1 &1/2 Story House Attic Ventilation
Old 02-03-2010, 10:56 PM   #1
Cjeff's Avatar
Trade: Renovations
Client as a house that Ice dams and drips inside the house. The slanted ceiling is fully insulated so there is no air flow.
Wondering about putting vents at the top of the lower attic area, so air comes in the eave and out the middle of the roof.
And vents at the bottom line of the upper attic area so air comes in and out the ridge.
The middle area will still have no air flow.
Will this help? Who do you go to for such information. Not really structural. So not an engineer.
Thanks for any help.
Cjeff is offline
Old 02-03-2010, 11:19 PM   #2
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,168
Re: 1 &1/2 Story House Attic Ventilation
Hard to tell without seeing the house, but if you can get air flow where the eaves are, that should help. When there's no cold outside air flowing through the eves, the roof surface gets too warm and melts the snow. Then you have water, then ice, then ice dams, then leaks.
In the past I've torn off a whole roof and put three-tab shingles on top of the insulation to push it down a couple inches. Enough to get some air flow through the whole roof. Hard to fix though without doing a lot of demolitioning.
KennMacMoragh is offline
Old 02-03-2010, 11:30 PM   #3
Cjeff's Avatar
Trade: Renovations
What I would like to do is remove shingles and sheeting and insulation. Fix/install poly, fiberglass insulation, 2-4" styrofoam on top of rafters, 2 by 2's on top of insulation to provide air flow, then sheeting and new shingles.
This would give proper vapor barrier. Better insulation (R40 is considered minimum here) and proper attic ventilation. T
his is a costly remedy and was wondering if any good ideas out there on a less expensive way.
Cjeff is offline
Old 02-04-2010, 02:08 AM   #4
genecarp's Avatar
Rewards Points: 2,000
How about just strip first 3 ft of roof edge, I&W shield REROOF, worth a try, if that does not work, strip rock from int, add baffles and soffet vents, GMOD.
genecarp is offline
Old 02-04-2010, 12:15 PM   #5
Cjeff's Avatar
Trade: Renovations
The ice & water may help with the ice build up at the bottom, but there is frost on the underside of the sheeting up as far as I can see which is about 1/2 way.
Cjeff is offline
Old 02-04-2010, 01:15 PM   #6
d-rock's Avatar
Trade: carpentry/drywall/plaster
Rewards Points: 250
ridge vent, soffit vent, and RAFT-R-MATE baffles in the bays before re-insulating.
d-rock is offline
Old 02-04-2010, 05:02 PM   #7
Cjeff's Avatar
Trade: Renovations
Ok so no easy way, either roof comes off, or drywall does.
Cjeff is offline
Old 02-04-2010, 05:04 PM   #8
genecarp's Avatar
Yes, but do it in steps, i would first I and W shield the first 3' see if that works, if it does not, then go for the baffles and the venting, GMOD
genecarp is offline
Old 02-04-2010, 05:38 PM   #9
wannabe
WNYcarpenter's Avatar
Trade: carpentry
Rewards Points: 1,000
a few years ago we had the same problem with a spray foamed cathedral.
We stripped the shingles, stacked 2x purlins on the rafters (over the sheathing), then re-sheeted and shingled....I can't remember the actual detail, but we added to the facia and re-wrapped with coil to provide the ventilation.
The only real PITA was replacing the skylights and trim.
WNYcarpenter is offline
Old 02-04-2010, 07:00 PM   #10
General Contractor
greg24k's Avatar
Rewards Points: 7,256
During cold temperatures outside, the frost that you see in the attic can be associated with attic bypasses, i,e when warm air from inside the house escapes in to the attic (through light fixtures, attic access panels are not being closed evenly,etc) especially during freezing digits weather, the moisture condenses in the attic on the roof boards and rafters, where the frost can form.
Installing mechanical ventilation could cause other problems, because by adding more attic ventilation, it will allow more air to escape from the attic and by doing that, it will pulls more warm moist air from the house into the attic. I would start by finding the source of humidity and try to bring it down.
greg24k is offline
Old 02-04-2010, 07:08 PM   #11
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 164
More ventilation is needed above the insulation. No other cure. You need cold roof above the existing cathedral.
jlhaslip is online now
Blew in attic insulation today-what a day LOL IHI General Discussion 14 09-16-2011 08:08 PM
furnace in attic causing ice 4julywoodworks General Discussion 20 01-11-2010 09:47 PM
Planning my dream house! CJ21 Carpentry 10 07-25-2009 10:15 PM
panel in guest house veer Electrical 15 08-10-2008 04:42 PM
Raining in the House oldfrt General Discussion 9 11-07-2007 10:10 PM
