Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 06-18-2008, 10:15 AM   #1
Trade: Structured Wiring / Home Automation
Wood options over concrete
Ok, I am new here and flooring isn't my area of expertise. I installed some BR-111 engineered flooring in my townhome only to be extremely disappointed in the durability (we have kids and a golden retriever). My question is what is my best option with regards to a wood-like product over concrete that is DURABLE? I'm not looking to spend a ton, and I will do the install myself. I am just clueless as to what to go with.
The rest of my townhouse I am very proud of, but the floors downstairs are just an eye sore. HELP!
Vader49 is offline   Reply With Quote
Old 06-18-2008, 03:14 PM   #2
genecarp's Avatar
welcome to the site, i cant recomend a specific brand, but i do know that there are plenty of engineered woods out there that will perform great, a flooring guy should be along soon.
genecarp is online now   Reply With Quote
Old 06-18-2008, 04:01 PM   #3
Professiona Instigator
rbsremodeling's Avatar
Trade: Design Build Remodeling Contractor Washington, DC
Install Bamboo floors and get rid of the dog
rbsremodeling is offline   Reply With Quote
Old 06-18-2008, 09:15 PM   #4
Old school Ranger
floorinstall's Avatar
Trade: flooring
look for an acrylic impregnated or ceramic finish engeneered wood floor. They can get pricy but worth the money They grow old very gracfully.
floorinstall is offline   Reply With Quote
Old 06-21-2008, 09:23 AM   #5
Trade: wood flooring
what is it that your disappointed in? did it dent from the dog or did the finish wear off?
psaulnier01907 is offline   Reply With Quote
Old 06-23-2008, 05:25 PM   #6
Knowledge Factory
Floordude's Avatar
Oversold expectations.
Sounds like the wood flooring is being wood. The wood you have is durable, for wood. Your expectations may be met with concrete, acid stained or just highly polished.
http://www.AustinFloorguy.com
Floordude is offline   Reply With Quote
Old 06-25-2008, 03:04 PM   #7
Trade: Flooring(hardwood/tile)
I like the stained contrete idea.. sharp lookin floor imo... but if you're wanting a wood look, a product you may want to consider is Konecto(spelling?)
its not very expensive, they've got some colors/textures that look fairly decent, is pretty durable, waterproof, and extremely easy to install... just floats over the floor and the only tool you need is your razor knife.
Also, there are some great engineered products... and you can also use any hardwood just glued down instead of nailed...
ridewags is offline   Reply With Quote
Old 06-28-2008, 11:24 AM   #8
Trade: Contractor
If you like to wood look and want something durable i would highly recommend the Karndean vinyl plank floor it's commercial rated and it should do better than any laminate or engineered wood. Stay away from bamboo its way to soft.
gogreen is offline   Reply With Quote
Old 06-30-2008, 02:49 AM   #9
Trade: magnesium oxide board
Send a message via MSN to fireproofboard
magnesium fireproof board
Magnesium fireproof Board (usually called magnesium oxide board) is combined system of MgO, MgCl2 and H2O alkali agent.The stable magnesium colloid is reinforced by middle alkali glass fiber net and stuffed by light material then becomes new frameless decorative material. It has the features of light quality, strong intensity, little contraction, easy constructing. Especially the unique waterproof, fireproof, corrosion proof and plasticity are better than normally used wooden multisplint, paper surface plaster board etc.
Five Main Advantages:
1. Fireproof
2. Moisture-Resistance
3. Heat Insulation
4. Sound Insulation
5. Bump-resistance and light
fireproofboard is offline   Reply With Quote
ipe wood tiles, over concrete genecarp General Discussion 0 05-28-2008 07:10 AM
Another wood subfloor over concrete slab GreenBuilder Carpentry 3 05-08-2008 12:20 PM
wood over concrete steps Patrick Decks & Fencing 3 04-09-2008 10:51 PM
Concrete To Wood Membrane TIMS Concrete & Paving 2 04-09-2008 10:30 PM
Connecting wood floor joists to concrete block structure in century home. bob_cntrctr Masonry 12 02-26-2008 12:27 PM
