Wood-to-tile -- Sub And Prep
Old 03-20-2006, 10:53 AM   #21
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: Wood-to-tile -- Sub And Prep
Originally Posted by Mike Costello
My point was having a flush transition between the wood and the tile and using a soft joint between the two.
Mike you do realize that a Schluter transition strip is a flush transition between wood and tile?
Mike Finley is offline
Old 03-20-2006, 10:59 AM   #22
Chief Toilet Mover
Originally Posted by sage
If the tile is already down and the wood has to go in, then a soft joint is appropriate IMHO, if bridging the transition is not called for.
Exactly. In that situation you have no choice.
and the client expected this to occur because I already planted the seed during the build.
Yes, that is smart, planting the seed as you put it is smart, because I'm sure you realize that most people will never call you back for little defects like this, but they will watch that caulk separation grow worse and worse year after year until eventually they will be thinking to themselves how that looks like sh!t!
Old 03-20-2006, 06:30 PM   #23
Mike Costello's Avatar
Trade: Flooring
Send a message via Yahoo to Mike Costello
Yep I do, but like I said, I dont do tile, Im the wood guy coming in after the fact.
Mike Costello is offline
Old 03-20-2006, 10:15 PM   #24
adams,b's Avatar
Trade: hardwood floors
Originally Posted by Big Dave
Ain't that what I said.
Dave.
i dont know, did you?
alright i guess we are on the same pg.
adams,b is offline
Old 03-20-2006, 10:21 PM   #25
Master Craftsman
Big Dave's Avatar
Trade: Rustic interior woodwork
C'mon Adams,b, why are you pickin on me?
Do one thing at a time, do it well, then move on.
http://www.bigdaveswoodworks.com
Big Dave is offline
Old 03-26-2006, 10:25 PM   #26
Chief Toilet Mover
If the tile is already down and the wood has to go in, then a soft joint is appropriate IMHO, if bridging the transition is not called for. I have had call backs on the soft joint outside of a year later. Quick fix, and the client expected this to occur because I already planted the seed during the build.
I never grout the transition for reasons already presented.
One thing I know of that will help lessen the deterioration of a caulked joint that we are discussing is using backer rod in that joint before you caulk. Using the backer rod allows you to create the preferred 1/2 as deep as wide joint and allows for what is called a 2 point joint (contact of the caulk only on two sides of the joint - tile and hardwood in this case) vs. a 3 point joint (tile, hardwood and the bottom of the gap you are filling with caulk)
Old 03-27-2006, 08:13 AM   #27
SAGE
sage's Avatar
Trade: Remodeler and Finish Carpenter
Mike, I am not familiar with this at all. Very interested.
What is a backer rod? Something that you would place in the joint between the tile and hardwood?
Does it go in partially set in the thin set, or do you just drop it in the gap?
What material?
Even with something placed in the gap, wouldn't the caulk contact it anyway (gravity-filling the joint)?
I can't make sense of it, Maybe if you have a picture. The only way I can figure is that the insert is V shaped.
-Lead from the front, or dont lead at all-
sage is offline
Old 03-27-2006, 10:08 AM   #28
Chief Toilet Mover
Backer rod is made from foam, (it looks like the round insulation that you put over copper pipes to hold the heat in, but much thinner) it comes in all sizes and thicknesses and most people know about using it for filling a too large space before caulking, but most don't realize the additional benefits of using it for joints that are going to be exposed to expansion.
The key to lessening caulk failure is creating a 2 point contact joint instead of a 3 point. The caulk in the picture is bonded to the 2 surfaces that will be moving, the backer rod is bonded to the caulk and since it isn't rigid like the other 2 surfaces when those surfaces push and pull the backer rod will give and allow the caulk to follow the 2 hard points. When you don't use a backer rod the 3rd point becomes the bottom of the joint which is a hard no giving contact.
Old 03-27-2006, 02:29 PM   #29
SAGE
sage's Avatar
Nice, learn something new everyday!
Thanks
sage is offline
Old 03-28-2006, 02:03 PM   #30
Trade: Flooring
Awsome graphic Mike and some useful info!
