Trade: General
Wood-to-tile -- Sub And Prep
I've been doing smaller jobs until recently, and just got a whole house job to put in ~2000 sq ft of prefinished 3/4" oak, and ~600 sq ft of tile. Owner wants no transitions or tees, just the tile and wood to butt up nicely.
I pulled the carpets (nastiest carpets ever, short of Katrina soaked) and started on the vinyl. I need to finish that, and pull the little bit of wood as well. The subfloor appears to be 3/4" OSB (I've heard it called "chip board", but maybe I'm confusing things) throughout. In the baths and kitchen, there is 1/4" plywood overlay (where the vinyl was, I suppose to better bring the level to match the carpet. Of course, after reading many of the posts here, I am rethinking my strategy, so I wanted to lay it out and see what you all think: i) Lay wood over felt (or AquaBar, if I can find it again) on present subfloor ii) Thinset and screw 1/4" CB over the current 1/4" ply over subfloor. This *should* put the wood and tile and nearly the same height. Thanks for reading. -Jimi P.S. First thread started... been lurking for a few months, and finally joined. I recently relocated, so it's a bit like starting over (finding dealers, distributors, etc). |
Trade: Tile installations
Re: Wood-to-tile -- Sub And Prep
Sorry, I don't install hardwood, so can't be of much help there, someone else will chime in I'm sure.
As for the tile, NEVER install it over 1/4" wood, doesn't matter where it is, it can't be in the mix, so remove that first, 3/4" OSB or Plywood is minimum for a subfloor before a CBU or membrane, I like more wood, say 1/2" plywood. What is your joist size, spacing and length of them unsupported?, this would also help in determining if that floor meets specs for tile, are you planning on Ceramic or Stone?
Flooring Guru
Trade: Sales Manager
They will still need some sort of transition to tile.
wood expands and contracts, so if it is butted up to tile, are they o.k. with gaps?
------------------------ "in 20 years you will regret more what you did not do than what you did" |
Master Craftsman
Trade: Rustic interior woodwork
I have always just put a roundover edge on the last peice of hardwood before tile then stained and finished the edge to match. If you lay your tile on 1/4 inch hardibacker the tile will be just short of the same height but have never had any complaints. Leave a gap between tile and hardwood to match your gap between tile then fill that gap only with color match caulk to match your grout. This also helps with expansion and will not crack out like grout. Hope this helps.
Dave.
Do one thing at a time, do it well, then move on. http://www.bigdaveswoodworks.com |
Hey Floorcraft , I have had succsess with a soft loint of tech caulking that matches the grout up to wood
Rebuilding the past.
Trade: Remodeling , renovations , snow services
As far as the tile I always tear out everything down to the subfloor and then use 1/2" cement board. Usually puts the tile within 1/8" of hardwood and gives a very solid floor. If the subfloor under the tile is pieced and soft it will crack at the grout lines. Makes for a very unhappy customer.
Interoir and Exterior Home Remodeling and Snow Services
Midwest BuildIt Inc. |
Chief Toilet Mover
Trade: Bathroom Remodeling
In regards to the transition, I would run one strip of hardwood the long way against the tile transition and install a Schluter strip at the edge of the tile, you will end up with a 1/16 reveal, all my clients love this method, they all comment how finished it looks. There will be no cracking of grout and no expansion issues since the long piece of hardwood will expand and contract evenly and consistantly allong the transition strip.
![]() It will look something like the picture except you will have wood in place of the carpet. |
Trade: hardwood floors
just leave you a grout line width between the tile and wood and where you get your grout you can buy some caulk that matches the grout, sanded too, that way it will expand and contract without cracking your tile. It will look jsut like the tile grout.
#9 | |
Master Craftsman
Re: Wood-to-tile -- Sub And PrepQuote:
Dave.
Custom Builder
Ditto fellas, good answers even with the echo.
Don't forget to make sure the sub layment is equal or no less than 1 1/4" before tile. Also I agree with R&G, better check joist size and spacing. Bob
Bob |
Chief Toilet Mover
I would caution everybody who recommends color matched caulk for this problem. The expansion characteristics of tile caulk are rather limited. Within a year you are going to see a very distinct pull back separation line everywhere the caulk touches the hard wood, sure it's going to look really nice the day you finish the job, but it won't look that way forever. But to each their own.
I have not used this product but saw it on a job this week. I talked to the tile guy who says its better and easeir then ply underlayments. You can call the manufacture and give them your floor conditions and they will give you specific install instructions for your floor. http://www.tileprotection.com
#13 | |
That may be true, but it is caulking, it can be touched up. |
#14 | |
It's an isolation membrane, and a very good one.
You can get siloconized sanded caulk to match the grout. When you order the grout, just order the caulk in the same color. As far as prefinished hardwood up to tile, keep the tile just a 1/16th higher than the floor, caulk the joint and your good.
I admit...I don't know everything...but don't tell my kids I told you.
#16 | |
Chief Toilet Mover
I think all us good guys shoot for that.
And to be totally honest with you I dont install ceramic. But I do install wood and I have gone through great lenths for a customer to get a floor at the right level so the wood and tile are flush. They like the no transition and are willing to do the maintenence needed for a soft joint. Just to be clear, it wouldnt be my first choice but I will give my customers what they want if at all possible. |
#18 | |
Chief Toilet Mover
#19 |
I was clear. Like I said I dont do ceramic so I would never have an occasion to use Schluter. That being said I think it should be used on every tile job but alot of guys dont use it.
My point was having a flush transition between the wood and the tile and using a soft joint between the two. Is it the best option? IMHO no, but sometmes you just cannot talk a customer out of it . In those specific cases a soft joint is the best option. |
#20 |
SAGE
Trade: Remodeler and Finish Carpenter
Mike F. & Mike C.
I think your both on the right track, just talking about two different situations. If the hardwood is in already (or not) a Schulter strip is the way I go. Permanent, w/ no issues, never had a call back. If the tile is already down and the wood has to go in, then a soft joint is appropriate IMHO, if bridging the transition is not called for. I have had call backs on the soft joint outside of a year later. Quick fix, and the client expected this to occur because I already planted the seed during the build. I never grout the transition for reasons already presented.
-Lead from the front, or dont lead at all- |
