Flexible Gutter????
Old 11-18-2009, 10:26 PM   #1
painterman's Avatar
Trade: Historic Restorations
Flexible Gutter????
I'm doing a porch restoration on a porch with a rounded roof. I need to install gutter on the rounded section,other that cutting std alum gutter into several 5 inch pieces what other ways can this be done.
painterman is offline
Old 11-18-2009, 10:27 PM   #2
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
Re: Flexible Gutter????
Make it a box gutter, line with metal or membrane from above. Somewhere there's a thread with pics of something just like that.
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is online now
Old 11-19-2009, 01:03 AM   #3
Tom Struble's Avatar
Trade: siding
besides Chris's way i wouldn't try to do that with anything but copper or wood
thinking about it there is a azek type pvc gutter out there
i wonder if that could be heat formed?
http://www.advancedtrimwright.com/pr...guttertrim.htm
Tom Struble is online now
Old 11-19-2009, 08:12 AM   #4
nlgutters's Avatar
Trade: seamless gutters
U can order custom bent copper.It's about $150 a ft with out hangers!! We have done a few.
The best way is their is a co out of Texas that makes them ouit of fiberglass from what i understand u would never know the diffrence. I believe they can come in 8 ft sections
www.nlseamlessgutters.com
nlgutters is offline
The Following User Says Thank You to nlgutters For This Useful Post:
Tom Struble (11-19-2009)
Old 01-11-2010, 08:04 PM   #5
Wood Craftsman
PrestigeR&D's Avatar
Post
I remember a 15-16 years back, there was a gutter firm we used for the same situation - He had a backer for the K section of the gutter - 4 solid steel shaped bearings 2 on either side, the runner - flat steel bearing (same dimension as the runner) and 1 steel bearing on the center of the facial section and he could regulate the arch - it was amazing piece of equipment-Copper ,,,of coarse . Check your local gutter distributors, they may have some attachment as part of their offered services- ask around, you never know, and good luck!
try this company http://www.ornametals.com/products/c...?cPath=100_150
PrestigeR&D is online now
Old 01-11-2010, 08:22 PM   #6
Do it with wood.
Line it with sheet lead.
neolitic is offline
Old 01-11-2010, 11:33 PM   #7
Trade: siding
sheet lead?.. does it come pvc coated
Old 05-01-2010, 08:59 PM   #8
CopperSmith's Avatar
Trade: Custom Copper Gutters, Leaf Protection, Seamless
Copper! Half round works great for this, but it is expensive to have a qualified installer do it. Plan on 40 per ft. + $100 per miter if its really high end. Should be able to make it look great.
CopperSmith is offline
Old 05-01-2010, 09:01 PM   #9
nlgutters's Avatar
$40 a ft for custom bent half round copper?
Old 05-01-2010, 09:36 PM   #10
copper magnet
seeyou's Avatar
Trade: custom metal fabrication
I'm guessing he was talking about segmented gutter. That's about what I get.
seeyou is offline
The Following User Says Thank You to seeyou For This Useful Post:
nlgutters (05-01-2010)
Old 05-01-2010, 11:29 PM   #11
TimelessQuality's Avatar
Trade: GC/Remodeling
Yankee gutters ...maybe??
Seems like that's what's on most round porches, 'round here
-Steve
"The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein
TimelessQuality is online now
Old 05-02-2010, 06:42 AM   #12
copper magnet
seeyou's Avatar
Using a SCMS with the proper blade, a nice looking segmented gutter can be created (we seldom have to use pieces much shorter than a foot). If a true radiused gutter is desired, this is about the best deal I've found:
http://www.classicgutters.com/Nehemiah/00000588.html
edit: The built in gutter is also a good option, but typically a curved crown molding would have to be milled and that's not cheap either. I'd use copper to line the built in gutter, rather than a membrane.
seeyou is offline
Old 05-02-2010, 09:33 AM   #13
Framer53's Avatar
Trade: Framing
What was there originally?
If this is an historical restoration, regular K gutters will look out of place.
I would suggest you get together with someone like Seeyou, Grant is his name, and work something out.
By the way Seeyou, good to see you posting!
Framer53 is online now
Old 05-02-2010, 12:50 PM   #14
copper magnet
seeyou's Avatar
Hey Dave - Looking forward to meeting you at Mike and Susan's in July. Want Steve and I to pick you up on the way?
seeyou is offline
Old 05-05-2010, 10:04 PM   #15
$40 a ft. Plus each miter charge. So $40.00 to $100.00
Depends the curve. We have done it a before it looks amazing.
Old 05-05-2010, 10:06 PM   #16
And yes NL that was for basic 6 inch half round.
Old 05-06-2010, 11:04 AM   #17
red_cedar's Avatar
If Im reading this right, you guys are charging $40 ft for segemeted ( curved ) 6 inch half round copper gutters? My goodness that cheap, unless your riveting and caulking the joints and doesnt include hangers.
Last job I did I got $60. Curved would be more like $80 +. Now if I was eastern european or from south of the border then $40 would sound right.
For those prices one is just doing the work because they want to, not to make money. Those are prices from 10-15 years ago.
red_cedar is offline
Old 05-06-2010, 02:15 PM   #18
copper magnet
seeyou's Avatar
I charge a little over $40 a foot for a slight radius segmented 5" copper K style, soldered, out the door, not including hangers. We hang it, it's more. Larger sizes, tighter radius, or half round = more $. We're pretty darn efficient at it - we do it regularly.
seeyou is offline
Old 05-06-2010, 11:58 PM   #19
Wow, around here you cant get those prices. Well, usually you cant.
$40.00 a ft. For copper 6 inch half round is good money around here. I get undercut at that all the time. All soldered and custom cut. Usually undercut by hacks who really don't know a thing about copper.
$50.00 a miter/cut at least so that brings your "flexible gutter job up in price!"
So 150 ft. of gutter with 50 cuts your looking @ $8500.00
Gutters and gutter guards Mitch M Roofing 39 10-11-2010 09:26 PM
Gutter Setup? guttersbyryan General Discussion 14 11-14-2008 04:57 PM
Com Cast tv cable in wood gutter Driftwood Carpentry 6 10-04-2008 09:40 AM
ice shield at gutter line? Grumpy Roofing 38 09-08-2008 08:22 PM
