Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Remodeling > Historical Restoration
Old 01-18-2009, 10:22 AM   #1
Trade: tile and stone installer
Question Pressure treated used in walls
I recently went to estimate a three bath renovation in condo downtown.
When I arrived to the job site I noticed the whole building has been studded out with pressure treated lumber. What concerns if any should I have about installing backer boards and stone in showers studded out with pressure treated lumber?
Tile man Dan is offline   Reply With Quote
Old 01-18-2009, 10:49 AM   #2
This would depend on where
you are.
If it's PT Yellow Pine,
it takes a loooong time
to dry out, during which
time, it shrinks and warps.
If it's PT fir....
I don't know.
neolitic is offline   Reply With Quote
Old 01-18-2009, 11:26 AM   #3
Trade: Home Theater
You have nothing to worry about. Since this is an existing property where the wood has had several years to dry out, it has already done its twisting and warping...
duckdown is offline   Reply With Quote
Old 01-18-2009, 11:39 AM   #4
If it might be ACQ,
look into corrosion proof
fasteners too.
The Following 2 Users Say Thank You to neolitic For This Useful Post:
Deadhead Derek (01-18-2009), K2 (01-18-2009)
Old 01-18-2009, 02:25 PM   #5
j.m.s.'s Avatar
Remove them, it is illegal to use pressure treated in living space, except for shoes on a slab. The reason is fire, they are concerned about the toxic gases when burning.
Joe
A Constitution of Government once changed from Freedom, can never be restored. Liberty, once lost, is lost forever. (John Adams)
http://jmsconst.110mb.com
j.m.s. is offline   Reply With Quote
Old 01-18-2009, 02:28 PM   #6
Professiona Instigator
rbsremodeling's Avatar
Trade: Design Build Remodeling Contractor Washington, DC
Joe
I don't think this is correct?
rbsremodeling is offline   Reply With Quote
Old 01-18-2009, 02:31 PM   #7
Remove them, it is illegal to use pressure treated in living space, except for shoes on a slab. The reason is fire, they are concerned about the toxic gases when burning.Joe
Errrr, he says he's the tile guy,
not the GC.
Reframing the building might
be outside the scope of his work.
Old 01-18-2009, 02:35 PM   #8
not the GC.
What about the issue of it being illegal I have never heard that before in my life?
Old 01-18-2009, 02:41 PM   #9
I've heard that before.
Makes sense, but the whole concept
is so bizarre......
I never cared to find out.
Old 01-18-2009, 02:47 PM   #10
Sean
SLSTech's Avatar
Joe
Where in the IRC is this? I can't recall ever hearing or seeing anything like this in there.
If its not there & is only a local code issue, all you should do is recommend they contact their local code officials & state that in your area it's illegal.
Thanks
SLSTech is offline   Reply With Quote
Old 01-18-2009, 04:21 PM   #11
j.m.s.'s Avatar
I was told that by inspectors years ago, not sure if it is really a law, but Like the other guy said, "it makes sense". I have just always made it may practice never to introduce pressure treated into the living space. I know I wouldn't want it in my house. I once had a 6 " splinter of treated go thru the front of my leg and out the back, when the Dr saw me in ER waiting room, he said "YOU , inside now!" Treated contains: cyanide, creosote, copper, formaldehyde, ... lots of nice stuff! I could have died from blood poisoning they said, had to get it out immediately. So, therefore, I don't like it in walls.
Joe
Old 01-18-2009, 04:54 PM   #12
Sean
SLSTech's Avatar
I agree completly with you, the catch is stating something is illegal as a blanket statement, or in my area were not allowed to do...
Cheers & have another on me
Old 01-18-2009, 04:57 PM   #13
Trade: Project Management; LEED AP
Interesting points made here. But if treated lumber is a toxic smoke issue then what about spray foam insulation? I think in most jurisdictions as long as it's covered with drywall it's ok.
rustyjames is online now   Reply With Quote
Old 01-18-2009, 05:13 PM   #14
tired carpenter
Trade: carpenter
Fire retardant teated lumber
I used a fire retardant lumber in a comercial building back in the eighties. This may be the case in this complex as that material appeared similar to the weather treated material of today. A check of the original prints should shed more light on what is actually involved. As mentioned watch out for injuries as I remember scratches from this material were worse than normal injuries.
Tired Carpenter
tired carpenter is offline   Reply With Quote
Old 01-18-2009, 05:27 PM   #15
Tired Carpenter
Bet you're on to something.
Old 01-18-2009, 05:36 PM   #16
My first 5 years of construction every house I built, every scrap of lumber used in the framing was constructed using pressure treated lumber.
Interior walls, rafters, sheathing. Everything was pressure treated.
Old 01-18-2009, 05:40 PM   #17
Yeah, but you live in a swamp.....
with really weird people!
Old 01-18-2009, 05:42 PM   #18
LOL No it was actually on an island but same difference.
Old 01-18-2009, 07:45 PM   #19
j.m.s.'s Avatar
Might be getting off topic but, when I took the RCS course we learned that every building material has a fire and smoke rating or requirement. Your wood paneling has ratings on the back of it, electrical wiring has ratings, Can't just use any speaker wire in walls-has to meet ratings, ....maybe the foam insulation meets these requirements. If you look in the back of the IRC book you will find the reference standards including flame spread and smoke requirements. In fact I found no mention of not being able to use treated in living space. You would think with all these other crazy laws that that would be one. My mistake, ignore my previous comment.
Joe
Old 08-10-2009, 07:25 PM   #20
Trade: contractor/Instructor
deck screws
If you install the backer boards to treated studs with the coated decking screws you will be just fine. Treated lumber have an even higher moisture content then s-dry (19%) lumber. Regular wood screws will carrode and break off while nails will pull out in a matter of time. There isn't any other concern with this project. remember to double the screws in the field area by 2" apart for the heavier stones.
dkendu is offline   Reply With Quote
pressure treated wood question???? davinci Construction 19 08-30-2008 12:00 PM
Pressure treated and cedar pfloyd Decks & Fencing 4 05-31-2008 11:46 AM
Pressure treated wood KellyPainting Painting & Finish Work 23 09-08-2007 11:05 AM
Pressure Treated Wood rjordan392 Carpentry 4 05-28-2007 01:23 PM
trim coil over pressure treated wood?? Lt.H Windows, Siding and Doors 7 04-13-2006 11:12 PM
