Trade: trim carpenter
Tin Ceiling Source And Tips Needed
It looks like I will be installing about 600 s.f. of 2x2 tin ceiling in a Victorian. Are there vendors that are great to buy from or vendors to stay away from?
Also, if you have photos or tips, I have not done much of this. TIA, Bass |
I like Green things
Re: Tin Ceiling Source And Tips Needed
VanDykes has a decent selection.
They seem to all be expensive. What will the finish be? Just have to make sure you start square. I bet the room wont be.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana Warner Remodeling Facebook |
Illusion of Perfection
Bass - I've only done 2 (can't remember the vendors, but they were not the same).
Like Warner said, start square, if the panels interconnect - double and triple check before nailing off. Wear gloves, too. Usually the perimeter is finished with a crown molding of sorts, any idea if it is wood or tin to match? |
Trade: GC, carpentry, cabinetry
Try outwater plastics. They have a pretty big selection and also offer accessories like cornice and cone head nails.
bathroom guru
Its been about 15 years since I did any tin ceiling. I used a source out of Quebec at the time that also sold stair railings, etc.
There are some 2x2 panels that are one big panel, then their are some that have 4- 1' squares on them, and some with a 6" square pattern. You'll have to see how, in the case of the "one big panel" - how many you can put across the room without cutting. Same goes for the other patterns, but, you can cut them down the seam which obviously gives you a lot more room to play, especially with the 6" pattern. I always used a pebbled "filler" sheet around the perimeter along with a tin cornice moulding. I know there is a company in the States - "Norman" something - they used to have all the old dies and could make some pretty amazing stuff - it was just very expensive. Finally, I think someone mentioned nails - make sure to get the ones made for tin ceilings. |
| Best brand and source of paint spray tips? | toddcla2002 | Painting & Finish Work | 7 | 11-19-2006 04:14 PM |
