Estimating Programs......
Old 11-26-2008, 05:47 PM   #41
It's all about the Avatar
woodmagman's Avatar
Trade: I have no face!
Re: Estimating Programs......
Originally Posted by True North View Post
I respectfully disagree with you about this.
All things being equal to start with, i.e., a floor and a pile of studs.
Do you break out the compressor and guns to build 10' of wall? If you do, that 5 or 10 minutes of cord and hose unrolling needs to be absorbed by the wall. Let's go with 5 minutes: Thirty seconds a foot for the 10' wall, and three seconds a foot for the 100' wall.
Let's say you use a hammer for the 10' wall, because it's not worth using the guns: Still more time per foot.
What if every stud needs to be cut? We can set up a chop saw with a stop for the 100' wall and blast through the 76 studs in short order. We're unlikely to do that for 10', so we break out the tape and skillsaw. Guess what? More time per foot.
The key word is ESTIMATING we are not putting a man on the moon, but if you include enough information with accurate variables then why not....
Let's move to marking the line on the subfloor: It only takes a little longer to snap 100' of line vs. 10'. You still have two measurements to make. Basically you just walk 90 more feet for the longer wall.
The list can go on. I'm actually astonished that you would say something like 100' of wall take 10 times as long. It is one of the basic principles of construction and manufacturing that smaller quantities of the same type of work cost more per unit. That's why 500 business cards cost $25 and 1000 cards cost $30.
I mean no offense by this post. I'm really enjoying the dialogue in this thread. Like Max Nomad said, estimating could almost become an obsession.
Cool….we both agree why square foot pricing or lineal or what have you does not work if you do not follow the same process as the estimate was based on. Using your examples, I can tell you a 10 foot wall takes X amount of time to frame using a specific process and manpower. 100 feet of wall take 10 times
10 HOURS DAYS
Note pad of calculation
10 feet of task. 1hour or (A)
Material to complete 10 foot task cost of material or (B)
A+B=X
Number of calculate trips 1 (C)
Set up and take down time 2 hours (AA)
Overhead profit and other based on man hour (D)
C+AA+3D=F
X+F=COSTX
100 feet of task 10hours or (AAAAAAAAAA)
Material to complete 100 feet of task cost of material or (CCCCCCCCCC)
10A+10C=10X
Number of calculated trips 2 (2C)
Set up and take down time 4 hours (4C)
Overhead, profit and other based on man hour (D)
2 C +10A+14D=G
10X+G=COST10X
It is not about the square foot or lineal foot, it is about the process. With out adding the process you are not completing the equation. This equation can be calculated on paper or in any simple spreadsheet. The constant is the foot, the variables are the labor and cost incurred completing the process. If you have determined a process for breaking the variables down into a manageable size they can be used in the calculation.
the key word is ESTIMATING
woodmagman is offline
Old 12-16-2008, 09:32 AM   #42
modterry's Avatar
Trade: Custom Modular builder
This is a great forum of ideas. We build custom modular homes and for 2009 shifting back to kitchen and bath remodeling like I did 20 years ago. My main problem with bidding programs is they don't relate to the specs- I am building an on line system where the specs drive the estimate for materials, labor, tasks. For example: I am using Topics : for instance = Kitchen Counters: If the spec is granite - then I can price the materials , Labor ,(Granite takes more labor than laminate to install) . If I have done a detailed bid - by line item , then when the project books - I can assign the material line items to a PO and it is integrated.
Our specs have the a Code, Topic, Specification, Product and this is shown to the customer
Then: behind the specs are: the materials by same code system ( assembly ) , labor, tasks ( tasks go into the schedule )
This system has created 4 data tables for each project: Specs, Materials, Labor, Tasks
I have 4 "Standard " Tables that are copied into each project - I find that it is easier to delete what does not go in the project than to remember all the items each time I do a project.
We have eliminated most specs on our plans and have everything in our job notebook.
I then have added pictures and the "How TO" for the production staff within the specs also. This has really helped. Sure was hard to get the production staff to read the specs at first. Now when they ask how high does a single closet rod and shelf is - I tell them look it up
Has any one seen a program that is driven by the specs first, then materials, labor, tasks , etc ?
modterry is offline
Estimating and Software - Review of 5 Programs! 10.25.08 SLSTech Business 7 12-19-2008 01:05 PM
Estimating Programs...... CF Construction General Discussion 1 11-24-2008 06:06 PM
Free Online Fundamentals of Estimating, by Michael Stone Ed the Roofer Marketing & Sales 3 09-02-2008 11:27 PM
Estimating and 3D Rendering Programs??? Two Brothers Drafting & CAD Forum 7 04-06-2008 12:46 PM
Estimating programs Alkyd Painting & Finish Work 9 02-19-2006 07:01 PM
