Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 07-31-2009, 09:47 PM   #1
Trade: Flooring & Remodeling
You Have Never Done This !!!
I bid a job , got it & scheduled it . We start on monday . But when i went to deliver the wood flooring and opened the boxes and looked at the product i was a little taken back . The pre-finished wood comes in diffrent widths.
I've been doing wood floors & tile for almost 19 years but i've never seen wood come in diffrent widths. I've done many large tile projects with patterns , but this is diffrent.
The boards come in 4 , 5, & 6 inch widths . All the boards are radom lengths . Does anyone know how to lay this pattern ? Is there a simple secret i'm not seeing here?
finaltouchfloor is offline   Reply With Quote
Old 07-31-2009, 10:17 PM   #2
Painter/Rehaber
Dustyrose's Avatar
Trade: Painter
That's what you get for shopping at Menards.
Politics is the art of preventing people from taking part in affairs which properly concern them. Paul Valery
Dustyrose is offline   Reply With Quote
Old 07-31-2009, 10:21 PM   #3
Yard Boi
Trade: Landscaping
Is it a mistake?
BobsLandscaping is offline   Reply With Quote
Old 07-31-2009, 10:27 PM   #4
ChrWright's Avatar
Trade: Builder/Remodeler
Maybe I'm just not getting your question... But I'd say you either randomly alternate rows of each size, or repeat them in a pattern: 4, 5, 6--4, 5, 6, etc.
Christopher Wright, WrightWorks, LLC
www.WrightWorks.net - Facebook - Christopher Wright, Remodeling Info on Twitter
Indianapolis Remodeling Contractor - Remodeling Photos: Kitchens, Baths, Room Additions, Basements
"Form follows function - that has been misunderstood. Form and function should be one, joined in a spiritual union." -Frank Lloyd Wright
ChrWright is offline   Reply With Quote
Old 07-31-2009, 11:00 PM   #5
Painter/Rehaber
Dustyrose's Avatar
Trade: Painter
That is how I pictured it. Just curious. Do you find you discard more material when installing this specific type of flooring?
Old 07-31-2009, 11:01 PM   #6
The wood is not a mistake .
Chrwright ,Thats make sense . Thanks for the heads up . All i have to do is not mixed the rows , Just make every row the same width . I was thinking of a off-set tile pattern , guess i'm just tired or retarded...
Old 07-31-2009, 11:06 PM   #7
Yes, there is more waste. I told the clients to buy 2 extra boxes of wood.
Old 08-01-2009, 12:05 AM   #8
Trade: New construction, remodeling
I installed this prefinished ash floor in random widths/lengths this last spring. I found that it does not look right when it is installed in a pattern. Random order looks best. Good luck!
dtsinc is offline   Reply With Quote
Old 08-01-2009, 05:46 AM   #9
BHR
Dufus Extrodinaire
BHR's Avatar
I agree...the flooring is meant to be random in layout
If I had one I would share it
BHR is offline   Reply With Quote
Old 08-01-2009, 05:00 PM   #10
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
I have seen several companies who make this.
trick is.....If the person who measured did not do the math...you will have problems.
You have to order different square footages of each to get the project done depending on what the customer wants.
If it's just random...then you may be fine....
Floorwizard is offline   Reply With Quote
Old 08-01-2009, 05:12 PM   #11
Crash Test Dummy
ChainsawCharlie's Avatar
Trade: Landscaping
I've seen that before. And I prefer it to all standard width.
ChainsawCharlie is online now   Reply With Quote
Old 08-01-2009, 05:36 PM   #12
loneframer's Avatar
Trade: residential framing/general carpentry
First off, you need to scatter out the boxes to verify quantity of each width in lineal footage. If there is an equal amount of lineal footage, you are limited to little choice of pattern. I prefer some type of symetry, so I would start wide, medium, narrow. Repeat. You may want to do some math to make sure you don't end up with a narrow rip at the other end of the floor. It may benefit you to shift the pattern to acheive a better margin at the other wall. BTW, random plank has been around since the dinosaurs roamed the earth.
" It's a Jersey thing, you wouldn't understand"
loneframer is offline   Reply With Quote
Old 08-01-2009, 05:42 PM   #13
loneframer's Avatar
Hopefully you're tired. If not.....your ride is here.
Old 08-01-2009, 09:55 PM   #14
nEighter's Avatar
Trade: Painting/Framing/Drywall/Tile
I have never seen a floor like that but seriously get pics man
nEighter is offline   Reply With Quote
Old 08-01-2009, 10:27 PM   #15
Each box has exactly the same linear footage of each width. I was just overthinking & overlooking a simple pattern. I was just tired after a long 60 hr week.
I'll take a few pics when i done.Thanks for the heads up.
Old 08-02-2009, 07:46 AM   #16
Trade: Finish carpenter
Sorry, this may be a bit late in the day to help.Random width flooring is nothing new to me,before you lay a stick you should establish how many packs/bundles of each width you have.That done it's easy to work out the percentages of each width and the pattern you will need to follow.The percentage dictates the pattern.
mack.
mack9110000 is offline   Reply With Quote
The Following User Says Thank You to mack9110000 For This Useful Post:
tomstruble (08-02-2009)
Old 08-06-2009, 04:52 PM   #17
AcademyHardwood's Avatar
Trade: AcademyFloor
The style seems to be the one in the several pics, did you receive an Installation Guide ? If not, did you speak with a representative from the distributors ? They should be able to give you an idea of the installation process, if you give them the specific product name and style.
AcademyHardwood is offline   Reply With Quote
Old 08-06-2009, 08:51 PM   #18
Final Product
Ok, This is what the Bella Cerra Handscraped Maple finished product looked like . The pattern was simple , 6" , 5" , 4" .We undercut the plaster fireplace , scary stuff to work with , very brittle.
ID:	21810   you-have-never-done-bella-cerra-maple-3-.jpg.jpg
ID:	21811   you-have-never-done-bella-cerra-maple-2-.jpg.jpg
Old 08-06-2009, 10:41 PM   #19
nEighter's Avatar
Awesome!
Old 08-07-2009, 11:28 AM   #20
Cpt. Chaos
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Looks good. I see you found out that it is very difficult to maintain proper spacing between end joints on those types of installs unless a larger waste percentage is figured in eh? That's the downside to not ordering your own product. Keep that in mind to educate the sales staff or gc. I typically figure 15% on jobs like that.
Precision Flooring
Hampton, VA (757) 256-0848
Tile, Hardwood, Laminate, and Resilients
PrecisionFloors is offline   Reply With Quote
