4" Hole In Brick - General Discussion - Contractor Talk
4" Hole In Brick
Old 02-25-2018, 10:51 AM   #1
90%-er
onmywayup's Avatar
Rewards Points: 1,606
4" Hole In Brick
Need to make a 4" hole in some brick to get a bathroom vent duct through.
I've got the badass Bosch Bulldog hammer drill, just wondering what kind of bit I need here?
Diamond tip hole saw? Or make a series of smaller holes and chisel it out?
onmywayup is online now
Old 02-25-2018, 11:01 AM   #2
Fugetaboutit
Lunicy's Avatar
Trade: Professional fixer upper
Rewards Points: 422
Re: 4" Hole In Brick
If you are just going through red brick, most big box stores will sell a core bit with carbide teeth for your Bulldog. I believe your bulldog is an SDS-Plus. This is a bit hard on it. I've done it before, with a cordless Milwaukee SDS Plus, but it's rough on the tool. Go slow, collect dust with a vacuum. (you don't want to be sneezing red dust for the next 3 days).
You are just doing 1, correct? If you plan on doing several, get the right tool.
ALSO, if you are running a dryer vent, you should make a 4 1/4 hole.
I've seen folks drill out a bunch of small holes in a circle, then chisel. It's kinda sloppy. Not precise at all. You may break off the area you need to anchor the hood to. If you use a core, it will make a very clean, precise hole.
Lunicy is offline
Old 02-25-2018, 11:10 AM   #3
90%-er
onmywayup's Avatar
Thanks. Need a good clean hole if possible, although it won't be visible from either side when I'm done with the back draft stopper and caulking around it.
This is for a basement bathroom vent fan. I'll check Depot tomorrow for that hole saw.
It is only one hole and I can take all the time I need on it. I'll bring my dust collector to keep it manageable.
Old 02-25-2018, 11:12 AM   #4
rustyjames's Avatar
Rewards Points: 1,580
While a core bit hole would certainly be cleaner, it could be done "good enough" with a series of holes and finished with a chisel. Most vent kits have some kind of collar that would hide even the sloppiest holes.
rustyjames is online now
The Following 2 Users Say Thank You to rustyjames For This Useful Post:
Framer53 (02-25-2018), Randy Bush (02-25-2018)
Old 02-25-2018, 11:51 AM   #5
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,238
Last one I did was this way, turned out ok .
Randy Bush is online now
Old 02-25-2018, 12:47 PM   #6
Pearce Services's Avatar
Trade: Commercial Loading Dock and Door Contractor
Rewards Points: 58
About a year ago, I bought a 4" diameter core bit that threads into a 7" grinder, and it is a bit slower, but once it started to grab, it cut nicely, for occasional holes brick it would be a good investment $150 I got mine at Pro Tool in Waltham MA I cant remember the brand
Kevin
www.BadcoDoors.com
Pearce Services is online now
Old 02-25-2018, 02:48 PM   #7
tjbnwi's Avatar
Rewards Points: 4,994
You should use a 4-1/8" holes saw for the duct.
I use a Bosch;
https://www.homedepot.com/p/Bosch-4-...G418/203570978
tjbnwi is online now
Old 02-25-2018, 04:42 PM   #8
90%-er
onmywayup's Avatar
Thanks fellas. I'm gonna buy the 4 1/8" bit. This is the third or fourth time I could have used it. The other times we just came up with alternative plans, but there really are no other good options on this house. I know we'll use it again in the future.
And I'm kinda looking forward to drilling it, in a weird way. Even if it will never really be seen by anyone else, if I do my finish work right.
Old 02-25-2018, 05:23 PM   #9
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,661
A few years ago, I happened to be present when a quartz countertop guy was boring fixture holes with a bit that attached to a 4" angle grinder. He wasn't happy with its performance and grabbed a new one.
I still have the bit he discarded, and it cuts block & brick like butter. Only maybe 1 1/8" diameter, so it takes several plunges for a larger hole, but it was free and takes up very little storage space.
Tinstaafl is online now
Old 02-25-2018, 05:29 PM   #10
tjbnwi's Avatar
I use a cordless drill. Prefer to not have my wrist broken if it binds.
I find for a hole saw this size it is best to bore the hole in a piece of 1/2" or 3/4" plywood. I hot glue this drill guide on the wall. Hit the hot glue with DNA and it will pop right off when done.
The Following 6 Users Say Thank You to tjbnwi For This Useful Post:
AustinDB (02-25-2018), onmywayup (02-25-2018), Pearce Services (02-25-2018), Randy Bush (02-25-2018), Tinstaafl (02-25-2018), Xtrememtnbiker (02-25-2018)
Old 02-25-2018, 10:53 PM   #11
builditguy's Avatar
Rewards Points: 428
I would just drill several small holes and chisel it out. Maybe not as fancy as a 4 1/8Ē hole saw, but it is cheap and pretty easy.
I canít even count he times Iíve done it.
Thursday was the last time. Worked just fine.
builditguy is offline
Old 02-25-2018, 11:35 PM   #12
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & wel
Rewards Points: 4,954
Dont buy the spyder bits, they say they will cut it but dont.
I am just a vessel from which genius flows -Homer Simpson
Global warming is a myth, like evolution and the metric system.
U.S. Coast Guard
Michaeljp86 is offline
Old 02-25-2018, 11:36 PM   #13
EVIL GENIUS
opps multiple post
U.S. Coast Guard
Old 02-26-2018, 07:27 PM   #14
Fugetaboutit
Lunicy's Avatar
Rewards Points: 422
Truth, I returned mine
Lunicy is offline
What is your favorite brick & why? fjn Masonry 43 09-09-2013 12:14 PM
Post Hole Auger Help openhearth Tools & Equipment 9 07-18-2012 12:46 PM
Up Against A Brick Wall Meticularius New Member Introductions 5 09-28-2011 05:06 PM
something for the masonry department dakzaag Masonry 2 05-08-2009 09:23 PM
Hole in Brick bigtick Masonry 4 11-28-2005 01:43 PM
