Capra aegagrus
100 Miles Of Caulk
Well, maybe not a hundred, but it's going to seem like it till the job is done. We're putting up steel siding on all the used-to-be windows on this building, and will be caulking the J channel all around.
Anyone have any neat tricks for tooling caulk on brick and concrete? I don't think I have enough spit for the job. ![]() And... I've always sneered at those powered caulk guns, but if there's a place for them, this is it. I'd appreciate hearing from those who have experience with them. |
I like Green things
Re: 100 Miles Of Caulk
Damp sponge, 2 buckets of water, one clean, one to clean sponge.
Power caulk guns, never used one, really wanted to. |
Trade: Construction Assistant Superintendant/Remodeler
I haven't done THAT much caulk ,but I always use a sponge and water bucket.
MURDER on the sponge and several passes to remove the excess. I'm sure you knew that though. |
Re: 100 Miles Of Caulk |
A can or pail with water and
dish soap....... and buy Fast Orange hand cleaner by the gallon. ![]() The pneumatic guns have a steep learning curve, but if you want to buy in bulk..... I've used a few of the battery powered ones, but not enough to recommend one or another.
Maybe a case of nitrile gloves?
I like Green things
I forgot about dish soap.
I usually wear black nitrile gloves when doing any glueing, caulking, staining, etc. I get tired of filthy hands. |
I used to build conservatories and we used a pneumatic caulk gun, it was cool but allowed you to lay a bead 2 times too big twice as fast.
I second, err third, the bucket and rag trick. |
#9 | ||
Capra aegagrus
Thanks guys; I think I'll be trying rags rather than sponges. I don't own enough of the Great Barrier Reef for that.
![]() Quote:
Trade: Custom deck builder
I have the ridgid 18v glue/caulk gun and it has a variable speed. Its also all about the cut, if you cut a gaping hole then your jacked no matter what you use. I bought the ridgid for glue mostly but I have used it to caulk and it worked just fine.
Trade: Bricklayer
I would use a set of spoons and rags.
Trade: Consultant
Hire a caulking company- it'll save you the pain.
#13 | |
Capra aegagrus
Re: 100 Miles Of CaulkQuote:
Novel thought, but I never learned to play spoons. ![]() Seriously, that does sound like it could work well under the right circumstances. But I don't trust myself to be able to handle the excess neatly on a brick/concrete surface. Under the right circumstances I'd be tempted. But (a) we're trying to maximize profit by keeping as much of the work in-house as possible, and (b) I actually do have a pretty good touch at it myself. Just haven't done it on this scale before. |
1" foam brushes and a small pail of water
Ray |
Trade: Bricklayer
Figured I would chime in since nobody brought up using spoons. If there is a section that is unnoticable I would atleast give this method a shot. You can get alot done quickly and neatly with a nice set of spoons. But you know what you are comfortable with. Good luck on the project.
Trade: Bricklayer
Just to make myself clear I mean using these
http://www.loghomesupply.com/special...-rod_107_d.htm I guess "spoons" are a slang term. |
As far as the battery guns,
I tried a Ryobi, and a DeWalt And another "yellow one" ![]() The Dewalt was variable speed, and had a way to lock in the rate of flow that you liked. That's about all I remember. Milwaukee makes one too, but you might want to check these guys. http://www.albioneng.com/
#18 | |
They come in different sizes, and I think they're called "spoonulas"? Sounds like a spork.
#19 |
Trade: Tube Installer
On commercial jobs like that I would expect to see bulk guns and NP2 in buckets, a soup can wired to your belt containing a little soapy water, and your spoon of choice. If you need gloves, rags, hand cleaner, and somewhere to put the "extra", you are doing it wrong.
#20 | |
Capra aegagrus
No doubt. You ljust showed me something I didn't even know existed.
Sounds like both of you guys have a clue as to how it's done on a bigger scale, and I do appreciate the education. Anything else you can point me at would be well paid with attaboys (can't fit much else through this keyboard).
| Tub-Tile joint, grout or caulk?? | Aframe | Ceramic & Stone Tile | 11 | 06-27-2011 02:55 PM |
| Which Caulk is most mildew resistant? | duckdown | Remodeling | 15 | 01-03-2010 08:51 AM |
| To Caulk or not Caulk. | HandyHails | Ceramic & Stone Tile | 11 | 03-10-2009 07:45 PM |
| Caulk at tubline... ...or grout? | Bazooka Joe | Ceramic & Stone Tile | 20 | 12-26-2008 02:39 PM |
| Caulk quality | Ralph6 | Windows, Siding and Doors | 5 | 09-04-2008 06:33 PM |
