Adding 12" To Casions
Old 08-18-2008, 06:38 AM   #1
Jarrow's Avatar
Trade: residential homes
I'm adding 12" to existing deck casions where a landscaper has raised the dirt and covered the deck posts. The post have rotted so we are cutting them above the damaged bottoms and raising the casions.
The subcontrator will be mixing the concrete by hand on site.
My concern is this... i don't want the the new portion of the casions to fail in the future.
What kind of concrete mix should he use... I am concerned with honey combing and cracking where water may get in and cause the casion additions to fail.
Should he use aggregete in the mix... or is just sand ok?
would anyone suggest a concrete recepie?
any other tips?
thanks in advance!
Jarrow is offline
Old 08-18-2008, 07:27 AM   #2
genecarp's Avatar
Re: Adding 12" To Casions
jarrow, there should not be a problem, quickrete makes a 5000psi bagged mix, that would be a good choice, just make sure you drill something like rebar into the top of the existing footing. here is a site that has some good bonding products if you are still not comfortable, but it is probably overkill, welcome to ct.
http://www.sanitred.com/ConcreteRepair.htm
genecarp is offline
Old 08-18-2008, 08:07 AM   #3
Bob Kovacs's Avatar
Trade: Consultant
As Gene said, I'd put some rebar down into the existing and extend it into the new. I'd also have the new top portion be larger than what's below it, essentially "capturing" the existing pier rather than just trying to extend it upward.
Bob Kovacs is offline
Old 08-18-2008, 12:11 PM   #4
This is one of the rare occasions where
I have to question you Bob.
Don't know where Jarrow is, but in this
part of the world creating a "collar" above
frost line is asking for trouble IMO.
Allowing the larger top portion to
"heave" off the lower section.
Collars on posts and footings are always
problematic from my obsevations in
this climate.
neolitic is offline
Old 08-18-2008, 12:34 PM   #5
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
This may sound like a lot of over kill, but make sure you bend a 180 loop on the top of the rebar and epoxy the bottom into the existing. Make sure the mix is not too dry and rod it into place to ensure it gets locked onto the rebar.
That puppy won't go anywhere
Chris
Chris Johnson is offline
Old 08-19-2008, 12:02 AM   #6
wyoming 1's Avatar
Trade: General contractor
If you are worried about honey comb take a pad sander without sandpaper and use it to vibrate the outside.Do not over vibrate it or you may blow out( or swell) your sonotube.
wyoming 1 is offline
Adding 400 amps to Commercial Bldg Bubbles Electrical 10 08-22-2008 06:39 AM
adding pitch to a flat roof. PAPERSTREET Roofing 3 03-07-2008 08:38 PM
adding to a ciruit Bkessler Electrical 9 01-27-2007 10:28 PM
adding 2nd story to block house 72chevy4x4 Construction 3 01-21-2007 09:20 PM
