2 1/2" Fiber Cement Siding
Old 08-14-2009, 01:20 PM   #1
OGStilts's Avatar
I've got a project where the architect has spec'd fiber cement siding to match what was once original to the home. When we removed the vinyl siding to uncover the original we found siding with a 2 1/2" to 2 3/4" reveal. So now I've got to find a fiber cement siding that is similiar in style. The best we've been able to do so far is a 4" reveal. Anyone here know of a brand that does the shorter reveal?
OGStilts is offline
Old 08-14-2009, 01:35 PM   #2
Re: 2 1/2" Fiber Cement Siding
I've seen what you have, but these
are the only replacements I have bought.
If there aren't too many, maybe you could
just cut down the 4"?
neolitic is offline
Old 08-14-2009, 01:47 PM   #3
I like Green things
WarnerConstInc.'s Avatar
Ripping that stuff would suck.
Have to be cement board or can it be wood?
Here is a good one for wood:
http://www.wardclapboard.com/
I ran a 5" lap with a 3 1/2" exposure.
Why cant it go down to 2 3/4"?
WarnerConstInc. is online now
neolitic (08-14-2009)
Old 08-14-2009, 01:54 PM   #4
Aframe's Avatar
Trade: Carpenter/GC
if you end up ripping stock sizes, maybe go with Hardie 8"
http://www.jameshardie.com/builder/p...nkLapSiding.py
2 pieces with one cut, no waste. Or call a rep to see if custom sizes are available, if volume warrants it.
You will have a larger than normal gap behind where you nail it. Don't know if it would be an issue.
If "you" modify an engineered product I would bet it will have warranty implications, so keep that in mind and let everybody else know.
Aframe is offline
Old 08-14-2009, 02:05 PM   #5
Ooops.
Forgot the click and paste part.
http://www.gaf-weatherside.com/?gcli...FYSL5wodARI0jQ
These were the closest matches
for what I've done.
neolitic is offline
Old 08-14-2009, 02:14 PM   #6
I imagined that he was talking about
the old transite shingle siding.
No where near as thick as Hardy planks.
neolitic is offline
Old 08-14-2009, 02:30 PM   #7
I like Green things
Ooops.
for what I've done.
Is that faux asbestos siding?
Old 08-14-2009, 04:22 PM   #8
Yeah, I think that's what
he's talking about....transite.
That was the original
fiber cement.
neolitic is offline
Old 08-14-2009, 04:24 PM   #9
I like Green things
fiber cement.
He was being kind of vauge.
Seems to me though, that if you pulled the vynil off of some of that, you wouldnt be able to save any of it.
Old 08-14-2009, 04:28 PM   #10
Nor any other fiber cement
that I've seen.....
Maybe he'll give us some more hints
later on?
neolitic is offline
Old 08-14-2009, 04:34 PM   #11
I like Green things
that I've seen.....
later on?
I hope, the suspense is killing me!!
Old 08-14-2009, 09:04 PM   #12
OGStilts's Avatar
That's some funny stuff there.
Sorry to keep you all in suspense, It is similar to what Warner had in his first link but has a rounded over edge instead of the square edge shown there.
Problem is this architect is very specific about everything he does and he spelled out fiber cement siding so I have to either find it in fiber cement, get him to approve a substitute as cedar or a larger reveal, or find out if I can rip down some fiber cement siding.
I have a message into the architect seeing if he will accept a substitute. I have my lumber salesman checking with hardi to see if we can rip down the siding to get the reveal we need without voiding the warranty. Something will have to give here.
I think I have checked everywhere, just tried checking here with you guys as a final attempt. It's fairly common siding on these older homes so I'm surprised someone hasn't duplicated it before. I checked on period homes to see if they had any resources but nothing helpful there. Thanks for your help.
OGStilts is offline
Old 08-14-2009, 09:46 PM   #13
#1 Handyman's Avatar
Trade: handyman do all
Once you get the starter strip set after that all siding will lay down evenly and flat as long as the overlap remains consistent.
