pocket Doors are enough?? woodbutcher2004 Finish Carpentry 14 02-14-2008 07:47 PM