You may not have to trim the hardy board.
#1 Handyman is offline
Old 08-15-2009, 12:16 AM   #14
21gun's Avatar
Trade: carpenter
Presuming #1 is somewhat to scale.... the corner and window boards would be 3/4 inch... which is about what the thickness of that diagram would equal.... so could make harry situation on corner boards and the like... but other than that i see it working... but what a waste of material. I dont know the req. lap on hardy...not installed too much too know for sure... but seems like 3/4 rings a bell... i've heard about having to use felt paper under the joints too.... true? that would make it even thicker... right?
What about a thicker corner board or using a 1/4 inch shim board to build it out on corners... etc... Sorry, i'm no help really.
carpet? no, we dont do carpet.
No sir... that spells CARPENTER.
21gun is offline
Old 08-15-2009, 10:06 AM   #15
Actually it is sort of drawn to scale.
the lengths are 1/2 scale and the siding board thickness is full scale.
Old 08-16-2009, 09:22 AM   #16
Tom Struble's Avatar
Trade: siding
why would ripping down hardie void the warranty?
as long as the factory edge is exposed on the bottom
why wouldn't hardie honor it?
if they dont i have alot of last course rips and window cuts not covered
Tom Struble is online now
Old 08-16-2009, 09:30 AM   #17
Money Changer
bert0168's Avatar
Trade: Residential Remodeling
Warranty is void, at least that's what I was told by my supplier.
I had a similar situation where I had to match an exposure of 3 1/2" like Warner.
We did exactly what #1 suggested, no problems on the corners or windows.
I love how these archys spec stuff before seeing if it exists
bert0168 is offline
The Following 2 Users Say Thank You to bert0168 For This Useful Post:
OGStilts (08-16-2009), Tom Struble (08-16-2009)
Old 08-16-2009, 09:33 AM   #18
Money Changer
bert0168's Avatar
To expand on what #1 is suggesting, we used a piece of beveled cedar as our under course starter.
This allowed less of a kick out on the board.
I think doing this only kicked out the first couple of courses. Near the ground you never see it.
bert0168 is offline
The Following 3 Users Say Thank You to bert0168 For This Useful Post:
OGStilts (08-16-2009), strathd (08-16-2009), Tom Struble (08-16-2009)
Old 08-16-2009, 09:43 AM   #19
strat hd
strathd's Avatar
Trade: framing contractor , remodeler , GC occasionally
I put a 17'x6' addition on an old painted cedar sided house last winter. It was to make the kitchen bigger for a total kitchen remodel. The lap (reveal) was 3". After checking into special ordering that size of cedar it was more expensive than buying 8" cedar that most stores stock.
So I chose to rip hardi down to size. Don't know how much you have to rip but it was'nt that bad. Went through three blades.
strathd is offline
The Following User Says Thank You to strathd For This Useful Post:
Old 08-17-2009, 09:17 PM   #20
OGStilts's Avatar
OK, I thought I'd stop back here one last time and let everyone know that my Hardie rep confirmed what many of you had said about ripping it down. He said as long as we seal the ripped edge that it will not void the warranty. So now I just need to confirm with architect that is the route he is going to want to go. It's not going to be the exact profile that was original but with the reveal the same I think it will look close enough and it will be much cheaper than cedar. Thanks for your help.
OGStilts is offline
Certaineed fiber cement siding strehlow const. General Discussion 17 09-03-2009 08:21 PM
Patching fiber cement siding bert0168 Windows, Siding and Doors 9 08-10-2009 10:27 PM
fiber cement siding smeagol Carpentry 9 07-18-2009 12:27 AM
Fiber Cement Siding question--- advanced_energy Windows, Siding and Doors 11 07-02-2009 06:43 PM
ring shank nails with fiber cement siding? Jer Windows, Siding and Doors 16 01-18-2009 12:58 PM
